Forums › General Discussion › Compression Testing
- This topic has 3 replies, 4 voices, and was last updated 16 years, 3 months ago by
RichCarter.
August 15, 2010 at 3:02 pm #68101
Participantand now for my 2nd question the day…..
Before I remove the engine (Strut Replacement), I want to do a compression test. I need to purchase a tester worthy of the task. I believe I need to remove the heaters to do the test. So I am thinking I will need an “adapter” to Thread/ Insert into the head where the heaters were. Anyone know anything about this? This is for the W58.
alan_______________________________________________
August 15, 2010 at 3:25 pm #75807
ModeratorGenerally speaking, you use a compression tester in the injector holes – I’m
not sure there’s an adapter for the pre-heater holes, but a diesel mechanic
would know better.Bob
August 15, 2010 at 5:02 pm #75811
ParticipantAlan-
It certainly would be easier to use the screw in glow plug hole rather than the fuel injector. Diesel compression testers usually come as a set with adaptors to fit common engines. Perhaps you could remove one glow plug then match it up to an adaptor at someplace where they have diesel engine compression testers.
Two cautions:
Pull all the glow plugs out before you spin the starter. If the engine starts, it will ruin your day.
Be sure that the adaptor does not extend further into the engine than the glow plug does.
August 16, 2010 at 12:33 am #75816
RichCarterParticipantAlan
There are special purpose adapters made for compression testing a diesel.
You’ll use it so rarely that its hardly worth the investment. I used a
different tool for my compression test, a checkbook. I hired a mechanic to
do it for me.Rich
