Forums › General Discussion › butyl tape for hatches and portlights
- This topic has 22 replies, 2 voices, and was last updated 12 years, 3 months ago by
July 14, 2014 at 7:18 pm #68957
I’m replacing the small opening deck hatch over the galley. The original Bomar is getting old and needs replacement. I found what looks like an ideal replacement at defender on clearance and ordered one today. It should arrive tomorrow or Wednesday.
http://www.defender.com/product3.jsp?path=-1|619045|1970800&id=2508857I doubt that the screw holes will match, but I think the frame size makes this otherwise a drop-in. I’ll let folks know after I complete the task.
I need to use a bedding compound to seal the hatch. Pearson used silicone sealant which is difficult to remove from the deck. I am considering butyl tape but wonder if the seam that I’ll need will leak. I think not, but figured that I’d ask those who use it.
I found a source for tape but it’s a bit expensive and I’ll have to wait for the shipment to arrive. Does anyone have a good source for similar?
http://www.pbase.com/mainecruising/butyl_tapeRich
July 14, 2014 at 7:49 pm #81290
I’ve used Rope Caulk from Lowes or Home Depot after Tor identified it.
Since then I’ve only used the Butyl tape from the site in your port. It’s
not a major expense and it helps support a really useful website.
13 years ago I replaced that Bomar hatch with a Lewmar size 40 Ocean Hatch,
which was a drop-in replacement (other than the screw holes and a little
sanding of frame corners). I can’t believe how expensive those hatches are
now even at the Defender price.Regards,
Sarah’s BlogOn Mon, Jul 14, 2014 at 3:18 PM, re.carter— via maillist <
> wrote:I’m replacing the small opening deck hatch over the galley. The original
this otherwise a drop-in. I’ll let folks know after I complete the task.I need to use a bedding compound to seal the hatch. Pearson used silicone
figured that I’d ask those who use it.I found a source for tape but it’s a bit expensive and I’ll have to wait
July 14, 2014 at 7:58 pm #81291
We were going to replace our deck hatches with newer Bomar also, even
bought a $1000.00 worth similar to what your buying but when I got them
next to the old ones I thought these old ones are of such a higher quality
they deserve a thorough rebuild. Brought back three of the other hatches,
kept the little guy 9 1/2″ above the aft cabin.I plan on using Dow Corning 795. Great stuff! I’ve used many times to
replace modern fixed ports where the bedding stays exposed to the sun.
Black, white, grey. I’ll use it to rebed the new acrylic in my old hatches
and I’ll use it to bed the hatch to the deck. I can’t tell you enough how
good a product this is and it’s awesome to work with. It comes out of the
tube easily with little or no mess and it’s easily worked with fingers,
putty knives, etc. It is a silicone based product so good masking is
crucial to a professional job.I also really like working with butyl rubber for your application but I’d
want a fatter roll of butyl to work with. New Found Metals in Washington I
believe sell rolls of 1/2″ tube shape. I used it to install their SS
opening ports. The owner of the boat was able to order it from them. Not
sure of cost or length but it too was awesome to work with. Clean and
simple.
Have fun,
KenOn Mon, Jul 14, 2014 at 3:18 PM, re.carter— via maillist <
July 14, 2014 at 8:49 pm #81292
The thick black round butyl that New Found Metals sells for bedding
their ports is excellent. The key is in the installation technique they
suggest which involves wrapping the port in the tape before sliding in
the hole and packing the tape in firmly with more added as needed.Pete
July 14, 2014 at 8:52 pm #81293
We replaced all the overhead hatches on Bel Esprit this year. I bought thmn on eBay for a third of the price and they were brand new.
Elaine Patton
On Monday, July 14, 2014 3:59 PM, Ken Page via maillist wrote:
simple.
Have fun,
July 14, 2014 at 9:31 pm #81294
I’m still a rope caulk fan for most applications above
the waterline, but that butyl looks very good and I’ve
heard good comments about it in general. The one place
I used rope caulk that regret was re-bedding the
Plexiglas panels in my (original) deck hatches. Rope
caulk is not adhesive enough or expansive enough and
anyway it doesn’t stand up well to direct sunlight &
weather. Those seams leak now a little from time to
time and I have to kind of smush in a little more fresh
rope caulk to re-seal it. Only takes a few minutes, but
I’m sure there are better products for that
application. For bedding the hatch frames, however, I
would feel confident using rope caulk. Of course, a lot
of people might feel better using a more “advanced”
product there which is fine. Personally, though, I
avoid using silicone on my boat because it’s so awkward
to remove later on.Bottom line, I’d say go with the butyl tape.
