Forums › General Discussion › Anchor chain snubber
Viewing 20 reply threads
    • #68215
      Dawn and Patrick,
      Congratulations on your completed foredeck project. That’s a big one off the
      list. At first I just shackled my anchor chain snubber to the pad eye,
      stowing the other end at the bow rail to attach to the anchor chain once the
      anchor’s set. Worked fine, but if you ever have to slip your anchor in an
      emergency – just drop it and run – you can’t do it. It’s a potentially very
      dangerous situation, the kind that can cost you your boat of worse. Remind
      me to photograph for you a better way to set up that snubber. Right now it’s
      dawn on New Year’s Day and raining.
      Reef early,
      SilverHeels, P-424 #17
    • #76493
      Dawn and Patrick,
      Reef early,
    • #76494
      Yes, you mentioned this before… You have a line through the bow eye and up
      to your bow cleat I believe.
      https://www.pearson424.org/bb2forum/viewtopic.php?p=5481&sid=67c821a8556673d24c661a5e33edeee3
      <https://www.pearson424.org/bb2forum/viewtopic.php?p=5481&sid=67c821a8556673d24c661a5e33edeee3>
      On Sat, Jan 1, 2011 at 5:15 AM, SilverHeels <> wrote:
      Dawn and Patrick,
      the
      the
      it’s
      Reef early,
    • #76495
      Damn, Pat, I can’t remember what I said yesterday, let alone in 2009. The
      thread you referenced, however, was way before I figured out the line led to
      the foredeck thing and, so, does not mention it. If I did describe it some
      time more recently, then you already know what to do. Even if you just have
      to suddenly scope out in a blow the snubber led as I’ve suggested makes it
      possible, while still keeping the pull down near the waterline.
      Good luck,
    • #76496
      Pat,
      I think we’re talking about two different stages of development with my
      anchor chain snubber. On 09/24/2009 I wrote in that thread:
      Regarding the anchor snubber, a line to a bow cleat is fine. However, if you
      install a really strong eye bolt through the stem about a foot above the
      waterline, then you can shackle a snubber line to that and leave it there.
      Its bitter end (THE END THAT ATTACHES TO THE CHAIN) stows cleated to a bow
      cleat (WHEN NOT IN USE). After you’ve set your anchor you affix the (BITTER
      END OF THE) snubber (TO THE CHAIN) as you normally would and feed out enough
      (ANCHOR CHAIN) rode so it (THE SNUBBER) takes up the strain, but now the
      angle of pull on the anchor is much reduced (being 6′ closer to water
      level). In effect, you’ve removed 6′ of “depth” from the rode:depth
      equation, enabling you to either use less scope for a given depth of water,
      or to achieve a higher scope to depth ratio “for free.”
      I have added notes (IN UPPER CASE) to the above quote to make the statement
      more clear. I hope this clarifies it for you.
      That was long before I realized the danger of that set-up, the inability to
      scope out or (in a dire emergency) cast off the anchor chain entirely
      without first retrieving 20′ of anchor chain and disconnecting the snubber.
      There is simply no way to reach and disconnect the snubber line when it runs
      from the near-waterline pad eye to the chain. What I’ve done now is to lead
      the line through the pad eye to the chain. The boat end of the line is not
      connected to the pad eye as it was on 09/24/2009. Instead, it runs through
      the pad eye, up to and through a shackle at the forward end of the chain’s
      anchor roller, aft through an eye that happened to be welded onto the after
      outboard end of the chains anchor roller, and finally to a foredeck cleat.
      This allows me to adjust the length of the snubber from the foredeck, or to
      cast it lose in an emergency, but keeps the pull down at the near-waterline
      pad eye, providing all the advantages of the low snubber without the
      potentially dangerous disadvantage that existed on 09/24/2009.
      I mention all this because I have never seen anyone else do it. If not
      unique, the adjustable/releasable snubber through a near-waterline pad eye
      is at least unusual. Still, it’s worth considering since you’ve gone to the
      trouble of installing the near-waterline pad eye. No point endangering your
      beautiful boat when there’s such a simple remedy.
    • #76497
      skipmac
      Hi Tor,
      I had also been thinking about running a snubber line through a pad eye on the bow for all the reasons discussed. Glad to see you’ve already thought it out and debugged the process for me, but a question.
