Forums › General Discussion › aft bunk water heaters
Viewing 3 reply threads
    • #68261
      Not counting the two drawers under the the bunk that I converted to
      cabinets, I have three accessible areas from under the mattress. One is
      outboard and forward, the other two are aft of the two drawercabinet
      cavities on the front of the bunk and next to the engine.
      Do those of you with the water heater under the aft bunk have a fourth area
      just outboard of the two lockers next to the engine?
      My water heater is fine where it is in the port lazaretre, but I was
      thinking if some of you have found an additional space under the aft bunk
      big enough for a water heater, then I need to plan to open up the space for
      additional storage.
    • #76786
      Patrick,
      I have the same 3 lockers under the bunk. The middle one is where my
      6-gallon water heater is located. My AC frig compressor is in the aft one.
      The aft locker is next to the engine.
      On Fri, Feb 25, 2011 at 4:58 PM, Patrick “Peaboy” Walters <
      additional storage.
    • #76787
      I have the water heater and 1 – 4D battery and one Group 31 battery.
      On Fri, Feb 25, 2011 at 5:18 PM, John Stevenson wrote:
      Patrick,
      area
      for
      additional storage.
    • #76789
      OK, sounds like there isn’t any usable space not already accessible under
      the aft berth then.
      Thanks!
      On Fri, Feb 25, 2011 at 2:18 PM, John Stevenson wrote:
      Patrick,
      area
      for
      additional storage.
