Forums › General Discussion › Clunky Engine Doghouse
Viewing 18 reply threads
    • #67764
      I am tired of wrestling with the original clunky engine doghouse in the aft cabin. It’s just to ungainly for the aft cabin, especially underway. It’s easy to bang up the woodwork and you have to get a sheet to cover the aft bunk before setting it down. Let alone dealing with the companionway ladder.
      Has anyone develope a way to build the doghouse in sections? Thought I’d ask before reinventing the wheel.
      Lady Leanne II (#135)
      Honolulu
    • #74163
      Hi Dan,
      Someone, I forget who, made the box collapsible – or so that it could be taken apart easily.  I think they used those pull-apart hinges.
      I agree with you – and especially when I put new sound insulation on the thing, it will weigh a ton.
    • #74164
      Here is what did to re-build my box.  I used thumb screws and threaded inserts to hold the sides together.
      http://www.svsarah.com/Sarah/ewEngineBox.htm
      On Sun, Nov 1, 2009 at 8:11 AM, Robert Fine < ([email][/email])> wrote:
      Hi Dan,
    • #74165
      Thanks for the tips. The idea of break apart hinges seems to be the best approach as I am not resizing the doghouse.
      I have resurfaced the doghouse with marine carpeting, using chrome finished metal edging strips from Home Depot for all of the box edges. As we all know, the box gets really chewed up over the years and this approach was visually pleasing, easy and prevents future scarring.
      I think I will mount two of the break apart hinges on each of the joints of the three box pieces so that the front will lift off. Aft inside cleats will hopefully keep the sides from falling over till I can deal with them during the removal process.
      Honolulu
    • #74166
      Syringa
      Thanks for the info! I like the look of you engine compartment (nice job). I was looking at re-doing my sound proofing and like the look of your tiles. Is the tiles glue still holding up will?
    • #74167
      Don,
      Yes the glue is still holding up – only been a little over a year though.  If it ever does start to loosen I can always go to mechanical fasteners.
      Don Gardner
      S/V Syringa #124
    • #74200
      reluctant
      Seperate the three vertical pieces of the doghouse (they were originally screwed together) and use draw latches to hold the sides to the front piece.
      Then you can access the engine without removing the top and all if it’s accumulated treasures by removing the ladder, unhooking the latches and pulling the front vertical piece out. Great for checking the trans and engine oil before starting the engine.
      http://www.mcmaster.com/#draw-latches/=4dejzf
    • #74202
      Wow! The best place to hide something is out in the open. I never thought of draw latches. This solves the problem and gives the easy access…………..checking the fluids was always a pain in the stern.
      Honolulu
    • #74204
      Or even these:
      http://www.marinepartdepot.com/dring.html
      Then you can access the engine without removing the top and all if it's accumulated treasures by removing the ladder, unhooking the latches and pulling the front vertical piece out. Great for checking the trans and engine oil before starting the engine.
    • #74211
      Sea Duty; thumb screws into threaded inserts holding the three panels together at the front with the draw latches holding the whole doghouse to the bulkhead.  I find sliding the entire dog house forward easy enough for a overall check.  Only if I'm doing extended work will I break down the three panels, making it easy to store.
      On Thu, Nov 5, 2009 at 4:50 PM, Robert Fine < ([email][/email])> wrote:
      Or even these:
    • #74221
      I read Rich’s and Jack’s pages on their repowering projects. Any other
      advice out there on pulling the W-58 engine out (and the fuel tank)?
    • #74278
      Any pictures to share on these break-down doghouses?
      the front piece.
    • #74279
      Pete,
      I supplied a link to the pictures of my engine box earlier in the thread, but if you missed it here it is again.
    • #74280
      Just got my engine out today. I am a bit confused about the bilge
      arrangement under the engine. Any water from the bilge aft of the
      engine ends up in the separate bilge under the engine. Shouldn’t this
      water flow forward to the main bilge and shouldn’t there be a separate
      pan under the engine to catch engine fluid leaks and contain them
      (separate from water from the aft of the boat?
    • #74281
      Pete,
      That's not the way my bilge works.  Water from aft of the engine compartment flows under the containment pan under the engine into the main bilge.  I know because I have had a persistent leak from the rudder post stuffing box.  Tightening or re-packing the stuffing box will dry things up for a year or so, but then the leaks start again.  Currently my bilge pump comes on every 24-36 hours for about 30 seconds.  The only water that collects in the under engine containment pan is that from dealing with the engine water and coolant hoses.
      On Sat, Nov 14, 2009 at 6:09 PM, Pete Dubler < ([email][/email])> wrote:
      Just got my engine out today.  I am a bit confused about the bilge arrangement under the engine.   Any water from the bilge aft of the engine ends up in the separate bilge under the engine.  Shouldn't this water flow forward to the main bilge and shouldn't there be a separate pan under the engine to catch engine fluid leaks and contain them (separate from water from the aft of the boat?
    • #74282
      John,
      You did a great job documenting this project. Thanks.
      I was wondering if others had pictures as well.
      John Stevenson wrote:
      Pete,
      http://www.svsarah.com <http://www.svsarah.com>
    • #74283
      Thanks John. I guess I need to sort this out.
      Pete,
      That’s not the way my bilge works. Water from aft of the engine
      Shouldn’t this water flow forward to the main bilge and shouldn’t
    • #74284
      Phil Fontaine
      Pete,
      My engine pan has always collected water from places other than hoses or
      pumps. I pump it out once in a while and clean it up a bit. But, mostly I
      keep an oil-sorb pad in the pan across the front of it and another just
      forward and below it to keep any oil in the overflow from getting into the
      bilge.I also keep an oil absorber in the bilge to sop up anything that might
      get by the first two. John evedidently has some separation between the hull
      and the pan that allows water to bypass it.
      I will be cureious to to see what other owners report on the matter.
      Phil Fontaine
      Aurora
    • #74285
      Well, my bilge is a lovely long stream from rudder shaft packing under the fuel tank under the engine (where, by the way, the bolts for the prop strut are) to a waterfall into the deepest darkest part of the bilge.  Not only is there no sump under the engine, there's no room for one.
      Like Phil, I have a veritable store load of oilsorb cloth under there..
