Forums › General Discussion › Damn your excel John Stevenson!
- This topic has 4 replies, 4 voices, and was last updated 18 years, 6 months ago by
April 26, 2008 at 3:35 am #66954
Hey all, I just posted some pix of my not-yet-complete bilge project.
https://www.pearson424.org/gallery/Bilge-on-Ra
So here’s how this little project went,
I wanted a horn at the spreaders. When I went to install it, I had difficulty getting the wiring in the mast because there was a lot of old crap. So I pulled that out.
And re-wired from the binnacle to the spreaders. In doing that I found oil in the bilge, suddenly clearing up the mystery of the disappearing oil.The original Bilge Pump left several inches of water in the bilge, topped with about a gallon of oil.
So I decided to redo the bilge pump setup as per suggestions from the list, but the shower sump was in the way, so I had to relocate that, (as in I had to rent a sawzall) which in turn meant having to relocate the raw water strainer.
When I removed the sump hose, I discovered that the seacock would not shut off. SO I replaced that.
(I did however talk my girlfriend into crawling into the bilge to help clean it. Again thanks to the list I was able to say “see hun, other admirals do it, it would be ‘weird’ if you refused”)
The best place to put the new sump was occupied by the holding tank discharge. SO I had to relocate that, which meant a couple new hoses.
So I decided to replace ALL of the sanitation hoses. In the course of this, I discovered that the discharge pump went straight to the seacock without a vented loop. Meaning that a small check valve in the pump was all that was keeping the seawater out of the holding tank.
While it was out, I rebuilt the discharge pump, where I discovered that the check valve didn’t in fact close all the way, which suddenly explained why the holding tank was full even if we didn’t use it for a week.
While I had nearly every friggin hose and wire in the bilge exposed I needed to climb into all of the aft lazzarettes, and since I had all that crap out of the boat I did a deep spring cleaning to inventory the boat and add everything into John’s excel spreadsheet.
But then it was dark, and supposed to rain and so I had to put it all back, and now I have to take it back out to inventory it so damned you John and your cool excel spreadsheet!!!!
Or and my boat is a friggin’ deathtrap.
I still don’t have the raw water pump or the sump reinstalled or even found the oil leak yet.
April 26, 2008 at 12:40 pm #69646
ModeratorHi Aaron,
That is perhaps the funniest thing I've read in a long time – and the picture is beautiful! Both are so prototypical of the plight of boat owners.
Thanks for that!
Bob Pelican # 8
April 26, 2008 at 1:16 pm #69649
john stevensonParticipantAaron,
I also loved the rant – actually you beat me to it. I've spent the last month trying to install my composting head, but it seems every day something more critical pops up and demands my attention. Two days ago the hard drive on my navigation computer crashed and burned. Spent a couple of days trying to restore it, then got my backup computer computer working , sorta. Yesterday I thought I was ready to move out on the head, when the galley faucet decided it was time to spring a leak – that's my task for today.
One thing I can say though – all these broken parts are very well inventoried.
Now if I can just keep those idiots on the Dell Auction site from outbidding me, I'll have two replacements for my old navigation computers.John
On Sat, Apr 26, 2008 at 8:40 AM, Robert Fine < ([email][/email])> wrote:
Hi Aaron,
Thanks for that!
Bob Pelican # 8
So here's how this little project went,
(I did however talk my girlfriend into crawling into the bilge to help clean it. Again thanks to the list I was able to say “see hun, other admirals do it, it would be 'weird' if you refused”)
While it was out, I rebuilt the discharge pump, where I discovered that the check valve didn't in fact close all the way, which suddenly explained why the holding tank was full even if we didn't use it for a week.
While I had nearly every friggin hose and wire in the bilge exposed I needed to climb into all of the aft lazzarettes, and since I had all that crap out of the boat I did a deep spring cleaning to inventory the boat and add everything into John's excel spreadsheet.
Or and my boat is a friggin' deathtrap.
I still don't have the raw water pump or the sump reinstalled or even found the oil leak yet.
April 26, 2008 at 10:19 pm #69654
ParticipantWelcome to boating my friend… what is it that West
not-yet-complete bilge project.https://www.pearson424.org/gallery/Bilge-on-Ra
So here¹s how this little project went,
install it, I had
with about a gallon of oil.So I decided to redo the bilge pump setup as per
strainer.When I removed the sump hose, I discovered that the
off. SO I replaced that.(I did however talk my girlfriend into crawling into
it. Again thanks to the list I was able to say ³see
it, it would be Œweird¹ if you refused²)The best place to put the new sump was occupied by
the holding tank
couple new hoses.So I decided to replace ALL of the sanitation hoses.
keeping the seawater out of the holding tank.While it was out, I rebuilt the discharge pump,
check valve didn¹t in fact close all the way, which
the holding tank was full even if we didn¹t use it
for a week.While I had nearly every friggin hose and wire in
everything into John¹s excel spreadsheet.But then it was dark, and supposed to rain and so I
your cool excel spreadsheet!!!!Or and my boat is a friggin¹ deathtrap.
I still don¹t have the raw water pump or the sump
the oil leak yet.
April 27, 2008 at 3:16 am #69657
RTFL, you know ruth manages one? Too funny.
install it, I had
it, it would be ‘weird’ if you refused”)The best place to put the new sump was occupied by
the holding tank
everything into John’s excel spreadsheet.But then it was dark, and supposed to rain and so I
your cool excel spreadsheet!!!!Or and my boat is a friggin’ deathtrap.
the oil leak yet.
