Forums › General Discussion › Diesel Leak or Spill
- This topic has 15 replies, 8 voices, and was last updated 15 years, 1 month ago by
quent.
September 1, 2011 at 5:43 pm #68406
SpectatorWhen fueling up the other day we had an overflow at the fill and at the vent on the stern. (Way more poerful pump than I was used to). Not that much fuel spilled, but now there is some diesel dripping from the forward area of the tank and i’m not sure if its from a leak or the overfill event.
I’ve crawled all over the lazarettes and the tank and all the fittings look fine and there’s no fuel on the top or sides of the tank.
Do I have a leak or is there some other place the fuel could have squeezed out when we overfilled? Right now I’m hoping it just a clean up problem… 🙁
-pOwners no more...
September 1, 2011 at 6:29 pm #77563
Many of the aluminum tanks supplied by Pearson developed pinhole leaks.
Hopefully this is not the case with your tank, but the hydrostatic pressure
of the fuel overflow might have been enough to open a pinhole. I believe
the pinholes were caused by electrolysis between the tank and the hold-down
straps. Earlier 424s came with iron tanks, which did not have this problem.
If there is no fuel evident on the tops and sides of the tank, could the
fuel you see have been there before and you only noticed it because of the
spill?
Clean it up and see if any fuel comes back. Good luck.Regards,
http://www.svsarah.comOn Thu, Sep 1, 2011 at 1:43 PM, Patrick_DeepPlaya wrote:
the tank and i’m not sure if its from a leak or the overfill event.I’ve crawled all over the lazarettes and the tank and all the fittings look
fine and there’s no fuel on the top or sides of the tank.Do I have a leak or is there some other place the fuel could have squeezed
🙁Thanks,
Deep Playa, #152 http://www.DeepPlaya.com_______________________________________________
September 1, 2011 at 8:03 pm #77564
Lee Yonkers
ParticipantJohn,
I read your response to Patrick’s question and immediately put a magnet on the tank. It stuck! I have hull number 43. Do you know which hull number was the first 424 to have aluminum fuel tanks?
Lee
September 2, 2011 at 12:14 am #77565
SpectatorGave everything a good cleaning laid down fresh oil cloths and we have a
drip, but its a very light drip (couple of drops today). I think we’re going
to leav it alone and get to San Francisco as there doesn’t seem to be any
options to fix it here in Newport, OR.-p
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.com | @DeepPlayaOn Thu, Sep 1, 2011 at 11:29 AM, John Stevenson wrote:
Patrick,
problem.
spill?
http://www.svsarah.comOn Thu, Sep 1, 2011 at 1:43 PM, Patrick_DeepPlaya <
vent on the stern. (Way more poerful pump than I was used to). Not thatmuch
of
look
squeezed
problem…
September 2, 2011 at 12:24 am #77566
joe shimkonis
Participantmine is hull 78 and had to replace the aluminum leaky tank-many many pin hole leaks-everywhere on the bottom-not one or two.
Joe Shimkonis
September 2, 2011 at 1:11 am #77567
john stevensonParticipantLee,
No, I don’t know when Pearson changed the tanks to aluminum. My new tank is
aluminum, but the hold-down straps are isolated from the tank by cork
strips.Regards,
http://www.svsarah.comOn Thu, Sep 1, 2011 at 8:24 PM, joe shimkonis wrote:
Quote:mine is hull 78 and had to replace the aluminum leaky tank-many many pin
hole leaks-everywhere on the bottom-not one or two.Post generated from Pearson424 Forum using Mail2Forum
September 2, 2011 at 1:31 am #77568
SpectatorI think I like Pete’s 95 gallon tank below the salon floor…
http://dublerfamily.com/Regina_oceani/Tank_project/SVReginaOceanFuelTankProject/index.htmlWhat did you do with the area under the cockpit sole, put in a third berth?
Quote:On Thu, Sep 1, 2011 at 8:24 PM, joe shimkonis wrote:Quote:mine is hull 78 and had to replace the aluminum leaky tank-many many pin
September 2, 2011 at 11:24 am #77569
joe shimkonis
ParticipantCan someone send me the boat profile and strap positionings to insure a damage free haulout? Bottom paint way past due.
Joe Shimkonis
September 2, 2011 at 11:32 am #77570
file attached : 424 profile & lift points.
~~~~ Capt. Bill Tice, aboard s/v CHARISMA ~~~~~
September 2, 2011 at 8:31 pm #77574
SpectatorGoing to have a guy come downa nd take a look today… just talking on the phone he had an interesting suggestion of removing the fuel, and the old tank, throwing in an interim solution (bladder smaller pre-made tank) to get us down the coast while we waited for a new tank.
Hate having to deal with this in a hurried manner… and its a holiday weekend too… yay!
options to fix it here in Newport, OR.Owners no more...
September 3, 2011 at 2:58 pm #77575
ParticipantAs a naive aluminum tank owner (#135), why couldn’t bladder fuel tanks be utilized as permanent replacements? Sounds a lot easier than pulling the engine.
Jolly Lama (#135)
Ko Olina, O’ahu -
September 3, 2011 at 3:32 pm #77576
john stevensonParticipantDon,
I can only guess at this, but reasons not to use bladder tanks1. Difficult to secure in boat
2. Limited capacity compared to metal tank
3. Coast Guard approved for fuel?
4. Insurable?
5. Difficult to attach fittings
6. Short useful life compared to metal tankRegards,
engine.Dan Kalinowski
Jolly Lama (#135)
September 3, 2011 at 3:55 pm #77577
ParticipantIf the’re not secured properly, they WILL chafe through – from the constant motion in a seaway……
alan— On Sat, 9/3/11, John Stevenson wrote:
September 3, 2011 at 6:57 pm #77578
ParticipantFlexible tanks come in all shapes and sizes. See link here to a flexible tank company that advertises in Professional Boatbuilder:
http://www.atlinc.com/
I’ve heard of some people who simply cut the top off the old tank then installed a flexible tank inside. Don’t know what a custom sized flexible tank would cost, probably plenty. This arrangement would probably address many of John’s concerns and would have the additional advantage of no air vent.
We have an aluminum tant which I repaired by encapsulating it in fiberglass and West epoxy. About 8 years since and no leaks, kow!
Clairebuoyant, #132 -
September 4, 2011 at 6:28 pm #77583
ParticipantTanks for the insights! (Had to do that.)
No leaks yet on our boat. But Quent’s #132 is close to my #135 and I guess I better be prepared.
Jolly Lama (#135)
Ko Olina, O’ahu -
September 4, 2011 at 8:12 pm #77584
ParticipantDan-
I suggest that you keep your fuel clean. Our tank corroded through from the inside. The outside was fine.
