Forums › General Discussion › Anchor locker/ chain/windlass solution
- This topic has 19 replies, 8 voices, and was last updated 12 years, 4 months ago by
Tor.
August 21, 2010 at 11:51 am #68109
To those Pearson 424 persons interested,
This response is from Windsong, a Pearson 422 which has the same anchor
locker as all the Pearson 424’s have. I have 275 feet of chain and a Manson
60 pound anchor on the bow platform. I also have a 35 pound CQR attached to
22 feet of chain and a 300 foot, 5/8 inch line. Also on the bow platform at
the ready. The anchor bow platform has additional angled supports to just
above the water line. Ahead of the anchor locker, where Pearson placed it,
I have a LaFrance project 1000 windlass with a chain gypsy and a capstan. I
use the 60 # Manson almost exclusively when anchoring and rarely use the
second anchor. Most often, in New England waters, and up and down the ICW,
we rarely needed more than 100 feet of chain. The solution to what to do
with the extra 175 feet of chain was the problem, as there was simply no
room in the anchor locker for it. So, I went to Home Depot and got some 4
inch white PVC pipe and appropriate fittings for the two Rhodes. The chain
rode I led straight down through space forward of the V berth, in the 4”
pipe, so that the chain, all 175’ of it, now resides flaked underneath the V
berth, ahead of the bow thruster tube. I put a piece of ½” starboard in the
bottom of the space ahead of the V berth, shaped to the hull, and drilled a
hole to accommodate the pipe, as well as in the bottom of the anchor well
shelf, so that the pipe could extend up to ~3” into the chain locker in the
bow. I can now pull up any amount of chain length I need, if I need more
than 100’. I have both foot switches on the bow and a toggle switch at the
helm, for ease of operation of the windlass. The extra CQR anchor rode is
also led via a 4” pipe to the space just ahead of the V berth where it is
flaked around the pipe and in that space behind the removable hatch way to
what should have been an anchor locker. Having both Rhodes out of the way
leaves a lot of extra space in the bow anchor locker for two bungi cord
chain hooks of different designs (and lengths) and the electrical cord for
shore side power. I will gladly send pictures of the actual locker and star
board shelf, etc., to those interested. Send your e-mail and I will
respond. I like this solution as it does not necessitate running the chain
over the locker hatch door but drops the 100’ of chain into the lowest part
of the anchor locker shelf where it is easily accommodated without piling
up.All the best,
Brad Moynahan
S/V Windsong
Block Island, RI
August 21, 2010 at 12:50 pm #75881
ParticipantReworking the anchoring system on Lady Leanne has been on my “to do” list for a while as I have had other more salient issues to deal with. Up until now, we have been sailing her from the dock in Ke’ehi Lagoon as we became familiar with the boat and Hawaiian waters. We are now at the point where we plan to cruise to Molokai’i and Maui this winter and anchoring has become a priority. Patrick’s timely inquiry and the subsequent discussion have now motivated me to “get into” this now.
Lady Leanne has an anchor platform and 2 rollers for the Danforth and plow on board. Most people here cruise with 2 plows or CQRs. Your chain/line mixes and lengths sound appropriate to me and I would like to view your pictures so I can understand how best to stow them. Please email me at: dan.kalinowski@comcast.net
Lady Leanne II (#135)
Honolulu -
June 9, 2014 at 11:30 am #81063
ParticipantIf those pictures of the anchor locker work are available, I could make use of them. Started a similar project assuming there was drainage into the bilge under the forward water tank and was surprised to find that there was none.
June 9, 2014 at 11:55 am #81064
ParticipantDiscoverie,
Never hurts to say please. You may find those photos at
pearson424.org. If not, you may ask me for them.In my boat there was drainage into the bilge as you
describe. Pretty dumb idea, huh. When I rebuilt
Silverheels’ chain locker I sealed that drain closed
and drilled port & starboard holes so water in that
locker drains overboard. Way better.Tor
June 9, 2014 at 12:11 pm #81065
ParticipantDelete that “please” part. Rough morning here and the
captain’s grumpy. Let me know if you can’t find those
photos in the archive.Tor
June 9, 2014 at 12:18 pm #81066
patn
ModeratorI’ve resurrected the photo gallery link on the pearson website. All the
pictures should be there.
https://www.pearson424.org/gallerySilverheels wrote, On 6/9/14, 7:11 AM:
Quote:Quote:
June 9, 2014 at 12:25 pm #81067
ParticipantHi Pat,
I’m sure I’m doing it wrong, but I don’t see
Silverheels’ chain locker / foredeck rebuild photos
there.Tor
June 9, 2014 at 12:48 pm #81068
patn
ModeratorYou’re doing fine.. you sent the pictures in email. I’ve now added
them to the photo gallery
https://www.pearson424.org/gallery/index.php/Windlass-Installations/Silverheels-17-Installationare there more? could the writeup be better?