July 14, 2014 at 11:30 pm #81295
Tor,
I have a hate relationship with silicone myself….It’s only good for windows and certainly never, ever, damn you to hell should you ever use it on a wooden boat. Gawd almighty who EVER invented ANYTHING that sprays silicone in the whereabouts of putting a finish on wood should be hung from the highest t r e e e e …nobody should ever weep for thee. do do do do do do …do…do…doooooo.Dow Corning 795…..will turn you around as it did me. $11 bucks a tube…a tube a hatch….economically worth EVERY dime. Just saying!
July 14, 2014 at 11:53 pm #81296
Ken, I’m sure you are right about Dow Corning 795. It
is one of a hundred available goops I have yet to try.
Regarding silicone spray, however, I just encountered a
potentially useful application, i.e., coating rubber
parts inside pumps, or any rubber in general that might
benefit from a protective sealant. Just sayin’.Tor
July 15, 2014 at 12:15 am #81297
Silicone spray has uses on a boat. Silicon sealant does not except putting
a dab on the ends of the cotter pins on the rigging fittings.Silicone sealant is a guarantee that there will be not only a leak but a
leak that actually pumps water through whatever it’s sealing. Silicone is
a compressive seal and almost never used that way. There are many better
and easier to use sealants. Silicone used casually is a disaster.Bob
On Mon, Jul 14, 2014 at 7:52 PM, Silverheels via maillist <
> wrote:Quote:Ken, I’m sure you are right about Dow Corning 795. It
July 15, 2014 at 12:43 am #81298
Bob, why then have all the through hulls of my boat and all the hatches on the deck of my boat which were bedded in state of the art silicone of the day 1980 never leak? 795 is a silicone ‘based’ product. There have been some improvements. Like I said…I really hate pure silicone my previous owner has left gobs of it (Pearson too) for me to remove.
I mention spray silicone from a past nightmare of trying to varnish in the vicinity of someone using it. One single molecule of the shit makes fish eyes in any finish. -
July 15, 2014 at 1:11 am #81299
All my through hulls (1978) were something like 5200. Not sure what. Most
old boats I worked on are the same stuff. I suspect your through hulls
were rebedded at some point.795 is not pure silicone – and it’s not a good bedding compound for
anything except plastics and glass – I use it for the inserts for hatches
and windows. It is a glazing compound used for buildings and is not for
bedding anything to the deck or below the water.Spray silicone will cause all sorts of problems with any kind of finish,
not just varnish. Teflon spray is a much better substitute. Even graphite
spray is better.Pure silicone will form capillary tubes – it seals for a bit and then will
pull from the substrate and actually pump water. It’s a disaster because
it’s so hard to remove completely requiring either mechanical removal or
the use of xylene, a very nasty chemical. There is a proper way to use
silicone but almost no one ever does it because it takes two days to do it
properly. It will form a proper compressive seal, but not a general just
bolt it on and go seal like 5200 or even 4000.Ken, you’re welcome to use whatever you want. I’m just saying that
silicone will cause more grief than it’s worth. There are better sealants,
adhesives, and caulks for marine use.Bob
On Mon, Jul 14, 2014 at 8:43 PM, Page Two via maillist <
> wrote:Bob, why then have all the through hulls of my boat and all the hatches
July 15, 2014 at 1:34 am #81300
Pearson bedded everything with silicon, one of the reasons the main cabin companion-way typically leaks. Once it gets on the surface of something it’s almost impossible to remove and nothing seems to stick to it; stuff should be outlawed. My coach trim (eyebrows) is bedded with the stuff. I’ve been chasing leaks in the cabin sides for almost 30 years. If your main cabin companion-way leaks in the rain, consider rebuilding it before the deck rot gets too bad.
http://www.richardcarter.net/boat/deckRot/Rich
July 15, 2014 at 2:03 am #81301
Bob, I ‘assumed’ the silicone on my through hulls was original (and on this I could be very wrong) there is a look and feel about removing something that you know if its been screwed with and these through hulls looked, OH so original in ‘my’ book, but as I took off the hatch on deck and found the same stuff there with absolutely no sign of any other bedding or residue left over, again it seemed to confirm it to me. I just can’t believe that all these hatches were re-bedded too. Not many PO’s go that far. I most certainly could be wrong but my gut and years of pulling apart boats tell me otherwise.
