Forums General Discussion Electric Propulsion
Viewing 10 reply threads
    • #68444
      I looked into electric propulsion 5 years ago for a boat I was thinking
      of building, shortly before I bought Silverheels. Researched it online a
      bit, met with an electric engine developer/manufacturer on the west
      coast of Florida, and concluded at that time that they weren’t quite
      ready for this application. Expensive, too. Still, I’ve always liked the
      idea. Sounds like maybe they’ve worked out the bugs.
      From whom are you getting quotes, Dan? Got a URL for what you’re
      considering?
    • #77878
      Aloha Tor: The company I’m talking with now is at electricyacht.com. They’ve proposed a complete package that consists of the motor, mounts, couplings, etc. for $7,500. The plan also calls for $3,900 of AGM batteries. This would drive a 424 (based on their model and our boat specs) at 3.5 knots for 25 NM or 5 knots at 11 NM before charging is necessary. There is always great wind here in the Sandwich Isles, so this is certainly enough to meet my needs.
      They are also developing a diesel genset with raw/fresh cooling that would be an extra (but I think important) addition for unlimited cruising. Of course, solar and using the prop as a log will also help out.
      The bennies are easy to see: 50,000 maintenance free running hours on the motor; no sound; no fuel smells/exhaust; and no fuel costs (outside of the genset).
      I’m game as replacement nears.
      Ko Olina, O’ahu
    • #77879
      Thanks, Dan. With a relatively new Yanmar diesel in my boat I’m not
      likely to change any time soon, but I like the idea of electric and will
      be very interested to learn how it works out for you in your 424.
      Conditions seem favorable for electric motoring in Hawaii, where you can
      count on steady breezes for sailing most of the time. But for more
      global blue water cruising in the modern sense we want the ability to
      motor hundreds of miles, ideally at 6 knots in a 42′ boat. What I’d love
      to find out is whether re-charging batteries using solar, wind and (as
      you noted, the important) diesel generator to power an electric motor is
      now practical. Thanks for keeping up posted if/when you make the change.
    • #77880
      skipmac
      I have been researching various electric drive systems for a couple of years and have to agree with Tor. For serious cruising I want at least 300 nm range plus enough reserve power to get me out of a jam if I need it.
      The range requirement is achievable but will require a diesel genset, either direct DC or AC with a DC converter. However, without the genset to reach even 100-200 nm range under power would require enough batteries to replace all the ballast in the boat. Solar and wind, even at max, are not enough for continuous motoring except at very low speed.
      Power is another thing. Electricyacht.com their biggest system is rated as equivalent to 23-30 HP engine, 18 continuous at the shaft. This is typical of most systems I have found.
      Now you do lose a good bit in parasitic loads with a diesel, water pumps, alternator, transmission, etc but most estimates I see range 10-20% so a W58 would give at least 46 useable HP. With my original W58 I feel just a bit underpowered already, so to go with an equivalent electric of half that doesn’t seem right for my cruising plans.
      Granted 99% of the time, motoring will be to leave the dock or make a few miles when the wind dies but there are those time when you need the power to punch into a head sea and wind or against a current in a tight channel where the extra HP could be critical.
      Then there’s the bottom line. The 30 HP electricyacht system is equivalent to about 20 KW which is a big, expensive generator. Even going with a system with less HP than my W58, after adding the genset I would end up with double or triple the cost of a complete repower with diesel engine and transmission.
      I love the idea but, for me, it is not yet ready for prime time but I’m hoping.
    • #77881
      There is no right or wrong here. To accept the current shortcomings of
      electric proplusion, you only have to start at the other end of the
      spectrum, i.e., with a pure sailboat. Back in the day that’s all there
      was. Then came auxilliary engines meant to assist in tight
      circumstances. Remember how comparitively small they used to be? Their
      function was essentially to move the boat around in harbor, not to power
      through anything and everything, 24/7. Today we cruise in, if not
      motor-sailers, then sailer-motorers. We rely on our engines. But that’s
      just a state of mind. You can cruise without. The Pardy’s did; so did
      many others not so long ago (including me for a few years aboard my
      engineless Ketch Autant). Starting from that point, from a plain
      sailboat, a 25-30 hp auxilliary propulsion system becomes a terrific
      asset. It’s a matter of perspective, and of what you seek from sailing.
    • #77882
      skipmac
      Again I agree. Not saying electric is right or wrong in general, just not right for my plans and style of cruising. There are places I want to go that you can’t go without strong power and range, like the rivers and canals of Europe. Also would prefer to motor through a calm than spend spend an extra day or three waiting for the wind.
      Cruised a bit without an engine myself. Boat had one but I couldn’t afford the fuel so sailed everywhere. Quite doable and good for skills building but limits some of your options.
    • #77883
      There is or was a company named Nanosolar that was going to make (or had
      taken money to make) thin, flexible, large scale solar films – much like the
      films that are now laminated in sails. I contacted them about their product
      (in development) mentioning the application – imagine, if you will, your
      sails with solar panels laminated to each side! Think of the area and
      power!
      They were disinclined to agree – they wanted to do entire buildings or
      Christo artworks. Feh! They lost a huge market.
    • #77884
      What we need here is to find a diesel Prius and take it apart…
    • #77885
      According to the calculations done when I was researching a new engine,
      accounting for transmission/v-drive losses, etc., it takes about 36 HP
      going into the velvet drive to achieve hull speed of a 424.
      And there are between 55 and 74 million bubbles in the average bottle of
      champagne (sparkling wine)… a fact you will probably get more utility
      out of at New Year’s Eve parties…
    • #77903
      Nigel Calder is doing a lot of research into this. When I last heard him
      speak 2 (maybe 3) years ago at the Seattle Boat Show he was saying with
      current technology using a generator and batteries to drive an electric
      engine didn’t add-up (i.e., it was less efficient). Now he said if you add
      in some solar, or wind generators, and for sailboats using the spinning prop
      to generate then its possible, but he didn’t have a lot of data on that. He
      did have data on the pure generator battery solution though and he said
      diesels still win in that solution.
      That of course was a pure power and efficiency comparison, it says nothing
      about the joy of quietness!
      I’m looking forward to his future publications in this area.
      On Sat, Oct 15, 2011 at 7:25 AM, Pete Dubler wrote:
      accounting for transmission/v-drive losses, etc., it takes about 36 HP going
      champagne (sparkling wine)… a fact you will probably get more utility out
    • #77905
