Forums General Discussion battery charging
This topic contains 1 reply, has 2 voices, and was last updated by  RichCarter 11 months, 1 week ago.
  • #224040
    Rock Richardson
    have a wench (bow), engine, and two house batteries, a 75 watt solar panel and engine alternator would like to charge all at once but not overcharge. sorry newbie
    rock
  • #224063
    I’m not sure I understand your question but let me give it a try. I assume that the winch battery is up forward, placed there to avoid having to run a heavy set of cables to the winch. You should be able to charge them by simply connecting them to the house batteries. You should use a heavy gauge wire pair to connect this. 6 or 8 AWG is probably heavy enough. I chose to connect my winch directly to my house batteries but I had to use expensive wire, 2/0.
    As for the house batteries, setting up a charging system for them is a pretty big topic. You’ll never get two boaters to agree on the right setup if there is such a thing. I suggest that you get a book and read up on it. Here’s a popular book that many folks like.
    https://www.amazon.com/12-Volt-Doctors-Practical-Handbook/dp/187879700X
