Forums General Discussion fraudulent gear shift control cables
This topic contains 6 replies, has 3 voices, and was last updated by  Hull152_Patrick 8 years, 2 months ago.
  • #68235
    Seawater
    does anyone know the length and type of control cables that are used for the gear shift and fthrottle on the w 60 ? or for that matter, any 424? One of mine has seized and I would like to buy the new parts before I tear the old one out.
  • #76782
    Seawater
    Walter
    SV Madness
    P424 Hull #1
    http://pearson424.org/mailman/listinfo/maillist_pearson424.org
  • #76783
    When my shifter cable broke I replaced it with cable that matched what was
    there, but I think at 11 feet it’s actually way too long. I had to get the
    boat back and running in 24 hours though so I didn’t want to dink around
    with trying a shorter cable. I have a W58.
    Teleflex Marine TFX CCX63311 – 3300CC TFXTREME CONTROL CABLE, 11FT
    I started by using a piece of string to measure the length of the cable, if
    you think yours is different than mine I’d do that.
    I also bought a pedestal rebuild kit at the time and replaces all the
    bushings and washers. You will have the entire pedestal apart anyway so you
    might as well do it. Your pedestal may not match mine.
    Edson EDS 314-335 – PEDESTAL REBUILD KIT
    Read the Edson instructions on installing your pedestal.
    http://www.edsonmarine.com/support/PDFs/planning/EB381SteeringGuide.pdf
    You will need to loosen the cables from the quadrant and disassemble the
    top-end of the pedestal completely. You should also find someone to spend
    the day with you who has long arms and small hands to help you pick up stuff
    you drop in there. OMG, that was a pain…
    Hope that helps !
    the old one out.
    Walter
    SV Madness
    P424 Hull #1
  • #76784
    I gotta ask. What’s a fraudulent cable?
  • #76617
    Seawater
    Sorry, the spell checker must have changed a mis-spelled Frozen to Fraudulent.
  • #76785
    Seawater
    Walter
    SV Madness
    P424 Hull #1
  • #77411
    I’m reply to this old thread because while I have the cover of the engine I also want to look into getting a proper cable end onto my shifter. When I originally did this repair the fitting supplied was too long and wouldn’t lineup so to get it working I drilled out the original fitting, which is what you see in this picture:
    http://www.flickr.com/photos/deepplaya/5937816368
    Does anyone happen to know where I can find a proper fitting or at last the part number? The Teleflex website isn’t much help.
    I was also thinking it might be possible to bend a piece of SS, tap the end that goes on the cable and drill out a fitting that fully connects to the transmission shifter “post”.
    Hope that helps !
    -p.
    </quot
