Forums › General Discussion › Cutlas bearing
- This topic has 28 replies, 11 voices, and was last updated 16 years, 10 months ago by
petedd.
December 20, 2009 at 12:39 am #67850
SpectatorAnyone have experience cutting out cutlas bearing? I can’t seem to cut
anymore without hitting the strut on the back or narrower end.Any suggestions?
December 20, 2009 at 1:06 am #74587
Syringa
ParticipantPatrick
The rubber is set in a bronze bushing and is one piece. You need to pull the whole thing (Rubber & Bushing). The yard should have a cutlass bearing puller, if not you will have to drive it out with a hammer & punch.
December 20, 2009 at 4:55 am #74588
RichCarterParticipantI replaced mine about 20 years ago. I used a checkbook. The yard did it. I watched them however to see how it was done. They used a threaded rod run through the bearing and a piece of cast-iron pipe and large washers to fashion a press. There are two set-screws that hold the cuttless bearing in place, both on the port side as I recall. In theory, if you remove both, you can press the old one out with this arrangement. It stuck in there so they cut a grove in the old one and tried the press again, Out it came.
Hope this helps
December 20, 2009 at 1:14 pm #74589
ParticipantRemoved ours using the method you are using. Cut it most of the way through in two places 180 degrees apart, then curled up one edge with a narrow screwdriver and a hammer. Once it is split the length of the bearing, grip the cut part with some heavy pliers, twist and pull it out.
Or pay the yard to do it.
December 20, 2009 at 1:29 pm #74590
ParticipantAnd anyone with a decent prop guy can borrow his hydraulic press/
Puller. It has variously fitted end caps and a piston. Better than beating a rod with a hammer cause you don’t mangle your bearing strut. So easy me and another eedgit figured it out on the fly.Adam Silverstein, iPhone
For additional commands, e-mail: ()Post generated from Pearson424 Forum using Mail2Forum
December 20, 2009 at 1:47 pm #74591
ParticipantI have found a site put up by someone who calls himself Maine Sail and his instructions and pics are unbelieveable! His description of how to replace the cutlass bearing is well worth reading! I wish I had seen this before I replaced mine (twice in 14 years!).
Rodd Leeds
WindseekerQuote:
December 20, 2009 at 2:11 pm #74595
ParticipantThose instructions are great.
On hull #73 using a press to remove the cutlass bearing was not an option. There was a lip at the forward end of the strut that prevented the use of a press.
We had to use a sawzall to cut the bearing and then worked it out in a fashion similar to the instructions.
The new bearing went in with a DIY jig similar to his after leaving the cutlass bearing in the freezer overnight.
RickOn Sun, Dec 20, 2009 at 8:47 AM, Rodd Leeds < ([email][/email])> wrote:
Quote:I have found a site put up by someone who calls himself Maine Sail and his instructions and pics are unbelieveable! His description of how to replace the cutlass bearing is well worth reading! I wish I had seen this before I replaced mine (twice in 14 years!).
http://www.anything-sailing.com/replacing-cutlass-bearing-photo-heavy-t1239.html?s=2b135f5683d941832e5e20ac03998d49&
Rodd Leeds
WindseekerQuote:
December 20, 2009 at 2:36 pm #74596
ParticipantPretty much what we did. On a similar note, has anyone tried the portable hydraulic tools that Harbor Freight sells? They have an electric cable lug crimper for $50 and also a 12 ton gear puller for a bit more.
I bought the crimper but have not yet used it. It appears to be a nice piece of gear, ideal for crimping battery cable lugs in the field, a remedy for that old measure once, cut twice problem.
Clairebuoyant #132 -
December 20, 2009 at 4:54 pm #74598
ParticipantThere are some set screws to be found under the paint and removed before
trying to pull the cutlass.Pete
Rich Carter wrote:
Quote:I replaced mine about 20 years ago. I used a checkbook. The yard did
tried the press again, Out it came.Hope this helps
*<.. snip>Post generated from Pearson424 Forum using Mail2Forum
December 20, 2009 at 5:37 pm #74600
john stevensonParticipantQuent,
Thanks for the info on the crimper. I've just ordered one. I plan to redo all of the battery cables before spring, adding a separate starter battery bank. That little hammered crimper I've used for years, probably isn't up to this job.On Sun, Dec 20, 2009 at 9:36 AM, quent < ([email][/email])> wrote:
Clairebuoyant #132—
December 22, 2009 at 10:09 am #74621
SpectatorThos are awesome instructions. The homemade press for installing looks super simple. I too have the lip on the foreward end of the strut as mentioned, but I was also not cutting right at the set screws (which I had already pulled), I’ll try that!
-p—-
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comFrom: “Rodd Leeds” <>
Sent: Sunday, December 20, 2009 5:47 AM
To:
Subject: Re: Cutlas bearingI have found a site put up by someone who calls himself Maine Sail and his instructions and pics are unbelieveable! His description of how to replace the cutlass bearing is well worth reading! I wish I had seen this before I replaced mine (twice in 14 years!).
Rodd Leeds
WindseekerQuote:
December 23, 2009 at 9:26 pm #74634
SpectatorWell now I have a bolt sheared off in the set screw hole. 🙁
I think I’m going to buy a proper cutless puller and a prop puller seems like I could get lots of free beer loaning them out.
On Dec 22, 2009, at 2:08, “Patrick Walters” < ([email][/email])> wrote:
Quote:Thos are awesome instructions. The homemade press for installing looks super simple. I too have the lip on the foreward end of the strut as mentioned, but I was also not cutting right at the set screws (which I had already pulled), I’ll try that!Thanks,
-p—-
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comFrom: “Rodd Leeds” < ([email][/email])>
To: ()
Rodd Leeds
WindseekerQuote:
December 23, 2009 at 9:47 pm #74635
ParticipantSorry to hear that! What type of bolt was it–stainless or other? and what size thread was it, 1/4-20?
