Forums › General Discussion › Changing the fuel filter
Viewing 10 reply threads
    • #67445
      I successfully changed my RACOR filter. That was pretty easy and I didn’t make a huge mess thanks to a couple of stainless steel hot food service bins I used as a catch.
      When I pull the primary fuel filter (the one on the engine) will a lot of fuel spill out (assuming the petcock before my RACOR is closed) and will I need to be prepared to bleed the fuel lines afterwards.
      I just want to get a feel for what I’m starting before I start it.
    • #72343
      Hi Pat,
      When I changed the one on the engine, I placed a big plastic cup under it and some of that absorbent stuff below that – if you're careful, you won't spill much – very little.
      I'm wondering if anyone with a W58 has ever changed the filter in the lift pump.  The electric pump has an integral filter.  I know because I have replacement cartridges from Westerbeke just for that.
      Hull #8
    • #72344
      Is there one? Just got e8012s Mexican bomba de fuel to make bleeding
      easier and to split to heater in bulkhead. Dirty filter would explain
      long lag in filling stroke.
      -Adam Silverstein-iPhone
      (“trust everyone but cut the cards”)
      On Apr 2, 2009, at 8:27 AM, Robert Fine <> wrote:
      Hi Pat,
      under it and some of that absorbent stuff below that – if you’re
      careful, you won’t spill much – very little.
      I’m wondering if anyone with a W58 has ever changed the filter in
      Hull #8
    • #72346
      Pat
      It depends on your engine.
      Slip a zip-lock bag with paper towels in the bottom over the fuel filter before removal. This will catch most of whatever spills.
      With my old W60 which was a bear to bleed, I found that if I could avoid getting air into the high pressure pump, changing filters was pretty easy. I would first crack a bleed screw on the top of the filter and fill that until fuel spilled out, then close that. Then crack the fuel input line on the high pressure pump and continue bleeding until bubbles stopped coming out. Then close that. If done right, the engine would start right up. Bleeding was done with an electric fuel pump I put in series with the mechanical lift pump. You can do it with the mechanical pump but its tedious.
      Hope this helps
    • #72348
      The W58 has an electric pump (with filter inside) and the bleed screw is at the top aft inboard side of the filter housing.  It takes about 15 seconds to bleed, but have some absorbents ready.
      On Thu, Apr 2, 2009 at 11:31 AM, < ([email][/email])> wrote:
      Pat
      Hope this helps
    • #72349
      Patrick,
      I find a pllastic container a little bigger than the filter and squeeze it under the filter before removing it.. Also wrap an oil absorbing pad around and under the area or the filter before removing it.
      Norris Larson, Easy Reach, #203.
      — On Thu, 4/2/09, Patrick Walters <> wrote:
    • #72358
      Sailinrj
      Changing the fuel filter on the pump was not a big deal. I changed it several years ago without much trouble. There is a hand pump on the pump for priming the filter and with the electric fuel pump does a good job of taking care of the air in the filter.
      Really didn’t make that big a mess.
      Rudy
      P-424 #197
      New Low Prices on Dell Laptops – Starting at $399 (http://pr.atwola.com/promoclk/100126575x1220433304x1201394525/aol?redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B213540718%3B35046385%3Be)
    • #72359
      I was looking at the parts manual and I don’t see that filter listed. Do you happen to have a part number for it I could search for?
    • #72361
      Not all W58s have this electric pump. (Mine for example does not)
      > wrote:
      Pat
      its tedious.
      Hope this helps
    • #72363
      I’ll have to crawl around on Sunday and check for that. I’m not sure if I have one either.
    • #72364
      Sailinrj
      The question on the fuel filter number, the number I have for the Westerbeke part # 24363 and the Fram replacement P3726.
      I hope that helps.
      Rudy Janis
      #197
      Hurry! April 15th is almost here. File your Federal taxes FREE with TaxACT. (http://pr.atwola.com/promoclk/100126575x1220714320x1201367638/aol?redir=http:%2F%2Fwww.taxact.com%2F08tax.asp%3Fsc%3D084102950001%26p%3D82)
