Forums › General Discussion › Electrical Panel
Viewing 15 reply threads
    • #67286
      If this thread has moved to nav station panels, here’s an idea I’m trying out. I need a bunch of different breaker switch name labels than what’s on there now. I bought a package of assorted labels for that purpose from Port Supply, which fit and look nice of the boat’s original Marinetics panel, but there were a lot of labels in the pack that I didn’t need, and a bunch I did need that weren’t there. So I returned the package and bought a pack of Avery stick-on labels at Office Depot, the labels of a size that fit perfectly into the name spaces on the panel. Then I made up a template in MS Word, typed in the names I need on my particular panel, and printed that onto a blank Avery labels page. Finally, I laminated the entire sheet (face side only). When I’m ready – that is, when I get around to re-organizing the breaker switches in the panel into groupings that makes sense – I’ll cut out the labels with a scissors, peel off the backing, and stick them on the panel. With their faces protected by the clear lamination, I anticipate a satisfactory result.
    • #71296
      I used a label maker machine from Brother with white on black tape. It
      looks great and I can write anything I want on the labels. These are
      laminated and very durable. But I would still like to make a clean, new
      panel one day.
      *<.. snip>
    • #71297
      Hi Pete,
      I used the labelmaker as well, but since I had a dinghy load of black on white labels, I used that tape. Frankly, I find them easier to read in red light. In addition, I added a red LED to each 12 breaker so I could see at a glance what was on. Unfortunately, in 'Tool Time' moment, I ordered the LEDs from plasmaled.com. When I was moored 1/4 mile from the docks at City Island the launch drivers would use the red light out the port aft cabin light as a marker in the mooring field.
      I probably, in hindsight, should have used just regular old LEDs. But I bought 50 of them for $50. The way it works out, if I have guests in the aft cabin I have to cover the power panel so they can sleep….
      Hull #8
    • #71298
      Robert,
      Try putting a few thousand ohm 1/4 watt resistor in series with the LED
      to dim it. I would first try a 3K ohm. You could get fancy and tie all
      the LED ground leads together and route that through a resistor with a
      switch across it. Then you could have bright and dim settings. If you
      do that, you may want to go to a higher wattage resistor.
      Robert Fine wrote:
      Hi Pete,
      so I could see at a glance what was on. Unfortunately, in ‘Tool Time’
      <http://plasmaled.com>. When I was moored 1/4 mile from the docks at
      Hull #8
    • #71299
      Hi Pete,
      That's a terrific idea – they are all commonly grounded now! I hadn't thought about that. To be honest, I was thinking how to make the LEDs light when the circuit was in use – using a resistor in series with the load and using the voltage drop across that for the LED's light, but I'd have to replace the LEDs with something like 3 volt ones.
      For your suggestion, I wonder if I could use a potentiometer for a variable dimmer? Like a dashboard on a car.
      On Thu, Dec 18, 2008 at 5:54 AM, Pete Dubler < ([email][/email])> wrote:
      Robert,
      Try putting a few thousand ohm 1/4 watt resistor in series with the LED to dim it. I would first try a 3K ohm. You could get fancy and tie all the LED ground leads together and route that through a resistor with a switch across it. Then you could have bright and dim settings. If you do that, you may want to go to a higher wattage resistor.
      Robert Fine wrote:
      Hi Pete,
      I used the labelmaker as well, but since I had a dinghy load of black on white labels, I used that tape. Frankly, I find them easier to read in red light. In addition, I added a red LED to each 12 breaker so I could see at a glance what was on. Unfortunately, in 'Tool Time' moment, I ordered the LEDs from plasmaled.com <http://plasmaled.com>. When I was moored 1/4 mile from the docks at City Island the launch drivers would use the red light out the port aft cabin light as a marker in the mooring field.
      Hull #8
      Hull #8
    • #71300
      Hard astern…
      The LEDs you have must already have a resistor in line. By adding more
      resistance, you can make them dimmer. A pot would be fine.
      plus lead of LED to output of breaker. ground lead through extra
      resistor then to ground.
