Thanks Quent.
A few thoughts on these:
These are about 14.5 watts per sq ft and the price per watt is $1.50.
Here is the full data sheet:
http://www.grapesolar.com/index.php/products/modulesandkits/100eco
Compared to a 245 watt ET panel which sells for $248: 14 watts per sq ft
and $1.01 per watt
Seems one pays a premium here for the 100 watt panel, but if the
dimensions work for you, the power density is the good. If you can use
a larger panel, like the ET (similar warranty, you get more watts for
you money.
http://www.wholesalesolar.com/products.folder/module-folder/ET/ET-P660245B.html
Good discussion on how to wire these is found here:
http://www.grapesolar.com/files/4313/4910/4245/GS-S-100-Fab36_Guide.pdf
On 2/22/2013 5:34 PM, quent wrote:
Costco is selling 100 watt panels for $150!
http://www.costco.com/Grape-Solar-100W-Solar-Panel.product.100033918.html