      I have been very pleasantly surprised to see my 422 does not sail at the anchor when I run my anchor line over the bow roller. I mean not at all, point dead straight into the wind and stay that way even in a pretty good blow. When I added a snubber line I initially ran it through the bow chocks and started sailing all over the anchorage so ran the snubber over the the roller and back to steady.
      So, first question, have you or anyone else had a similar experience? Does the 42 typically ride so well at anchor (certainly none of my other boats ever did so)? Then does moving the lead to the padeye down on the bow, other than giving a better/lower angle pull to the anchor, change the way the boat rides at anchor especially increase (or decrease) sailing?
    • #76498
      ALL: I spend about six months a year on the hook, and here’s what I’ve
      found to be effective.
      I used a 25ft., 3/4″ 3 strand line to make my snubber with the chain hook
      secured midway with a slip knot, thereby creating two sections of snubber
      leading to the one hook. Each section is lead over the respective chock, prt
      & strb., to its adjacent cleat. The boat will not only dance less as
      tension is transferred from one side to the other but benefit from greater shock
      absorption, less strain on the hardware, and you’re still snubbed to a
      cleat in case either a cleat or your cleating skills fail. You also have more
      control, being able to winch in one side or the other in a blow, or let
      out or retrieve line as conditions dictate. Futhermore, this arrangement
      facilitates setting the anchor off the beam to counter act the effects of a
      surge (another story altogether).
      Also to cut down on dancing, try setting a double reefed mizzen as an
      anchor sail – Tor has the scoop on that, I believe.
      FYI to ALL: I did not go south this year so as to stay and complete
      renovations to my house. So CHARISMA is on the hard at Deltaville Boatyard where
      my 25kg ROCNA was stolen, probably during this holiday week as the yard is
      closed. NO one else lost an anchor to this thief SO I guess the moral here
      is secure your ROCNAs! ($OUCH!$)
      Happy New Year, everybody, BILL
      CAPT.BILL TICE~s/v CHARISMA, hull #120
      writes:
      Hi Tor,
      m2f
      Read this topic online here:
      https://www.pearson424.org/bb2forum/viewtopic.php?p=8806#8806
      m2f
    • #76499
      Hey Bill,
      The double snubber is a good idea. I see it used a lot, on monohulls and (of
      course) most often on cats.
      Regarding “setting the anchor off the beam to counteract the effects of a
      surge (another story altogether),” there’s an article on the subject at
      http://www.tor.cc/articles/rode.htm .
      Bummer about that anchor.
    • #76500
      Hi Skipmac,
      The dancing at anchor probably came from moving the pull of the anchor
      off-center on the hull. The farther to one side you place that force, the
      more the boat will turn in relation to the wind. Physics 101. Running the
      snubber from any center point, near-waterline pad eye or bow roller, or
      running a double snubber evenly to port & starboard chocks, should keep the
      boat nose to the wind and riding quietly.
    • #76501
      Hi Skipmac,
    • #76502
      skipmac
      @SilverHeels wrote:
      Hi Skipmac,
      Exactly. What surprised me is how little the Pearson sailed at anchor. I’ve had a couple of boats with rollers and always ran the line or chain straight off the bow but still would hunt back and forth as much as 30-40 degrees from side to side. With the Pearson I never saw a 5 degree hunt at anchor.
      So other than reducing the angle to the anchor did you see any difference in using the eye on the bow like pitching more or less in a choppy anchorage?
    • #76503
      I have never tested/compared a snubber off the near-waterline pad eye
      directly against a snubber off the anchor roller, but I can’t imagine
      there’d be much (if any) difference in the boat’s motion in a choppy
      anchorage. There is certainly a difference in the angle of pull against the
      anchor. Not sure why some boats sail at anchor, but as you have noted 424’s
      do not.
    • #76504
      On Easy Reach, hull #205, when it was still mine, I used a double snubber of two twisted nylon lines from the forward cleats, through the chocks to a chain hook of the the kind recommended by Earl Hines (I’d give a page number, but my copy of the book was left on board for the new owner). Eventually the galvanized eye shackles yielded to rust and I cut the them off and started using rolling hitches, each line tied separately to the chain. I discovered after some years that the hook had worn the gavanizing off several chain links. The rolling hitches, of course, won’t do that.
      I don’t think it is a good idea to run a line or chain off the end of the anchor sprit, unless someone can prove that the sprit will take loads the forward cleats will.
