Forums › General Discussion › Drip Rails
Viewing 6 reply threads
    • #67960
      Has anyone done anything so major as pull down the drip rails and completely
      replace the cabin top wood? We’ve had a setback with our choice of materials
      and I might have to pull the wood off the cabintop completely. Not excited
      about the idea of that.
      But back to those drip rails. I can see a set of bungs and thus screws along
      the finished face facing the salon. Are they also bolted in on the for and
      aft bulkheads I dont’ see any evidence of this. I’m going to have a boat
      builder look at this before I do anything drastic, but I was just curious if
      anyone has had to do anything so extreme.
      Breathing deeply, in and out…
    • #75110
      Hi Patrick,
      Are you talking about the inside or outside of the cabin? If the ones under
      the portlights inside, they come out with the removal of those bungs and
      screws.
      Remember, in a production boat, easier is better – they’re not going to do
      really fancy things on trim when simple screws will do.
      Have fun!
      On Fri, Apr 2, 2010 at 12:14 AM, Patrick “Peaboy” Walters <
      completely
      materials
      along
      if
    • #75111
      I’m referring to the ones inside the cabin. Huh, they’d come out that easy?
      I figured they were structural.
      On Fri, Apr 2, 2010 at 4:56 AM, Robert Fine <> wrote:
      Hi Patrick,
      under
      screws.
      Have fun!
      completely
      materials
      excited
      along
      and
      if
    • #75112
      They are structural in the sense that they help stiffen the plywood that
      sheathes the inside of the cabin. They also provide a handhold and a place
      to put business cards, snack bars, and all sorts of little items.
      Other than that, they are easily removable (except for those bungs).
      I have hull # 8, and I have backing trim as well for the plywood. I suspect
      that’s removed after removing the drip rail.
      On Fri, Apr 2, 2010 at 11:03 AM, Patrick “Peaboy” Walters <
      Hi Patrick,
      under
      screws.
      do
      Have fun!
      completely
      materials
      excited
      along
      and
      boat
      curious
      if
    • #75114
      I replaced a section of the interior coach trim around one of the portlights in the V-berth. As I recall, removing the drip-rail was trivial. I drilled a small hole in the center of each bung. Put a screw in each and popped the bung out. I removed the screws and the rail came off. The damaged section ran under the forward bulkhead, so I used a multi-tool with a saw bit and straightedge to cut the panel. The forward section of the panel connects to the piece on the bow, so I cut there too. After removing the top trim piece and portlight, the damaged section came out. I assume that you have similar deterioration around one or more of your portlights. If you are handy with tools, this repair is fairly simple. I can send photos of the work if it might help.
      Rich – BlackSheep #47
    • #75115
      We already put up a new layer of plywood, but we used poor material I
      thought it was birch plywood. It’s MDF with birch faces. Now we have a leak
      that is causing the MDF to expand in two spots so we’re going to have to
      pull that down, but we put it up with epoxy over the old wood, so either we
      grind off the MDF or pull out all of the wood and put up new wood.
      Very disappointing… calling crosscut hardwoods today to talk marine grade
      plywood with them.
    • #75116
      I replaced the small section in my V-berth with new teak-faced marine plywood. The plywood was thinner that the original stock by about 1/16 inch and had to be shimmed. I used some oak veneer I had laying around for the shim. Worked fine. I got the wood at goosebay lumber. Shipping would kill you to buy plywood from them, but they have unbeatable prices on teak lumber.
      http://www.goosebaylumber.com/
