Forums › General Discussion › bronze antifouling
- This topic has 17 replies, 5 voices, and was last updated 17 years, 6 months ago by
madsailor.
April 8, 2009 at 12:21 pm #67454
ParticipantOnce again I am in search of knowledge, if not wisdom. What seems to be the most effective antifouling system
on the bronze shaft, strut & prop? Anyone?If copper-based paints are so destructive on bronze underwater, why do painted seacock flanges survive as well
as they do?I’m thinking of painting Silver Heels’ underwater bronze with West System epoxy as a barrier, then using
ordinary copper-based antifouling over that. Good idea? Bad idea? In the vernacular of the New York Yacht
Club, wassup?Tor
April 8, 2009 at 12:32 pm #72410
ModeratorHi Tor,
Copper based paint and bronze are no problem at all. Copper and aluminum is, however, extremely corrosive. Bronze, after all, is an alloy of copper, tin, and other metals for different uses. But primarily, copper and tin. So, paint away with no worries. (Brass is copper and zinc, a very different and very useless underwater alloy).
For the strut, I paint with bottom paint. If the shaft is bronze (mine's stainless or monel) you could paint it everywhere except where the zincs will go. That must be clean.
For the prop, you could paint it but the paint will wear off in no time unless you use a hard, non-ablative paint. Here's what I do:
1. Clean and smooth the prop – not polish, but pretty smooth
2. Using something like lithium grease or STP (yup, the oil that fixes everything in engines), wipe on liberally. Give it all a good coat. Rub it in.
3. You're done. For some reason sea life doesn't like either of these greases. I think molybdenum sulfide grease will work, too. But the oil/grease gets in the pores of the metal and really hangs in there. I may try teflon grease for speed, though, and it can be applied later in the season in the water.You could also use the zinc propeller and shaft paint in the spray can to coat these things as well. It does work but doesn't last the season.
as they do?I'm thinking of painting Silver Heels' underwater bronze with West System epoxy as a barrier, then using
Club, wassup?Tor
April 8, 2009 at 12:50 pm #72411
john stevensonParticipantI haven't painted a prop since they took the tin-based paints off the market. For a while you good get Tri-Lux in small cans, then it became Tri-Lux II and was worthless.
Since then I just clean the prop to a bright finish and then dive on it every few months with a scraper.On Wed, Apr 8, 2009 at 8:31 AM, Robert Fine < ([email][/email])> wrote:
Hi Tor,
Club, wassup?Tor
Hull #8—
April 8, 2009 at 12:53 pm #72412
ModeratorOf course that works, too. I just purchased a wetsuit for cleaning mine in 40-65 degree water…
Hi Tor,
Club, wassup?Tor
Hull #8—
http://www.svsarah.com—
April 8, 2009 at 1:03 pm #72413
john stevensonParticipantFortunately for me it only involves moving the boat to a small cove and diving in crystal clear 80 degree water. Then drag to dinghy onto the beach and clean the green scum off its bottom.
Hi Tor,
Club, wassup?Tor
Hull #8—
Hull #8—
April 8, 2009 at 2:10 pm #72415
ParticipantI thought copper would set up an electrolytic current with bronze. Glad to hear I was mistaken. (And that explains why painted seacock flanges survive as well as they do with bottom paint on them.) In the past I’ve generally done as John does, i.e., leave the drive train plain and dive on it once in a while.
Bob, I am amazed that those products you listed will stick to a prop for long. I think I’ll try your system: bottom paint on the strut & shaft, and lithium grease on the prop. Thanks!
April 8, 2009 at 3:10 pm #72417
Syringa
ParticipantTor
Here is a link to prop speed http://www.propspeedusa.com/index.htm the cost is about $350 per prop/shaft. It seems to work in Puget Sound (but I have only seen it a few times) If feels like slick rubber and produces a surface that does not allow marine growth to permanently attachit.
April 8, 2009 at 4:11 pm #72418
ParticipantThanks, Don. Will wonders never cease!
April 8, 2009 at 4:16 pm #72420
RichCarterParticipantI paint my running gear with outdrive paint each season. Its sold in a
small spray can at most marine outlets. I think its tin based.Regards
BlackSheep #47Quote:
April 8, 2009 at 4:22 pm #72422
ModeratorHi Tor,
I don't know why they stick either except to say that the lubricants are designed to 'bond' with metal so they can perform their lubrication duties. Or, it could be magic.
On Wed, Apr 8, 2009 at 10:09 AM, Silver Heels < ([email][/email])> wrote:
Quote:I thought copper would set up an electrolytic current with bronze. Glad to hear I was mistaken. (And that explains why painted seacock flanges survive as well as they do with bottom paint on them.) In the past I've generally done as John does, i.e., leave the drive train plain and dive on it once in a while.
Bob, I am amazed that those products you listed will stick to a prop for long. I think I'll try your system: bottom paint on the strut & shaft, and lithium grease on the prop. Thanks!
April 8, 2009 at 4:39 pm #72423
ParticipantRich,
Why don’t you just use copper bottom paint?
April 8, 2009 at 4:40 pm #72424
ParticipantBob,
Magic, definitely. How long does lithium grease remain effective on the prop?
April 8, 2009 at 8:12 pm #72427
ModeratorCouple of months, anyway, depending on use…
On 4/8/09, Silver Heels <> wrote:
Quote:Bob,Magic, definitely. How long does lithium grease remain effective on the
prop?Tor
April 8, 2009 at 9:05 pm #72428
ParticipantAnd then you re-apply it underwater?
April 8, 2009 at 9:11 pm #72431
ModeratorOddly, I've never reapplied it as I generally dive the prop every couple of weeks since I'm in the water anyway to clean the waterline…
April 9, 2009 at 2:06 am #72437
RichCarterParticipantI like the finish the spray-on paint provides better. It seems to work OK. I still get a few barnicles on the shaft but they don’t stick well. My shaft and prop are both stainless. I polish them with a rotary scotch-brite pad on a drill and then spray on a clean coat each spring.
April 9, 2009 at 12:06 pm #72440
ParticipantUnderstood. I’m looking for longevity, hoping to go as long as possible between haul-outs. Bob’s grease trick may provide that by allowing repeated applications underwater. Or perhaps it’s possible to do both, starting out with a spray-on paint and then applying lithium or one of the other lubricants when the paint starts losing its effectiveness. My prop is being re-pitched today and will come back professionally polished, a good time to spray it.
Thanks for the feedback.
April 9, 2009 at 12:45 pm #72443
ModeratorPerfect! The best time to apply said treatments!
2009/4/9 Silver Heels < ([email][/email])>
Quote:Understood. I'm looking for longevity, hoping to go as long as possible between haul-outs. Bob's grease trick may provide that by allowing repeated applications underwater. Or perhaps it's possible to do both, starting out with a spray-on paint and then applying lithium or one of the other lubricants when the paint starts losing its effectiveness. My prop is being re-pitched today and will come back professionally polished, a good time to spray it.