      (Do not try to put the LED and resistor in series with the load the
      breaker is handling, if that is what you were suggesting).
      Robert Fine wrote:
      Hi Pete,
      That’s a terrific idea – they are all commonly grounded now! I hadn’t
      the load and using the voltage drop across that for the LED’s light,
      but I’d have to replace the LEDs with something like 3 volt ones.
      > wrote:
      Robert,
      Robert Fine wrote:
      Hi Pete,
      Unfortunately, in ‘Tool Time’ moment, I ordered the LEDs from
      plasmaled.com <http://plasmaled.com> <http://plasmaled.com>.
      Hull #8
      Hull #8
    • #71301
      Hi Pete,
      Actually, they are already wired the way you mention – all I have to do is put a pot on the common ground.
      But let's look at another problem, for instance, where you not only want to know when the breaker/switch is on, but you also want to know if the load is actually running as in navigation lights. On high-end yachts and cars, there is a monitor light for each light (the old Corvettes had a fiber optic connection to each bulb, believe it or not) that indicate not only they're on but they're functioning.
      Here's what I was thinking: A large power resistor with a very low resistance, for instance 20 watt 1K ohm ceramic with an LED in parallel with the resistor, Not only would the light light but the LED would work as long as the light did, indeed, function.
      Of course this depends on the light being less than 20 watts (1.8 amps) and the LED being low enough voltage to work and that there wasn't a dead short. Then the LED is going to be toast with the short. For my nav lights which are all LED this might work, except, of course, it might not. Basically, I'm using the voltage drop across a resistor for the led power.
      There may be a better way (and I'm pretty sure there is) but with my limited electronics background it falls under the category of, “Hey, it should work…” Which, by the way, may not be all that far from, “Hey, guys! Watch this!”
      On Fri, Dec 19, 2008 at 2:58 PM, Pete Dubler < ([email][/email])> wrote:
      Hard astern…
      The LEDs you have must already have a resistor in line. By adding more resistance, you can make them dimmer. A pot would be fine.
      plus lead of LED to output of breaker. ground lead through extra resistor then to ground.
      (Do not try to put the LED and resistor in series with the load the breaker is handling, if that is what you were suggesting).
      Robert Fine wrote:
      Hi Pete,
      On Thu, Dec 18, 2008 at 5:54 AM, Pete Dubler < ([email][/email]) > wrote:
      Robert,
      Robert Fine wrote:
      Hi Pete,
      plasmaled.com <http://plasmaled.com> <http://plasmaled.com>. When I was moored 1/4 mile from the docks at City Island the
      — Bob Fine
      Hull #8
      Hull #8
      Hull #8
    • #71302
      Could be a new way to heat your nav station…
      Each LED has a forward voltage, Vf, and a current limit. Consider those
      things in your design. I’d love to see what you come up with.
      On the other side, there is a circuit that indicates when the bulb is
      burned out. See http://pweb.jps.net/~lschaffer/navltcurrentsensors.html
      By the way, I have their indicator lights on my panel and I love them.
      Easy to see if you have the correct lights on.
      Robert Fine wrote:
      Hi Pete,
      But let’s look at another problem, for instance, where you not only
      not) that indicate not only they’re on but they’re functioning.
      Here’s what I was thinking: A large power resistor with a very low
      wasn’t a dead short. Then the LED is going to be toast with the
      of course, it might not. Basically, I’m using the voltage drop across
      There may be a better way (and I’m pretty sure there is) but with my
      > wrote:
      Hard astern…
      Robert Fine wrote:
      Hi Pete,
      I hadn’t thought about that. To be honest, I was thinking
      across that for the LED’s light, but I’d have to replace the
      wrote:
      Robert,
      have
      go to a
      Robert Fine wrote:
      Hi Pete,
      load
      find
      a red
      was on.