– p
Silverheels wrote, On 6/9/14, 7:25 AM:
there.Tor
June 9, 2014 at 1:17 pm #81121
ParticipantPat,
I could write a great deal more about that project – it
was a major undertaking for me – but the photos say
most of it. Here (attached) is most of what I have. The
numerical order is not quite chronological, but the
photos illustrate the basic idea. Many in between steps
are missing. Also missing is a shot of the drain holes,
which were drilled port & starboard at the bottom of
the locker, angled slightly down and aft. They function
perfectly and to my knowledge no seawater ever backs
into them.Tor
June 9, 2014 at 2:37 pm #81069
john stevensonParticipantI finally installed an electric windlass on Sarah last summer. I had
planned to follow Tor’s (and other’s) approach to cut out and cover the on
deck locker. i elected to retain the locker (for now). After one winter
anchored in the Bahamas that part of my installation worked reasonably
well, but I can certainly see the advantages of the more radical approach
used by Tor and others.Below is a link to my analysis the Pros and Cons of retaining the on deck
locker.
http://www.svsarah.com/Sarah/ewQuickWindlass.html#On_Retaining_the_On_Deck_Anchor_LockerRegards,
into them.Tor
June 9, 2014 at 3:19 pm #81070
ParticipantIf I were doing it again I would install a horizontal
windlass instead of the vertical I have, simply to make
handling the 2nd bow anchor easier. In practice I don’t
set the 2nd anchor all that often, although perhaps I
would do so more frequently if it were as easy as the
#1 hook. I have, however, devised a pretty good and I
believe quite original system for deploying and
retrieving the 2nd bow anchor with the vertical
windlass.John, I expect know about my anti-pyramid stick for the
chain locker. I’m sure I shared it with the group and
in fact it was in the February issue of SAIL as a
Cruising Tip.Tor
June 9, 2014 at 4:01 pm #81071
john stevensonParticipant“JJohn, I expect know about my anti-pyramid stick for the
Cruising Tip.
As a matter fact I was talking to someone the other day and he mentioned an
article he read in Sail about a way to knock down castles. I said, “Yeah I
know the author”.Regards,
Cruising Tip.Tor
June 9, 2014 at 4:41 pm #81072
ParticipantAutographed copies available for a small fee.
June 9, 2014 at 4:52 pm #81073
ParticipantA limited edition, autographed Torstick!
What you want for that?
Q -
June 9, 2014 at 5:06 pm #81074
ParticipantTor: Followed your anchor locker approach. I sealed up the anchor locker door and installed the diamond pattern non skid over it (matches the rest of the deck non skid). I did install a horizontal windlass unit though. Even put in an anchor wash down hose, which is accessed through its separate recessed container. Works great and looks like original equipment.
Keehi Lagoon, O’ahu -
June 9, 2014 at 5:09 pm #81075
ParticipantOh, man, that’d cost you big time. BIG time.
June 9, 2014 at 5:19 pm #81076
ParticipantTor: A fool and his money……….
June 9, 2014 at 5:23 pm #81078
ParticipantWhat? Hey, you guys are the ones living on islands!
Q -
June 9, 2014 at 6:36 pm #81079
ParticipantIt sounds like you did a nicer job of it, Dan, matching
the original gel coat. And you chose the more suitable
windlass, too. Glad to hear it all worked out so well.Tor
June 9, 2014 at 9:00 pm #81080
My PO added a Lofran Kobra 1000W under the existing locker door. It fits fine and I wondered how it would perform that low to the rollers. So far…just great! The only thing is he could have come up another inch higher to the locker door or another 1/2″ to port to make the bar fit and work easier on the gypsy clutch. I’m going to try and add pictures.
If the pictures don’t show….The windlass does completely fit ‘under’ the door and he put a stainless plate forward to the chain stopper which is mounted at the extreme aft end of the bow/cap rail.Sorry, I’m trying, but I can’t figure out how to make my pictures smaller.
