Forums › General Discussion › Boat gremlins
Viewing 6 reply threads
    • #68403
      That’s the best we have come up with so far. On way to Nantucket. Noticed issue underway:
      W60 runs great. 150 degrees, 70 psi oil. No smoke, white or otherwise. Valves just adjusted, injectors re jetted, heat exchanger cleaned, fuel pumps rebuilt. 2000 rpm usually gets me 7.0 in still water. Has for the past 4000 miles Now it’s 6.
      Paragon with vee drive. Clean, full oil, tranny fluid. No weird noises. Clean running gear, bottom. Not dragging a lobster trap. Not too heavily laden. Gps and apparent speed are the same, so it ain’t an adverse current. And not wind either.
      I got nothing. Who can show their smarts?
    • #77531
      Adam
      Have you verified the engine rpm’s with another tach, in case yours is faulty.
      To:
    • #77532
      Bottom fouled?
    • #77533
      Adam,
      Do you have feather prop, e.g., Maxprop, and was the pitched changed on you
      last haulout?
      On Fri, Aug 19, 2011 at 11:17 PM, Joseph Steiner wrote:
      Bottom fouled?
    • #77534
      Clean bottom, fixed 20″ prop. But have not verified tach. Engine really sounds right for rpms, but given the fact that I have an unknown variable where mostly simple mechanical configurations are involved, I’ll need to check. (and thank you for responses).
    • #77535
      Before I went totally nuts with the tach, I’d suspect the knot meter. They
      are notoriously finicky, and agreement with the GPS is temporary at best.
      Also, have you jumped overboard and actually looked at the hull or prop?
      This year seems to be the year of barnacles and it only takes a few on the
      prop to really screw up the efficiency. They have been growing
      significantly in as little as two or three weeks, even with fresh paint.
      s/v Phantom Corsair
    • #77538
      Adam
      If it were your transmission, the engine would likely behave as if you had a bad clutch. The engine would race like it was slipping. You don’t report that behavior however. You might check the transmission fluid to be sure. It shouldn’t smell burned and should be at the proper fill level. If it were the V-drive, you’d hear it.
      Is your engine still running to 2000RPM?
      I assume that you have a fixed-blade prop. My guess is a problem with your prop, possibly a line wrapped or growth on the prop. Barnacles can cause the problem you’ve observed. You’ve ruled this out however. Are you sure there’s nothing on your prop? Did you dive on it?
      A dirty bottom can make your boat act sluggish. Its amazing what a difference a clean bottom can have. You’d need quite a lot of growth for the behavior noted below.