      LEDs from
      cabin
      works out,
      — Bob Fine
      Hull #8
      Hull #8
      Hull #8
    • #71303
      See Pete? I knew you'd show me something new – that's exactly what I'm trying to do – sense current. I suppose I should have looked that up as someone else since the discovery of electricity probably wanted to sense current as well.
      I wonder if they will sense current as low as a couple 10ths of an amp as my nav lights don't draw more than that (all LED).
      Anyway, this may require more thought…
      Thanks!
      Hull #8
    • #71304
      Forgive my old-fashioned simplicity, Bob, but why not just poke your head out of a hatch and look at the lights themselves. If a bulb is burned out you’ll know it because it won’t be lit even though the light is turned on.
      Or am I missing something more profound (which would not be so unusual for me)?
    • #71305
      Ah, Tor, my friend, looking out at the lights would be easy. Too easy. If you are going to have an indicator light, it should do as much as possible – it should encode information that may or may not be gleaned elsewhere or in an easier manner.
      You're right, of course – I'm getting carried away here. I will just dim the lights with a resistor. There are enough real problems for me to deal with on Pelican.
      Thanks, Tor, for bringing me back to reality, such as it is.
      On Fri, Dec 19, 2008 at 6:05 PM, Silver Heels < ([email][/email])> wrote:
      Forgive my old-fashioned simplicity, Bob, but why not just poke your head out of a hatch and look at the lights themselves. If a bulb is burned out you'll know it because it won't be lit even though the light is turned on.
    • #71306
      These do not sense LED level currents unfortunately, but what you really
      need this for is to know that your incandescent bulb has burned out.
      Robert Fine wrote:
      See Pete? I knew you’d show me something new – that’s exactly what I’m
      as my nav lights don’t draw more than that (all LED).
      Thanks!
      Hull #8
    • #71307
      Hi Pete, I know the won't sense the LED levels. But as Tor so kindly and gently pointed out, I could just look up…
      On Sat, Dec 20, 2008 at 10:44 AM, Pete Dubler < ([email][/email])> wrote:
      These do not sense LED level currents unfortunately, but what you really need this for is to know that your incandescent bulb has burned out.
      Thanks!
      Hull #8
      Hull #8
    • #71308
      Ah, for gleaning encoded information I have my Flash Gordon secret decoder ring. It only cost two cereal box tops and a quarter when I got it and it has never failed me. To this day I can always tell when the lights are off.
    • #71309
      I’ve had incandescent bulbs in nav lights fail on passage and always
      wondered how long they were out before I noticed. LED nav lights are a
      relief in that regard.
      Tor is right of course. Like the old pilot saying goes… “when
      everything else fails…. fly the plane”.
      Robert Fine wrote:
      Hi Pete, I know the won’t sense the LED levels. But as Tor so kindly
      burned out.
      what I’m trying to do – sense current. I suppose I should
      of an amp as my nav lights don’t draw more than that (all LED).
      Thanks!
      Hull #8
      Hull #8
    • #71317
      Hi All
      Really enjoy being in the pearson424 loop.
      Please change my email address to () and remove ().
      We have a blog http://sailblogs.com/member/mariposa216/
      I sold my charter business of 16yrs and headed off on a 2-3 yr cruise 14 Oct..
      Interesting being with LOOPERS going down the Illinois, Mississippi, Ohio, Tennessee & TenTom Waterway to Mobile. Got mast stepped there (Turners) and on to Penscola, Panama City, Clearwater (the Gulf can really get nasty in a passing front) and presently in St Petersburg while other half finishes requirements for USCG license (done today) Plan to go on to Long Boat Key, Charlotte Harbor, Marathon, Key West and Yuctan Mexico and on.
      Still need to upgrade SSB radio – have very old ICOM IC700. Shirley & I both working on HAM licenses and will probable go for a new ICOM 803 comb Marine/HAM rig. Need advice and input on this.
      Seasons greetings to all
      Capt John & Shirley
      n a message dated 12/20/2008 11:06:20 A.M. Eastern Standard Time, writes:
      burned out.
      Thanks!
      Hull #8
      Hull #8
