Forums › General Discussion › Brake Pads for the original Shaft Lock
- This topic has 3 replies, 2 voices, and was last updated 12 years ago by
October 9, 2014 at 9:58 pm #69002
pma_foyl
ParticipantHi all,
I don’t know the make/manufacturer of the original Shaft Brake on my 1980 P424, but it looks like I need some new brake pads.1. Can anyone here tell me “which pads” they are (or recommend an equivalent I can order)?
2. Does anyone have a PDF Owners Manual for the shaft brake device? It might be helpful as I attempt to remove and replace the pads.
As usual, I appreciate your focused and informative answers to my questions.
Thank you,
paul
October 22, 2014 at 9:44 pm #81681
Re: Brake Pads for the original Shaft Lock
Author:
http://www.mfgsupply.com/gomini/gominibrakes/gominibrakesdisc/4-489.html
These are the pads I used. Â They required drilling but have worked fine for my limited use. Â They are a very close match to the ones that came out. Â
Hope this helps
LinusÂ
Sumocean
Reply Link:_______________________________________________
October 22, 2014 at 10:24 pm #81682
Thanks Linus,
Those are the same ones that Rich recommended. But I can’t figure out how they would attached to my Shaft Brake. I have “car-like” pads that are rectangular or oblong.Maybe mine is just very different.
P
Author:
These are the pads I used. They required drilling but have worked fine for my limited use. They are a very close match to the ones that came out.
Hope this helps
Sumocean
October 22, 2014 at 11:01 pm #81683
Wow, mine are nothing like those. The ones on my brake are rectangular. I ended up getting a sheet of rigid brake pad material from McMaster Carr and cutting a few to size. I guess they used a variety of brakes over the years.
