Forums › General Discussion › AC Main Breaker
Viewing 24 reply threads
    • #68197
      Has anyone replaced any the AC Main breaker (mine is fried)? I’m curious if
      the Blue Sea Systems 30Amp A Series double toggles are a match to the panel.
      http://bluesea.com/category/3/11/productline/overview/19
      <http://bluesea.com/category/3/11/productline/overview/19>Thanks,
    • #76385
      Patrick,
      I haven’t replaced that breaker, but I’ve replaced others (to change the
      amperage) and Blue Seas breakers fit those other slots. I’ve also used Blue
      Seas meter to replace a dead AC Ammeter and add one for my SSB. So I would
      go with the Blue Seas. I have a Marinetics panel (The Blue Seas of the
      70s), Pearson may have changed to something else before the end of the P424
      run.
      On Mon, Dec 13, 2010 at 4:46 AM, Patrick “Peaboy” Walters <
      panel.
    • #76386
      Thanks John, I also have the Marinetics panel (Hull from 1981).
      On a more fun note, we had a nice trip this weekend to Blake Island in Puget
      Sound. On the way home we sailed in 20kts of breeze with gusts to the mid
      20’s. All downwind or beam reach under jib alone with following seas and
      current. It was nice to do 6+ kts with ocassional 7kts for our nice short 2
      hour jaunt.
      On Mon, Dec 13, 2010 at 7:11 AM, John Stevenson <>wrote:
      Patrick,
      Blue
      run.
      if
      panel.
    • #76389
      Went down and pulled out the bad AC Main breaker wire and now I’m a tad
      perplexed. I have a 30amp shore cord and always thought the boat was wired
      for 30amps. My shore power plug on the boat appear to have been replaced
      after manufacturing, but all my panels and breakers are Marinetics and I
      assume all original original.
      My AC Main breaker was a 50amp breaker and I have other breakers in the AC
      panel that are labeled as 30Amp.
      Was the P424 wired for 50amps originally?
      On Mon, Dec 13, 2010 at 3:58 PM, Patrick “Peaboy” Walters <
      Puget Sound. On the way home we sailed in 20kts of breeze with gusts to the
      mid 20’s. All downwind or beam reach under jib alone with following seas and
      hour jaunt.
      Patrick,
      Blue
      would
      P424
      run.
      if
      panel.
    • #76390
      Hi Pat,
      When I replaced my charger/inverted I found the same thing. The wiring was
      good for 1 leg of a 50 amp service. My main breaker is 30 amp, tho. I had to
      replace all the wiring from the plug on.
      If you check the plug you may find the wires don’t fit properly as I did.
      I’m not being short. This is from my mobile.
      On Dec 14, 2010 4:13 AM, “Patrick “Peaboy” Walters” <>
      the
      and
      2
      hour jaunt.
      wrote:
      Patrick,
      Blue
      would
      P424
      run.
      curious
      if
      panel.
    • #76394
      Same here, 50A main breaker. I have a 30A breaker at my isolation
      transformer up stream from the panel, so this breaker doesn’t protect much.
      All of the sub-circuit breakers are 15A or less, except the frig and the
      A/C, which are 30A and 20A respectively. Can’t explain the 30A for the
      frig, which appears factory installed. I don’t believe the old Grunert
      (died in 2001) drew more than 10A.
      I could use 50A service right now. It’s really cold in Jacksonville (once
      again I didn’t go far enough south). Back to breaker roulette trying to
      juggle a couple of space heaters, the frig and hot water heater.
      On Tue, Dec 14, 2010 at 6:05 AM, Robert Fine <> wrote:
      Hi Pat,
      to
      wired
      AC
      the
      and
      short
      2
      hour jaunt.
      wrote:
      Patrick,
      the
      Blue
      would
      P424
      run.
      curious
      if
      panel.
    • #76399
      I have contemplated moving the shore power connection and getting a longer
      cord. Wonder if I should replace the 50amp main AC breaker and put in a
      50amp shore cord…
      Might be better to do a different modification to accommodate overseas
      power….
      Well now I’ve got some research to do I guess.
      Hi Pat,
      was
      to
      wired
      replaced
      I
      AC
      to
      the
      seas
      and
      short
      2
      hour jaunt.
      wrote:
      Patrick,
      the
      used
      Blue
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76404
      Hi Patrick,
      Here’s the thing: even if you put a 50 amp cord and stuff, the boat is only
      wired to handle one leg of the 220v circuit. Surprisingly, that’s not all
      that unusual. I’ve seen large-ish motor yachts wired that way.
