Forums › General Discussion › Aft cabin mattress
Viewing 4 reply threads
    • #68586
      patn
      On Jul 3, 2012 7:04 PM, “pat noordsij” <> wrote:
      I believe you mentioned once that you just dropped on a full size mattress
      for the aft stateroom with minor modifications. Please confirm as we should
      be “in town” tomorrow where I can pick up a foam one from Ikea.
      – pat
    • #78639
      Pat-
      We bought a 4″ foam double mattress from a chain bedding store. Opened the seam and tapered the port side aft and notched the port forward corner to fit, then sewed the cover up again.
      This wasn’t thick enough so we got a 4″ memory foam topper. Since it was on top, we didn’t need to modify it.
      Cheap and comfortable.
    • #78640
      For the aft bunk, we bought those interlocking plastic springs. I can’t remember the brand, but I believe it was a a 4 letter Swedish name. They are in the small space ads in the sailing mags. They really work and can be form fitted to the weird size of that bunk. BIG difference!
      Ko Olina, O’ahu
    • #78641
      DITTO – my solution as well, and heat buildup in the memory foam is
      minimal. My best sleep is on the boat.
      In a message dated 7/5/2012 7:26:45 A.M. Eastern Daylight Time,
      writes:
      Pat-
      m2f
      Read this topic online here:
      https://www.pearson424.org/bb2forum/viewtopic.php?p=11342#11342
      m2f
    • #78654
      Pat,
      As you have read it was Quent who modified a standard foam mattress for the
      aft cabin. I went the high price route with a custom mattress from HMC in
      2002. Best $900 I ever spent, but I might go Quent’s route when this
      mattress needs replacement (10 more years?).
      writes:
      Pat-
      corner to
      m2f
      m2f
