Forums › General Discussion › Broken mizzen traveler tang
- This topic has 6 replies, 4 voices, and was last updated 16 years, 4 months ago by
kalinowski.
June 11, 2010 at 7:37 am #68043
ParticipantPushing the envelope with Lady Leanne off Diamond Head with just jig and jigger. Damned if the mizzen traveller tang didn’t part. I guess the SS is just old. Has anyone else had this problem? How did you approach repair? I only want to pull the taff rail as a last resort for welding.
Lady Leanne II
Honolulu -
June 11, 2010 at 12:23 pm #75574
ModeratorHi Dan,
I think you can have that welded on the boat as is. But I have another idea
which I am taking from Jack and Pat’s “Whoosh”.I’ve given a great deal of thought on how to control the mizzen better. On
Whoosh, they have rigged blocks and tackles on either side of the main boom
for sail control and as preventers. It alleviates the need for a traveler
and boom vang. It also locks the boom in place.The mizzen twists too much off the wind with the one point of attachment.
There’s no vang or provision for same.What would happen, then, if you added a new pad eye at the aft corners of
the cockpit and had tackles like the running backs to the bale on the mizzen
boom? You could use them to shape the sail any way you wanted. It would
also allow you to prevent gybes.True, that’s some more line in the cockpit, but it might be worth it.
I only want to pull the taff rail as a last resort for welding.Dan Kalinowski
Lady Leanne II
Honolulu_______________________________________________
June 11, 2010 at 12:33 pm #75575
RichCarterParticipantDan
I assume that you mean the tang welded to the pushpit for the mizzen sheet?Rich
June 11, 2010 at 7:08 pm #75576
ParticipantGreat idea Bob! Thanks for making me see outside the box. I’ll trot down to West today and begin to sort it out.
Lady Leanne II (#135)
Honolulu -
June 11, 2010 at 7:12 pm #75577
ParticipantRich: Yup, that be the one.
Honolulu -
June 11, 2010 at 7:30 pm #75578
SpectatorIf you use a fiddle with a snap shackle on it you could use a webbing loop,
or one of those Ronstan Dyneema Links, or even a big locking carabiner (that
would scratch the stern pulpit pipe) attached around the stern pulpit where
that supportive inverted “V” is located. That would also allow you to sheet
from other places (like the eyepads for the running backs).The main idea of using the snap shackle is one I copied from s/v Sarah.
http://www.svsarah.com/Sarah/ewUpgradeDeckRig.htm#Running_Rigging_-_Mizzen_Mast<http://www.svsarah.com/Sarah/ewUpgradeDeckRig.htm#Running_Rigging_-_Mizzen_Mast>My
setup: http://www.flickr.com/photos/deepplaya/3675983302/sizes/l/-p
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comOn Fri, Jun 11, 2010 at 12:37 AM, kalinowski <>wrote:
Lady Leanne II
June 12, 2010 at 6:35 am #75579
ParticipantFYI all: The SS tang broke in half through the eyehole. The weld is still strong.
Lady Leanne II #135
Honolulu
