Forums › General Discussion › Broken mizzen sheet taffrail tang
Viewing 18 reply threads
    • #68173
      After some aggressive sailing off of Diamond Head, the tang that holds the mizzen sheet block on the taff rail managed to part. I guess its just old and stressed metal.
      Has anyone else had this problem and how did you meet the challenge?
      Lady Leanne II (#135)
      Honolulu/Atlanta
    • #76239
      Dan,
      Hasn’t happened to me – yet, but I can think of several options short of
      having a tang re-welded to the rail.
      1. You can replace the tang with one that mechanically fastens to the rail.
      I use a couple for the lead blocks on my Monitor control lines. I thought I
      purchased them from MarinePartsDepot, but I can’t find it in their online
      catalogue. I’ll send a pic if you are interested.
      2. Put a padeye on the rear coaming.
      and stressed metal.
      Honolulu/Atlanta
    • #76240
      Dan,
      Assuming the rail tubing is sound and the tang parted at the weld, why not
      just have the tank welded back on? After all, the first weld held for 30
      years.
      SilverHeels, P-424 #17
    • #76241
      Tor: Interestingly, the weld on the tang held. It snapped in half horizontally across the hole. I filed down the rough edges for obvious reasons.
      I kind of like the idea of a pad eye on the rear coming if I can keep it out of the way.
      Honolulu/Atlanta
    • #76242
      On a different yet related subject.
      Last winter I had Mack Sails pull my mast and boom and refurbish them – new
      paint, lines, rivets, winches, sheaves, etc.
      The folks from Mack reported that several of the tangs on the top of the mast
      were beginning to fail.
      lee
    • #76243
      Dan,
      A pad eye on the combing (with a backing plate) could work, but first I’d
      rig a length of line from that point to the sheet block bale on the boom and
      check the line’s run with the mizzen boomed all the way out to port and
      starboard. Seems like the sheet will lay hard across the pushpit railing
      when you’re reaching, snagging anything you have mounted there.
    • #76244
      Tor: Definitely don’t want to get tangled up in my underwear. I’ll certainly check the play on all before I get out the drill!.
      Honolulu/Atlanta
    • #76245
      Lee: Curious as to how many boat units the spars refurbishing cost. Can you give a directional?
      I guess I’m approaching that costly line in the sand when you’re done fixing existing problems and move to fixing anticipated ones as we get Lady Leanne ready for some extended offshore work.
      Honolulu/Atlanta
    • #76246
      If there is enough meat there you could bolt on a new eye to the nub.
      reasons.
      out of the way.
      Honolulu/Atlanta
    • #76247
      True, you could bold on new tang to the stub of the old one, but I believe
      welding would be stronger. Quicker, too, compared to boring through
      3/16″-inch stainless steel with a hand-held drill, twice.
    • #76248
      This may sound crazy. I have been lookin at reworking the mizzen sheet assembly with a traveler / sheet system. I have noticed alot of lift and twist in the mizzen boom. I have been looking at a basic unit from Garhauer.
      http://garhauermarine.com/catalog_process.cfm?cid=34
      I think the mt-3 would work…
      Eric Lorentzon
      Navasana
    • #76249
      Dan,
      Since you are at a point where you can replace the existing rig or re-work
      it, here are my suggested solutions.
      1. Grind off the broken tang and weld a replacement
      2. Grind off the broken tang and replace with a mechanically attached
      tang (one of my previous suggestions). This is probably stronger than the
      welded tang (IMO)
      3. Replace the sheeting of mizzen to either of the solutions above with a
      3:1 tackle. This frees up the mizzen sheet winch for a more useful use
      (even a 98 Lb weakling can handle the mizzen sheet without a winch.
      4. Do 3, above, but attach the tackle to a padeye on the coaming. This
      provides better leverage on the cam cleat on the tackle.
      I still have the welded tang, but I went with a 3:1 Tackle on mizzen and no
      longer use the winch for the sheet.
      http://www.svsarah.com/Sarah/ewUpgradeDeckRig.htm#Running_Rigging_-_Mizzen_Mast
      Eric Lorentzon
      Navasana
      believe
    • #76250
      Yesterday a fellow on the adjacent dock told me we are no longer required to
      have a ship’s bell.
      Is this true? If so what, if any thing, replaces the bell?
      Lee
    • #76251
      http://www.usps.org/national/vsc/conductvsc_files/USCGMinReq.pdf
      <http://www.usps.org/national/vsc/conductvsc_files/USCGMinReq.pdf>-p
      to
      have a ship’s bell.
      Lee
    • #76252
      Well, there you have it. No bell. But if you did have one, it should be an
      8″ bell, not a 6″ one (that was the requirement for our size vessel).
      Having sailed in some serious fog, though, I can tell you I’ve never heard a
      ship’s bell. Air horns, breath powered or electronic horns, etc., etc. but
      never bells. I’ve often wondered about that as they sound too similar to
      buoys. But I guess, before modern sound making technology there were only
      bells.
      I like my Standard radio that does all the sound making for me.
      It’s nice to know the USCG is keeping up.
    • #76253
      Good link. Thanks.
      Does the following mean that flares are no longer required if you have a
      flag and a night signaling device?
      *Minimum of three day-use and three night-use or three day/night
      combination pyrotechnic devices. Non-pyrotechnic substitutes: 1 orange
      flag (day-use) and 1 electric S-O-S signal light (night-use)*
      to
      have a ship’s bell.
      Lee
    • #76254
      That’s the way I read it although it’s inland rules. To be honest, I carry
      both the flares and flag. The SOS light better be a pretty powerful,
      self-contained unit if you’re in trouble.
      Remember, the USCG is minimum requirements. I carry the SOLAS flare set.
      On Tue, Nov 16, 2010 at 9:55 AM, Pete Dubler <> wrote:
      Good link. Thanks.
      combination pyrotechnic devices. Non-pyrotechnic substitutes: 1 orange flag
      to
      have a ship’s bell.
      Lee
    • #76261
      Dan, I am so sorry to be so late in responding to your question.
      I dug out my records and this is what Mack Sails charged:
      1. Pull and prep mast: $1,700
      2. Paint spars: $4,000
      3. Upper tangs replaced: $250
      What the invoice doesn’t list was all of the small and not so small things they
      did to make the job top notch. The paint job is incredible.
      Lee
    • #76262
      I can vouch for that!
      I’m not being short. This is from my mobile.
      they
      Lee
