Viewing 15 posts - 1 through 15 (of 21 total)
  • in reply to: Complete refit and blog invitation #225193
    David Siegel
    We’ll be out in Nova Scotia in September, if your return route takes you back to your home province we would like to meet up.
    Jim Sanger
    SV Idyll Ours
    Jim, how is your itinerary and timing looking? We are currently in the Bras d’Or Lakes and will be back on Nova Scotia’s south coast by the end of August. In September we will cross back to the US, but the exact departure time is TBD. Wonder if we will cross paths.
    –David
    SV Winnedumah
  • in reply to: Refit news #225153
    David Siegel
    Sorry about the multiple photos. When I was uploading them, it looked like the process failed several times, and I realized I was making a “user error.” Finally, I did it the correct way. Later, all the others showed up, but the editing function was not available.
    Here is another photo of the refit in progress.
    IMG_20190708_104923
    • This reply was modified 2 months, 1 week ago by  David Siegel.
  • in reply to: Refit news #225144
    David Siegel
  • in reply to: Owners Registry Is Now Online #225128
    David Siegel
    Hull # 94 is now owned by David Siegel and Susan Dray. Name is Winnedumah. Homeport is Minneapolis Minnesota. Location not specified.
    –David
  • in reply to: Wanted: Sails. #225001
    David Siegel
    Hi Rich. Are you still looking for sails? I have a complete set. They seem to be in pretty good condition, but may need their reinforcements at the corners replaced.
    –David
  • in reply to: Used parts #224584
    David Siegel
    In case you can’t find the plate”
    Here is a link to the W60 manual, with detailed diagrams and measurements: https://www.westerbeke.com/advanced%20specs/w60.pdf.
    Here is the same for the W58. https://www.westerbeke.com/advanced%20specs/w58.pdf
    Its dimensions and form are slightly different from those of the W60.
    If you find out that your engine is a W60, hope you saw my earlier post about parting out our engine plus list of additional spare parts. Let me know if you are interested.
  • in reply to: Single line reefing #224579
    David Siegel
    Thanks for all this great information. Any other approaches or experiences out there? I would appreciate any photos anyone might be able to send to clarify the descriptions. I will also report on whatever we end up doing.
    –David
  • in reply to: Repowering–W60 stuff for sale #224570
    David Siegel
    Hi Adam,
    Sorry I missed this. Yes, I still have that stuff? Are you still interested?
    –David
  • in reply to: Refit news #225157
    David Siegel
    Hi Herctor. In the photo, the guys are reinstalling the overhead I made last year.
    The boards are PVC, 8′ in length. However, I cut them into shorter sections so they would not flex uncontrollably in the installation. Cutting them to fit, using the original overhead panels as templates, was quite challenging, and there was a lot of wastage, so be sure to buy plenty. Part of the cutting challenge was that the original panels had spaces between them, but I had to make the new overhead continuous or I never would have been able to get the grooves to line up. So I butted up several strips to make a wide enough panel to lay 2 side by side overhead panels on them, trying to approximate the space that had been left. This was challenging because those spaces were not exact in the first place–they didn’t have to be–and my approximation introduced more errors.
    Here’s a photo of the cabin before it was disassembled to enable rebedding deck hardware. The dome nuts that you see were for through bolting mast pulpit bases. The real nuts are under the overhead. The bolts have now been cut back and we are covering the holes with new dome lights.
    43698061_10214950902104884_4550810547838255104_n
  • in reply to: Refit news #225147
    David Siegel
    No solar panels yet. However, we did radically increase our battery capacity. Panels and/or wind generator are in our future.
  • in reply to: Complete refit and blog invitation #225126
    David Siegel
    Thanks. We are not native Nova Scotians, but do hope to be there in September. Let’s keep in touch.
  • in reply to: Complete refit and blog invitation #225121
    David Siegel
    Would love to check in with you if our route takes us to the Chesapeake. Enjoy the sails.
  • in reply to: Complete refit and blog invitation #225119
    David Siegel
    We’ll be posting a bunch.
    • This reply was modified 2 months, 2 weeks ago by  David Siegel.
  • in reply to: Repowering–W60 stuff for sale #224581
    David Siegel
    I have to check on the alternator I listed in the original email. I took that list from the one the PO gave me. But I am not sure I have seen the spare that’s listed. However, there is a 100 AMP alternator on the engine. If you are interested, in that one, let me know. I do have the spare manifold. The engine and equipment are currently in Nova Scotia. What’s the best way to contact you?
  • in reply to: Repowering–W60 stuff for sale #224580
    David Siegel
    Hi Adam,
    Just want to make sure you know that I did finally see your message. Let me know if you are still interested.
    –David
