Forums › General Discussion › documentation number
Viewing 11 reply threads
    • #67920
      OK I now have my documentation numbers any suggestions for the location for permanently marking in the interior. Any pictures would be great. I can’t remember ever seeing the numbers on boats in the interior before.
    • #74942
      According to coast-guard requirements, it should be carved in a beam
      somewhere that can’t be mucked with. My boat has vinyl letters stuck to the
      forward bulkhead in the v-berth. This is not consistent with what I’ve read
      for permanent marking. I suggest carving it into the crossbeam under the
      mizzen or a similar place.
      The whole theory behind carving the documentation numbers into a beam is out
      of date. Federal laws now require that the builders serial number be
      permanently affixed to the transom. This more or less mitigates the use of
      a documentation stamp. You want to be legal however.
    • #74943
      Morning Glory’s documentation number was carved into a one by three, the numbers painted black and then the 1 X 3 was glassed in place in the port lazerette. Don’t know if this is the way it is supposed to to be done, but it has worked so far.
      By the way, does anybody know the correct way to spell ‘lazerette”?
      Lee
    • #74944
      maritime&shippingT
      LAZARETTE
      A storage space in a boat’s stern area.
      Nautical Know How Glossary of Boating Terms
      LAZARETTE
      Nautical Nomenclature
      Lazarette
      spaces below the deck that are designed for storage
    • #74945
      Thanks Rich.
      Here are some interesting tidbits, some of which are a bit humorous.
      http://dictionary.reference.com/browse/Lazarette
      Lee
    • #74946
      Mine’s on the aft bulkhead on the port side over the foot of the bunk in the
      aft cabin. It’s a self-adhesive transparency. The only key to having one
      mounted is that it has to be easily visible, affixed to the boat in such a
      manner that removal would destroy it.
    • #74947
      Navasana’s documentation numbers are carved in a teak board that was sitting loose above the bunk in the Vberth. We found it during our survey. the official survey noted the documentation panel was not properly affixed. I glued and screwed it to the starboard interior cabin just forward of the midship companion way.
      Last summer we were boarded by USCG in the Gulf of Maine. The office in charge of our inspection noted the location on his report and told me though the panel was not in the right place it was acceptable. I will post a photo later.
      Eric
      — On Wed, 2/10/10, sum ocean wrote:
    • #74948
      Mine is in roughly the same location as Bob’s, except inside the cabinet
      over the foot of the bunk. I have to remove the drawers to make it
      visible. Don’t know why it is there. I guess the PO who documented the
      boat didn’t want to waste useful bulkhead space on it.
      later.
      Eric
    • #74950
      Mine are glassed into the hull in the hanging locker in the v-berth. Looks
      like they took vinyl sticky numbers and then glassed over them. Quick and
      easy.
    • #74949
      Lady Leanne’s number is routed into a board that was affixed (glassed?) onto the aft wall of the the aft cabin hanging locker.
      Lady Leanne II (#135)
      Honolulu
    • #74951
      I guess the wording that the instructions from the Coast Guard: “Arabic
      numerals of at least 3 inches in height on some clearly visible interior
      structural part of the hull” confuse me a bit. I don’t know that there is a
      clearly visible structural part of the hull down below. However I guess a
      bulkhead is a structural part of the hull so I can affix a plaque to that
      and I will pass. From what you guys have described the Coast Guard is not
      as concerned as I am about the number.
      So a small plaque screwed to the bulkhead it will be. After the leaking
      stanchion bases have been fixed.
      I hope it’s warm where you are, winter sucks
    • #74961
      The doc # on Easy Reach were carved into a beam under a cabin sole hatch by a P.O., upside down, as it were, so it can be easily read while the reader is bent over. The numerals are large and it appear to have been cut with some sort of dremel tool.
      Norris Larson, #206
      — On Thu, 2/11/10, Linus Martinez wrote:
