Forums General Discussion Zerc fittings on old bronze through hulls
This topic contains 0 replies, has 1 voice, and was last updated by  Seawater 8 years, 7 months ago.
  • #68252
    Seawater
    I may be the only owner with the old bronze through hulls, but…
    I got tired of dis-assembling them every year or two, given the contortions you have to go through to reach them, so I pulled all of the plugs and screwed in stainless zerc fittings.
    Now I just go give them a few shots of waterproof grease once in a while and work them a little. it can be done in the water, so you can do it mid season. If one starts to get the least bit stiff, it gets greased.
    The only problem I can think of is that it will be harder to detect leaching of the nickel, with the attendant pink color, but I try to inspect on the hard from outside the boat.
    Walter
    SV Madness
    P424 Hull #1
    http://pearson424.org/mailman/listinfo/maillist_pearson424.org