Rodd Leeds
December 23, 2009 at 11:52 pm #74637
SpectatorOther… I managed to get everything out. I’ll explain more details later. Have to go pickup Dawn.
On Dec 23, 2009, at 13:48, Rodd Leeds < ([email][/email])> wrote:
Quote:Sorry to hear that! What type of bolt was it–stainless or other? and what size thread was it, 1/4-20?Rodd Leeds
December 24, 2009 at 2:05 am #74638
RichCarterParticipantThere are tools for removing stuck bolts.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95530Here’s what I use for a prop-puller
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=8832Rich
December 24, 2009 at 2:28 am #74639
Participant6″ or 8″ ?
December 24, 2009 at 4:49 am #74640
RichCarterParticipantI have the 6″ set. Its only $10 more for the 8″ set but I didn’t see it when I ordered. The 6″ puller works on my prop. I had to cut a dimple into the center end of the prop shaft for the prop-puller to work right. The dimple retains the puller at the center of the shaft. My prop and shaft are both stainless. I suppose I could have used a drill, but stainless is a bitch to drill. I had to remachine the shaft anyway so I had the machine shop cut the dimple when they did the work. It works pretty well pulling the prop. I put never-sieze on the shaft during assembly to assist in removal. If the jaws slip off the edge of the prop, wrap a hose-clam around them to keep the jaws from slipping off.
December 28, 2009 at 7:39 am #74647
SpectatorHer’es the follow-up info…
I “thought” I had cut all the way through the cutless (that’s the proper spelling right?) bearing, but I had not.
I used a handheld hacksaw blade to really cut the cutless bearing. I was very carefull to not damage the lip in the foreward end of the strut.
It’s really hard to tell if you’ve cut through that end of the bearing. I did scratch the inside of the strut with the saw, but not much.Anyway, once I had really cut the bearing I was able to use a small screwdriver and a hammer to tap it and start ie bending away
from the strut. then I used a large screwdrive and bent it i, it folded very easily inward.I had to bend it in quite a bit because of the bolt that broke off in the set screw hole was sticking into the tube about 1/4″.
Once the bearing was out I was able to use a tiny screw driver and a hammer, tiny little tapping, and more patience that I am known
to posess to slowly back the screw out. I had broke two of those “removes broken screws” thingies. Those things suck, they always break.Anyway, bearing out no damage to the strut and things are looking good!
-p—-
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comFrom: “Patrick Walters” <>
Sent: Wednesday, December 23, 2009 3:52 PM
To: “” <>
Subject: Re: Cutlas bearingOther… I managed to get everything out. I’ll explain more details later. Have to go pickup Dawn.
December 28, 2009 at 1:24 pm #74648
ModeratorActually, Pat, it's cutlass, just like the sword. Your method of removal is pretty typical when all else fails and there's no puller or you're by yourself, or for any number of reasons…
You should be proud of your patience, though.
December 28, 2009 at 2:22 pm #74649
RichCarterParticipantPat
No, it cutless bearing. The bearing doesn’t cut the shaft, so its cutless. Here’s a good link with info.
http://www.diybob.com/diyCutlessBearing.htmRich
December 28, 2009 at 2:35 pm #74650
ModeratorI stand corrected.
Sorry.
December 28, 2009 at 2:50 pm #74651
john stevensonParticipantI think there is a lot of folklore about this name. I was told by a guy who was obsessed with marine terminology that the bearing was named after its inventor. I don't remember how this guy spelled the inventor's name.
On Mon, Dec 28, 2009 at 9:35 AM, Robert Fine < ([email][/email])> wrote:
I stand corrected.
Sorry.
Follow me at: http://www.tinyurl.com/WhereIsBobFine—
December 28, 2009 at 3:10 pm #74652
Participantok , the debate continues, with my vote for “cutlass” as in the following link for the Duramax “Brad” model, which is the one I have used on my boat.
http://www.tacomapropeller.com/6223/Duramax-Marine-Cutlass-Bearings.html
You pays your money and you takes your choice!
Rodd Leeds
December 28, 2009 at 4:12 pm #74654
ParticipantI wonder if a shot of liquid nitrogen (which we all keep in our tool boxes, right? but easy enough to get from the welding supply house or borrow an applicator from a doctor or get one of the wart freezing kits at the drug store) would shrink the bearing enough for it to slide out easier?
Just a thought…
December 28, 2009 at 4:32 pm #74655
ParticipantNever had a problem getting the old one out (after a tough job sawing it and bending it), but what I do is put the new bearing in the freezer overnight and then bring it down to the boat in an ice chest. This does work!!
Rodd Leeds
WindseekerQuote:
December 28, 2009 at 9:11 pm #74656
RichCarterParticipantI always thought the cutlass was a car and the cutless was a bearing, but a web search shows each as being popular spellings for the device. I guess you take your pick.
December 28, 2009 at 9:37 pm #74657
Syringa
ParticipantPatrick
Look at this linkhttp://www.strutpro.com/ on pulling Cutless bearing.
Your yard should have a tool something like this.
Don
December 29, 2009 at 2:12 am #74658
Not in Maine in December………
December 29, 2009 at 4:15 am #74659
ParticipantOn 12/28/2009 2:37 PM, Syringa wrote:
Patrick
Don
Don Gardner
S/V Syringa #124/)+/)+~=:)
