Forums › General Discussion › Cutlass bearing
Viewing 13 reply threads
    • #68187
      What are you smart skippers using for your cutlass bearing? Make,
      model/type, length (is it 4″?), source, etc. I replaced mine a few years ago
      and now can’t find the order info for it.
      SilverHeels, P-424 #17
    • #76329
      Maybe it was 6″. Also, what outside diameter?
    • #76330
      Flounder or Brad I believe
    • #76331
      Johnson Duramax Brad
      Brad is the part number (why I don’t know)
      http://www.fisheriessupply.com/productdetail.aspx?iid=JON%20BRAD&cid=18979
      Length 6″
      Metal Wall (D) 1â
    • #76332
      Excellent! Thanks, Patrick. I believe that’s what I bought last time. Just couldn’t find the data in my files.
      FYI, the site you mentioned, fisheriessupply.com, is selling that cutlass bearing for $109.37, but it’s only $69.99 at http://www.deepblueyachtsupply.com/products/navalbrassinchcutlessbearing.aspx .
    • #76333
      Yeah Fisheries is just convenient (right by my condo) not cheaper on
      everything, but some things.
      Only cool thing is they track everything if you setup an account and then
      you have a completely online copy of everything I’ve bought. Plan to print
      that out before we leave town. They also have variable pricing. The more you
      spend the deeper your discount.
      bearing for $109.37, but it’s only $69.99 at <
      http://www.deepblueyachtsupply.com/products/navalbrassinchcutlessbearing.aspx&gt;
      http://www.deepblueyachtsupply.com/products/navalbrassinchcutlessbearing.aspx.
    • #76334
      I found them even cheaper on ebay search for brad or flounder cutless
      or cutlass
    • #76335
      Thanks, Pete. Every little bit helps stretch the cruising kitty. (Looks like the eBay sellers spell it “cutless.” I never have been clear on what’s correct.)
    • #76336
      That’s it. They all have boy-pornstar names. Weird.
      -iPhone
      Length 6″
      Metal Wall (D) 1â
    • #76337
      “Cutlass vrs. Cutless”
      Let’s not start that discussion again (almost as bad as the anchor threads)
      [?]. Let’s just accept that the name can be whatever the seller thinks it
      is.
      -iPhone
      On Dec 8, 2010, at 2:39 PM, “Patrick “Peaboy” Walters” <
      Length 6″
      Metal Wall (D) 1â
    • #76341
      I say it’s “Cutliss.”
    • #76344
      That was a long discussion a while ago. “Cutless” was the trademark.
      You might even find for sale copies of the original ads for the bearing
      in ebay. Back when we all would have grown up with lathes, etc, the
      concept of a bearing cutting less of your shaft would have rung true.
    • #76373
      On the subject of ‘I found a cheaper source’…
      I did a major refit on a twin engine trawler. The dripless shaft seals which were relatively new were already failing. I contacted the manufacturer and explained the issue, they said they would replace them and sent me such. They also requested we send the old ones back so they could examine them. A few weeks later I get a call back and asked to find out where the customer had obtained them from. They were knock offs.
      I’m sure the cost to replace them was considerably more than the savings up front.
      Make sure such products are coming from a reputable supplier. These knock offs passed all the tests except usage.
      Duramax is the main manufacturer of cutless bearings, they supply the military as well.
      SS hardware/fasteners is another real problem we are seeing problems with.
      I’ve purposely not noted the manufacturer or the source of the parts.
    • #76374
      Sorry, ‘Johnson-Duramax’ and I’d bet Deep Blue is a reputable supplier.
