Forums › General Discussion › A/C installation
Viewing 8 reply threads
    • #67657
      Adam
      I just installed a new 16,000 btu a/c unit in the starboard hanging locker in front of the head. The boat only had one outlet installed just above. I was wanting to add more vents, especially to the V berth and wanted to know who has done this, where they put the vents, and any problems to consider. It sure is great to have A/C in the south!
      Thanks, Adam
    • #73520
      Adam,
      I inherited an A/C similar to the one you've just installed in the handing locker.  The PO ran a 3″ vent to the forward cabin, down the lockers behind the starboard settee backs.  It exits through a smal vent on the port side of the forward berth.  He also ran a vent to the aft cabin (through the locker behind the head sink and outboard of the shower liner to another vent on the navigation desk.
      The A/C works well for the forward cabin and pulls the temp down to the low to mid 70s on the hottest days.  The aft cabin vent doesn't do much.  The problem is most likely in the duct work to which the A/C output is connected.  When and if I replace the existing A/C I'll try to learn a little bit about ducting and maybe improve the aft cabin situation.
      Two problems with this arrangement.
      1. The vent hose takes up a lot of space in the lockers behind the settee backs.
      2. Condensation can produce a fair amount of moisture in those lockers.
      Neither problem is very serious.  I certainly am glad to have the A/C for the last 6 weeks in New Bern.  It has been cool for 3 or 4 days now, but we had a month and a half where the high temp just about never got below the mid 90s.
      Thanks, Adam
    • #73528
      My heat pump installation is similar to Johns. I bought a Mermaid from Defender.
      I have a large vent coming out of the locker immediately aft of the hanging locker door for the main cabin, a vent that leads to the head, one that leads forward to the v berth (like John's) and another that leads aft to the Nav station (like John's).
      Eclipse
      On 9/3/09, John Stevenson < ([email][/email])> wrote:
      Adam,
      Thanks, Adam
    • #73529
      joe shimkonis
      I installed one 16000 BTU same place.I wanted to run one vent of 3 vents to service the V berth.Running inside the upper cabinets it was a very tight cut and fit just a the bulkhead separating v berth from main cabin.The other consideration was to go down under the floor boards and up at the v berth but I was concerned with needing much more insulation-so I did neither.I have 3 vents coming out in the main cabin and it doesn’t do that bad in Myrtle beach,sc even in 95 degrees and only 16000 btu’s.Installed 3 years ago.
      Joe Shimkonis
    • #73530
      If (when) my OceanAir unit fails I intend to replace it with a similar from Mermaid.  Has that A/C worked well for you?
      Eclipse
      Adam,
      Thanks, Adam
    • #73531
      Sorry, Rick not Rich
      On Fri, Sep 4, 2009 at 4:38 PM, John Stevenson < ([email][/email])> wrote:
      Eclipse
      Adam,
      Thanks, Adam
    • #73540
      Adam
      Yes I am running into the same problem as Joe. The entryway through the bulkhead into the V berth is very tight. It looks like I will have to bring the cushion outward to make room for this vent. How do John’s and Rick’s boats deal with this? Is the vent 4″ going forward and 6 ” going to aft cabin.
      Also I have the Mermaid unit and it made the CO detector go off in the middle of the night. On the second night it did it again with 3 ports open.
      Thanks for the advice
      Adam
    • #73550
      My vent to the main saloon is 6″
      My vents fwd and aft are 4″
      Yes it was very tight getting through the bulk head into the V berth.
      I have carbon monoxide detectors in the V Berth and aft cabin and have never had a problem with them going off when the AC was in use.
      In Virginia, on the southern Chesapeake Bay, the 16,000 btu Mermaid has performed well. On a day where the temp is 98+ it cannot keep the cabin temp in the low 70s… it will however keep the humidity low and even though the cabin temp is upper 70s it still feels great.
      I think our size boat probably needs 20,000 btu but or so to keep them really cool.
      I think the Mermaid is a good value (I also installed one in our last boat, and ODay 34) and the mfg has given good advice and support when requested.
      Our marina electrics couldn't support a larger unit if I wanted to get more AC.
      Eclipse
      On 9/7/09, Adam < ([email][/email])> wrote:
      Yes I am running into the same problem as Joe. The entryway through the bulkhead into the V berth is very tight. It looks like I will have to bring the cushion outward to make room for this vent. How do John's and Rick's boats deal with this? Is the vent 4″ going forward and 6 ” going to aft cabin.
      Adam
    • #73569
      Here is picture of the vent in Sarah's forward cabin.
      Eclipse
      Adam
