Forums › General Discussion › Clean Freshwater
Viewing 2 reply threads
    • #68538
      Hell, John, that ain’t nothin’. When Silverheels’ PO left this boat with
      the yacht broker to sell, he also (slob that he was) left enough water
      in the tanks to stagnate and grow a small rainforest. It was gross! One
      of the very first things I did when I bought the boat was to scour those
      tanks with bleach and long-handled scrubbers – top, bottom and sides –
      and then do it again and again until the gel coat was virgin white. I’ve
      kept the tanks that way ever since. But you definitely need 3 opening
      ports per tank top to do that because they’re baffled into 3 sections.
      I also replaced all the tank hoses and added in T-fittings between the
      tanks and the manifold so I can drain them into the bilge sump, for
      emptying when storing the boat and for general cleaning and rinsing.
      When I store the boat over the summer, the tanks are freshly washed and
      thoroughly dried, so nothing grows in there. When I refill them in the
      fall they’re clean as new.
      I guess you can tell I’m really into clean freshwater. Once I had gotten
      the tanks cleaned the first time, I installed a large, generic sediment
      pre-filter that ALL my freshwater passes through right after the tank
      selection manifold under the galley sinks. I also installed a secondary
      Home Depot double-water-filter system at the galley sink. I use the
      purified water from that spigot for drinking, cooking, ice-cube trays,
      etc. I believe it’s as good as or better than what you buy in jugs from
      the supermarket, and a whole lot cheaper than Perrier.
    • #78417
      Patrick,
      It may be useful to plumb the big sediment filter before the freshwater
      pump (rather than after it), to remove grit particles before they enter
      the pump. Also, this way a T-fitting enables the same filter to serve
      the foot pump.
      Similarly, you’ll double the usefulness of the foot pump by installing a
      Y-valve on the intake. One setting pulls freshwater from the clean side
      of the sediment filter, same as the electric pump does (one filter
      serves both pumps). The other foot pump Y-valve setting draws seawater
      from the after side of a raw water sea strainer. Most cruisers use
      seawater from the foot pump for washing dishes offshore and in clean
      anchorages. I do, but as long as I have a working watermaker I often
      then give dishes & utensils a light, final rinse with a little
      freshwater to remove the sea salt.
      I only set up the foot pump with a freshwater option as a back-up, in
      case the electric pump fails – even though I carry a new, spare electric
      water pump since I cruise in foreign waters.
    • #78419
      Silverheels’ water tanks are gel-coated fiberglass, not aluminum.