      If you’re going to Europe where there’s 220vac single phase current, you
      have to have a step-down transformer to run the normal boat loads. Stuff’s
      just not wired the same there. It’s easier for a foreign 220v boat to hook
      up here to 50 amps (2 hot leads, 1 ground) than it is to take a 50 amp 110v
      single leg boat and hook it up there.
      What you could do (and I would if I were going to 50amps) would to put a
      second AC panel and box for big loads – heaters and air conditioning,
      refrigerator, etc. and the other 50 amp leg to run all the other ac loads.
      Then you’d have something!
      On Tue, Dec 14, 2010 at 2:01 PM, Patrick “Peaboy” Walters <
      50amp shore cord…
      power….
      much.
      (once
      Hi Pat,
      was
      had
      to
      did.
      tad
      wired
      replaced
      and
      I
      the
      AC
      in
      to
      the
      seas
      and
      short
      2
      hour jaunt.
      wrote:
      Patrick,
      change
      the
      used
      Blue
      I
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76405
      OK, after looking into this a bit more, I’ve decided I’m not ready to dig
      into this now and it’s not realy neccesary. Since it’s winter we need the
      AC Power to make the boat comfy.
      I’m going to properly size the wire to the existing plug and drop in a 30AMP
      main breaker. I’ll look at the individual circuit breakers and see if they
      need to be downsized. I think the 30amp ones that were in the panel may have
      all been spares anyway. (Need to take some pics of that so I can sit at my
      desk and be sure about it)
      Not planning to go to Europe and since we plan to be very infrequently in
      Marinas we’ll rely on Solar, a Honda EU2000i with the engine as the backup
      to both those for charging in Mexico and beyond.
      Need the AC to make it through the winter…
      On Tue, Dec 14, 2010 at 1:38 PM, Robert Fine <> wrote:
      Hi Patrick,
      110v
      longer
      50amp shore cord…
      power….
      much.
      the
      (once
      to
      Hi Pat,
      wiring
      was
      had
      to
      did.
      tad
      was
      wired
      replaced
      and
      I
      the
      AC
      Island
      in
      gusts
      to
      the
      following
      seas
      and
      nice
      short
      2
      hour jaunt.
      wrote:
      Patrick,
      change
      the
      used
      Blue
      So
      I
      would
      of
      the
      of
      the
      P424
      run.
      I’m
      curious
      if
      to
      the
      panel.
    • #76406
      I am fairly certain that the 50Amp inlet on the 424 is only a single phase (leg) connection. So just one hot leg of 50 amps.
      On Dec 14, 2010, at 2:38 PM, Robert Fine <> wrote:
      Hi Patrick,
      50amp shore cord…
      power….
      much.
      (once
      Hi Pat,
      was
      had
      to
      did.
      tad
      wired
      replaced
      and
      I
      the
      AC
      in
      to
      the
      seas
      and
      short
      2
      hour jaunt.
      wrote:
      Patrick,
      change
      the
      used
      Blue
      I
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76407
      Yes. Originally wired for 50 amps as a single 120 volt leg
      hour jaunt.
      Patrick,
      Blue
      would
      P424
      run.
      if
      panel.
    • #76408
      If your bored I’d love to see an explanation of the difference between
      50amps as a single 120v leg and whatever the other way is.
      I assumed to upgrade from 30Amps to 50Amps and thus run more on the boat,
      you would just upgrade the feed from the shore to the panel (shore power
      cord, shore power plug, wiring to the AC Breaker) to be sized for 50Amps and
      then you could run more off the panel than you could at 30Amps.
      Is it more complicated than that?
      On Tue, Dec 14, 2010 at 3:03 PM, <
      wired
      AC
      the
      and
      short 2
      hour jaunt.
      >wrote:
      Patrick,
      the
      Blue
      would
      P424
      run.
      curious
      if
      panel.
    • #76409
      Basically correct. The thing is that more often than not these days docks don’t have the 50amp 120v single leg outlets sp u end up tapping two 30amp outlets using a Y adapter. Also there may or may not be two outlets available for one boat at the dock
      Regarding the “other way”, that would be a 50amp 220 plug which provides 120V at 50amps on each of two legs. This is like an outlet for a welder or more familiarly a dryer outlet though the latter is only 30 amps per leg.
      wired
      AC
      the
      and
      short 2
      hour jaunt.
      >wrote:
      Patrick,
      the
      Blue
      would
      P424
      run.
      curious
      if
      panel.
    • #76412
      As planed I left it as-is and just did a proper replacement. I have AC power
      again!
