Forums › General Discussion › Cutless it is…
- This topic has 8 replies, 7 voices, and was last updated 16 years, 10 months ago by
hanks424.
December 30, 2009 at 11:39 pm #67872
SpectatorSent from my iPhone
December 31, 2009 at 3:24 am #74671
john stevensonParticipantUnless you are dealing with the Patent Office: http://www.patentstorm.us/patents/5860745/description.html
On Wed, Dec 30, 2009 at 6:28 PM, Patrick Walters < ([email][/email])> wrote:
https://pearson424.org/mailman/listinfo/maillist_pearson424.org—
December 31, 2009 at 1:46 pm #74674
ModeratorThen I'm going back with what I've known it as for the last 50 years, cutlass bearing. Ahahahahahahaha!
http://www.svsarah.com_______________________________________________
December 31, 2009 at 3:00 pm #74675
RichCarterParticipantAs far as I can tell by doing a web-search, they were originally called cutless bearings by the inventor since they were self-lubricating and didn’t cut the shaft. Previously shaft bearings were made of Lignum Vitae, a kind of wood. The new bearings were originally manufactured by Goodyear (I think) using the cutless trade-name. They were later manufactured by another company using a cutlass logo and became popularly known as cutlass bearings much like my grandparents called refrigerators frigidairs. There appear to be more references to cutlass that cutless so I think its the more popular spelling. My own perference is to call them cutless because it refers to the device with its original name and not a brand-name. I think either spelling is perfectly acceptable however.
“In the beginning inboard propeller shaft bushings were wood, machined from the rock hard tropical Lignum Vitae tree. That is until the 1920s when a Californian mining engineer improvised a bearing using a chunk of common rubber steam hose pressed inside a sleeve. The modern day Cutless bearing replete with flutes and naval bronze tubing was born. Cutless bearing technology advanced during the WW II battle for the Coral Sea when reverberations from explosions in the water hardened the rubber in Cutless bearings. Battleship propeller shafts locked up solid. Rigid rubber was soon replaced by resilient nitrile rubber.”
December 31, 2009 at 3:10 pm #74676
john stevensonParticipantWas the inventor's name Cutless?
On Thu, Dec 31, 2009 at 9:59 AM, Rich Carter < ([email][/email])> wrote:
Quote:As far as I can tell by doing a web-search, they were originally called cutless bearings by the inventor since they were self-lubricating and didn't cut the shaft. Previously shaft bearings were made of Lignum Vitae, a kind of wood. The new bearings were originally manufactured by Goodyear (I think) using the cutless trade-name. They were later manufactured by another company using a cutlass logo and became popularly known as cutlass bearings much like my grandparents called refrigerators frigidairs. There appear to be more references to cutlass that cutless so I think its the more popular spelling. My own perference is to call them cutless because it refers to the device with its original name and not a brand-name. I think either spelling is perfectly acceptable however.
December 31, 2009 at 3:14 pm #74677
ModeratorNavy ships still use lignum vitae for the strut and stuffing boxes. The stuffing boxes are pressure lubricated, though.
The wood lasts far longer than rubber. Very often, a ship will go it's full lifetime without changing the bearing surface.
December 31, 2009 at 3:29 pm #74680
ParticipantOn 12/31/2009 7:59 AM, Rich Carter wrote:
… Previously shaft bearings were made of Lignum Vitae, a kind of wood. …
Lignum Vitae, also known as “iron wood” is one of two woods that naturally don’t float. The other one is Natalie Wood. ba dum bump…
December 31, 2009 at 3:47 pm #74681
Bah, humbug! Just because a few manufacturers don’t know how to spell…
December 31, 2009 at 7:36 pm #74684
hanks424
ParticipantMore trivia: teak wood logs sink, making harvesting very expensive.
(message sent to test the new system, not impart knowledge :-))
Hank S.
SHAY #80
— On Thu, 12/31/09, Pete Dubler <> wrote:Quote:<.. snip>Post generated from Pearson424 Forum using Mail2Forum