I would certainly never use 795 under the water and the only times I have used it was for glass, plexi and the like for ports on boats where there is a lot of temperature change between parts. Saber Boats of Maine have been using it exclusively for all their fixed ports on the cabin sides. A lot of it remains exposed to UV.
My thoughts of using it for the hatch to deck joint is purely laziness, as I’ll be using it to set the new acrylic into the aluminum casting and having used the product before I feel it will be absolutely fine for the aluminum frame to glass deck as it adheres to both just fine. Of course both surfaces will be thoroughly cleaned for the installation. None of it will be exposed. I’m figuring 1 1/2 tubes per hatch.I would use butyl too… or 4200… Sikaflex…or life caulk…etc.
Ken -
July 15, 2014 at 2:15 am #81302
But silicone spray is, I understand, an excellent
lubricant/sealant/protection for rubber. I’ve been
using Dow 111 (a grease-like gel, not a spray) on
rubber parts for years, originally recommended by an
engineer at Groco when I called and asked with what to
lubricate the rubber cores in their thru-hulls.
O-rings, gaskets, seals, rubber valves, pump
diaphragms, and so on all get a film coating whenever I
have them in hand. So far, so good. And my fingers have
lasted to date, as well. Good stuff.Tor
July 15, 2014 at 9:52 am #81303
Silkaflex (which one) or Lifecaulk?
And why??
Sent from my iPhoneOn Jul 14, 2014, at 9:11 PM, Robert Fine via maillist wrote:
July 15, 2014 at 11:37 am #81304
BoatLIFE Life Caulk is a halfway decent all around bedding compound. It’s a polysulfide and I’d give it a fair rating. Somewhat inexpensive.
Skiaflex 291 is a polyurethane (similar to 3M5200) but with less tenacity to keep things together forever. It’s more like 3M4200. I used Sikaflex 291 on all my through hulls. https://www.youtube.com/watch?v=_TQgh82QM7Q
Have fun.
July 15, 2014 at 12:21 pm #81305
And yet another consideration for these products is
shelf life. I’ve had many tubes of 5200 and 4200 cure
in their tubes, even when never opened. Perhaps
refrigerating them would help? (I so know that Bob will
know this.) Also, I don’t buy any goops in long gun
tubes unless I’m planning a job big enough to use it
all at once. I’ve thrown away a lot of half-tubes of
the gun type over the years, and had to store them
meanwhile. I’d rather pay more for several small
toothpaste-type tubes with caps.Oh, the trials and tribulations…
July 15, 2014 at 12:53 pm #81306
This is very true especially with 5200 and Life caulk.
I am having excellent results with DC795 and 291 even with the tubes opened. I had some 795 last in the opened tube almost a year. I usually use a long #12 or bigger screw into the nozzle. Presently I’m finding a length of #8 green wire stuffed in the nozzle working excellent for both products.@Silverheels via maillist wrote:
July 16, 2014 at 11:07 pm #81307
Tor, I was just reading up on that Dow Corning 111….
I think that’s a …Must Have. Thanks!In my very limited past of things of that category, lubricating etc, all I ever used was regular Vaseline (sail slides etc.) A tub of old wheel bearing grease, in moderation of course(gooey grease, HOW can it not work?).
July 16, 2014 at 11:12 pm #81308
Vaseline has its uses on board, Ken, but my
understanding is that any petroleum product (including
Vaseline petroleum jelly) will degrade rubber over
time. Best to keep it off your rubber parts entirely.
Silicone, on the other hand, which is the main
ingredient in Dow 111, will not harm rubber.Tor
July 16, 2014 at 11:30 pm #81309
Tor,
Yea, I’m aware of Vaselines limitations, I used it mostly on the main sail
slides and bronze hanks pretty regularly and no doubt used it where I
shouldn’t have but hell, I’m still alive and all three of my past wooden
boats are still floating.Ken
On Wed, Jul 16, 2014 at 7:11 PM, Silverheels via maillist <
> wrote:Quote:Vaseline has its uses on board, Ken, but my
July 17, 2014 at 12:16 am #81310
Still alive & floating is good, Ken. I find Vaseline works well if only temporarily to lubricate snaps on the boat. Bit by bit I discover, which is to say am shown by other sailors, better alternatives for various applications. One of my favorites is dry graphite on the sail tracks, main and mizzen. I believe Rich mentioned it the other day. Just before each long passage I go aloft – the mizzen mast in a bosun’s chair, the main via the stirrup steps – and work my way down spraying a line of the stuff directly onto the masts’ inset sail car tracks. Amazing what a difference it makes!
July 17, 2014 at 12:18 am #81317
Forgot the illustration.