      Part list for the archive:
      – 20′ of 10awg3 Ancor shore power cable
      – 7′ 10awg Ancor white primary wire
      – Blue Sea A Series Toggle Double Pole PN# 7238
      – Ring Terminals for 10Awg Wire
      Out of the 20′ I was able to make the main connection to the breaker and
      from the 7′ the wire from breaker to the AC break out panel. The Green wire
      in the triple actually hooks into the ground as the wire comes through the
      hanging locker, so you will strip off a lot of the insulation.
      The wires connected to my shore power plug were only covered with electrical
      tape. There is a proper cover for the back I plan to buy. They probably left
      it off because the 6awg Type 2 wire they used was very stiff. Here’s a shot
      of that if you also see electrical tape and want a proper cover.
      http://www.marinco.com/product/30-amp-rear-safety-enclosure-8-way
      Thanks again everyone for answering my questions!
      On Tue, Dec 14, 2010 at 3:39 PM, <
      and
      wired
      replaced
      I
      AC
      to
      the
      seas
      and
      short 2
      hour jaunt.
      >wrote:
      Patrick,
      the
      used
      Blue
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76415
      Be careful! A common 220V outlet such as used for a dryer or stove has only three prongs. There are two hot leads and a ground. To split a 220v feed into two 110V circuits you need a four prong plug, two hot leads, neutral, and ground. Without the neutral wire, you may not have 110v on each circuit. If the main circuit is shared among lots of boats, there is usually no need to balance the loads. They will randomly balance themselves. If its provided from a single source such as a generator it should really be balanced with more or less equal loads on both 110V circuits.
    • #76417
      By the way, before you decide to go to 50AMP inlet wiring, check out the
      prices of the cords, adapters, and plugs. It is cheaper to run two
      30AMP inputs than one 50AMP, which is what lots of newer boats do.
      again!
      On Dec 14, 2010, at 4:17 PM, “Patrick “Peaboy” Walters”<
      and
      On Dec 14, 2010, at 2:13 AM, “Patrick “Peaboy” Walters”<
      wired
      replaced
      I
      AC
      On Mon, Dec 13, 2010 at 3:58 PM, Patrick “Peaboy” Walters<
      to
      the
      seas
      and
      short 2
      hour jaunt.
      On Mon, Dec 13, 2010 at 7:11 AM, John Stevenson<
      >wrote:
      Patrick,
      the
      used
      Blue
      would
      the
      the
      P424
      run.
      On Mon, Dec 13, 2010 at 4:46 AM, Patrick “Peaboy” Walters<
      curious
      if
      the
      panel.
    • #76420
      +1 on what Pete posted.
      If there is only 30A service on the dock, it’s a lot easier and cheaper to
      use two 30A cord sets to two 30A receptacles than to use a “Y” adapter to
      bring two 30A sources into the single 50A receptacle. That adapter usually
      costs > $400. My fun and games on the 54′ Bertram last summer opened my
      eyes to the world of heavy power requirements and usage.
      prices of the cords, adapters, and plugs. It is cheaper to run two 30AMP
      power
      again!
      wire
      electrical
      left
      shot
      docks
      30amp
      or
      boat,
      and
      tad
      wired
      replaced
      I
      the
      AC
      in
      to
      the
      seas
      and
      short 2
      hour jaunt.
      >wrote:
      Patrick,
      the
      used
      Blue
      I
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76421
      RIch,
      Correctamundo. Sorry if I added confusion. You are right that the
      marine split 220V must have four conductors. (The outer housing of the
      part of the plug that gets inserted is also ground, btw).
      What was on the 424’s is a 50AMP single feed 120V circuit. Three
      conductors: hot, neutral, and ground.
      If I were to want more power on a boat that is wired for a 30AMP input,
      I would go with two 30 AMP feeds instead of the 50AMP feed. (I have
      considered going that way as the 50AMP cord is a real monster. Most of
      the time I only use a 30amp cord with an adapter at the boat end).
      BTW, I also have a European cord input for 220V which goes to a
      transformer. I recently put both the input connectors into a recessed
      box which has a flush cover. This eliminated to two places that you
      could not comfortably sit in the cockpit due to these connectors. I’ll
      post a picture.
      On 12/15/2010 7:34 AM, wrote:
    • #76423
      I don’t know about where you folks sail, but around here in the northeast, 50A outlets are pretty rare. Most marinas have one 30A outlet per slip. Even if you have two 30A inlets on your boat, there is usually noplace to plug the second cord in unless you unplug the cord from the boat next to you. This is not the best way to meet the guy in the next slip 😉
    • #76424
      I have an adapter with two Male 30amp plugs that go to one Female 50amp
      outlet. This goes on the dock side and the 50Amp long cord plus into this.