      Norris Larson
      — On Sun, 1/2/11, <> wrote:
    • #76505
      skipmac
      @norris larson wrote:
      I discovered after some years that the hook had worn the galvanizing off several chain links. The rolling hitches, of course, won’t do that.
      Have heard this from several sailors so tie in myself but use a Prussic Knot.
      That is a thought that occurred to me as well. Another reason to go for an eye on the bow. Meanwhile if anchored in a blow guess it’s a good idea to go with a bridle to the cleats.
    • #76506
      Norris,
      I use a rolling hitch, too. Never thought about the galvanizing wearing off
      – I’ve just never had a chain hook – but what you say makes sense. As for
      proving the sprit – i.e., an anchor roller extension – will take loads the
      forward cleats will, I’m sure it won’t. But in my experience it will take
      the loads necessary to hold an anchored boat in all conditions.
    • #76507
      Bill
      I’ve been suggesting that equal-length pennants is a bad idea for many
      years. Almost everybody seems to use them except me. This is odd, since
      the document linked below is published in our area. Marblehead harbor is
      open to the northeast. Here in New England, the bad weather blows from the
      northeast. This makes the harbor particularly dangerous. My 424 sank there
      when her mooring chain broke before I owned her. There were eight foot
      braking waves in the harbor during that storm. I bought her after she was
      rebuilt.
      http://www.inamarmarine.com/pdf/Moorings.pdf
      “No mooring system is complete without a safety
      pennant. Some harbors require safety or secondary
      pennants. This extra line is inexpensive compared
      to the cost of your insurance policy deductible.
      The safety pennant should be of equal size
      (diameter and strength) and 25%, or three feet
      longer (whichever is less) than the primary pennant.
      The theory is that the safety pennant will be in
      “perfect” condition when the primary fails.
      Marblehead has studied this issue and requires
      two primary pennants of line, the longer one
      being the safety pennant. During Hurricane Bob,
      Burr Brothers Boats, in Marion, Massachusetts,
      used a storm pennant of 5/8″ poly-reinforced wire
      on their vessels which proved to be very successful.
      Experience has shown that the primary (or shorter)
      pennant should have the chafe gear run from eye
      to eye, to prevent it from slipping out of the chock.
      The length of the pennant described in many
      standards is given as 2.5 times the height of the
      free board. At some harbors, the pennant size and
      length are based on vessel length.”
    • #76508
      A mooring safety pennant is smart – I add one on the rare occasions I pick
      up a mooring – but I believe Bill was talking about two equal-length anchor
      chain snubbers (or pennants) to divide the holding force of the anchor
      between two deck cleats. Here the anchor chain itself is the safety
      connection.
    • #76509
      Thanks, Tor, for the rescue!
      Rich is certainly correct and offers good advice re: mooring pennants, but
      this is a snubber matter (HA). (sorry). I am usually aboard while
      anchored, and certainly in a blow. Were I to lose one snubber for whatever reason,
      the other snubs the boat until I can tie on my backup and release
      additional chain & scope on the remaining snubber.
      PS: RE: my being winter land-locked in VA, someone has come to my rescue
      and offered me a boat sitting gig in George Town for 2 weeks – on the 17th,
      I’m outta here!
      BILL TICE~in residence ~*I*I*TREEHOUSE *I*I*I*~ Smith Mt. Lake, VA
      In a message dated 1/4/2011 10:29:18 A.M. Eastern Standard Time,
      writes:
      connection.
    • #76510
      Yahoo, boat-sitting in George Town! That’s a sweet deal this time of year,
      the perfect Bahamian holiday for the cost of the airfare.
      Have fun,
    • #76512
      I think the same reasoning applies to twin anchor-snumbers. IMHO, a bad
      idea.
    • #76525
      On holding chafing gear in place–I would poke two holes near the end of the poly tube or canvas sheath, run a stout line of small stuff grough the holes, and belay the end of the line to the mooring cleat to hold the tube or canvas in place. I suppose the gear could move back up towards the cleat.
      I’ve often thought about the problem of heat build up inside a poly tube. I decided that if we ever waiting for a blow at anchor that I would drill holes in the tube, allowing water to cone in contact witht he rope, thus cooling it.
      Norris Larson, PO of Easy Reach, hull # 206.
      — On Tue, 1/4/11, SilverHeels <> wrote:
