Forums Announcements flushing out the coolant system
This topic contains 0 replies, has 1 voice, and was last updated by  Rock Richardson 4 weeks ago.
  • #225241
    Rock Richardson
    got a question.
    1. can I fill the cooling system with a flushing mix in run the engine for a short time, then dispose the mixture ( I removed the thermostat) or should I use water
    2 where is the best place to drain the mixture
    3 what is the direction of flow or does it matter ?