      The cheaper option to the two females to one male adapter is to have two
      30amp outlets on the boat and have them wired internally. I do not know
      the ABYC approach to this (and I could not find anything in a quick scan
      of section E-11 of 08/09) but I would have two separate 30AMP breakers
      on the panel so that you do not have two live inlets when you are only
      feeding one. I do not know how the adapter works if the two 30AMP
      outlets on the dock are actually on separate legs or if that matters ..
      perhaps Rich could add some expertise on that.
      costs> $400. My fun and games on the 54′ Bertram last summer opened my
      power
      again!
      wire
      electrical
      left
      shot
      docks
      30amp
      or
      boat,
      and
      tad
      wired
      replaced
      I
      the
      AC
      in
      to
      the
      seas
      and
      short 2
      hour jaunt.
      >wrote:
      Patrick,
      the
      used
      Blue
      I
      would
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76425
      Pete,
      How does that “Y” adapter work that combines two 30A sources into one
      50A/125VAC receptacle? We looked at one it last summer, but decided we had
      spent enough of the owner’s money at that point. My guess is it blocks one
      leg if it is out of phase with the other. I can’t believe it rectifies the
      phases.
      If you ever head down the ICW I recommend getting a 50A shore to 30A boat
      adapter (unless you have a 50A/125VAC receptacle – in which case you may
      need Pete’s adapter). At ICW marinas (or just about any marina in FL) you
      may not have 30A/125VAC power at the berth. In which case you’ll need the
      adapter I described. It works with both 125VAC and 240VAC shore power
      (takes one phase of the later). As a matter of fact if you go down the ICW
      and spend a lot of time at marinas, it is best to have as many power
      adapters as there types of dock receptacles, including 15A.
      30amp outlets on the boat and have them wired internally. I do not know the
      ABYC approach to this (and I could not find anything in a quick scan of
      section E-11 of 08/09) but I would have two separate 30AMP breakers on the
      panel so that you do not have two live inlets when you are only feeding one.
      I do not know how the adapter works if the two 30AMP outlets on the dock
      are actually on separate legs or if that matters .. perhaps Rich could add
      usually
      power
      again!
      wire
      the
      electrical
      left
      shot
      docks
      30amp
      provides
      welder
      or
      leg.
      boat,
      power
      50Amps
      and
      tad
      wired
      replaced
      and
      I
      the
      AC
      in
      gusts
      to
      the
      seas
      and
      short 2
      hour jaunt.
      On Mon, Dec 13, 2010 at 7:11 AM, John Stevenson< >wrote:
      Patrick,
      change
      the
      used
      Blue
      I
      would
      of
      the
      the
      P424
      run.
      curious
      if
      the
      panel.
    • #76427
      I don’t know what the ABYC standard is for shore power but I can guess. If you use plug into two 30A plugs on the dock and feed two independent panels each with its own master breaker, I think you are OK. If you use a single 50 cord with a ‘Y’ cable to two 30A outlets, I would guess you are not in compliance with the law. It doesn’t make sense to do this. If the two outlets are wired to opposite phases of the 220v power, you will trip the breaker or worse fry something when you plug the cable in. If they are on the same phase, you are feeding a 50A cable with a 60A source.
      Someone more familiar with the ABYC standard might have a more authoritative opinion.
    • #76428
      Thanks for the tip. Unless you have A/C or electric heat on your boat, I can’t see the need for more than 30A. Here in the northeast, A/C is uncommon. Winters are so harsh that very few folks stay here over the winter.
    • #76429
      Which of course is why so many of us went south and need A/C. Of course
      with Global Warming we also need space heaters. Go figure.
      Freezin’ my butt off in FL.
      winter.
    • #76430
      Just checked my Calder on those “Y” adapters that combine 2 30A/125VAC
      sources into one 50A/250VAC circuit. Those adapters will not complete the
      connection to the boat if the two sources are in phase. The adapter will
      provide 50A/250VAC 2-phase power to the boat only if the 2 30A/125VAC
      sources are out of phase, which I guess is what adjacent 30A sources
      normally would be. If you need a single 50A/125VAC source then you will
      need another adapter to pickup only one of the phases provided by the “Y”.
      The cost of all of these adapters is probably over $500.
      Calder also recommends the dual 30A inputs rather than a single 50A/125VAC
      inlet for simplicity and lower cost.
      On Wed, Dec 15, 2010 at 12:48 PM, John Stevenson
      <>wrote:
      winter.
