Forums › General Discussion › Electrical problems
Viewing 8 reply threads
    • #68623
      Jack Clarke
      Hi everybody,
      I have been experiencing some electrical problems for the last little while
      and I can’t track down the problem. The meter that I had installed back in
      May says that I an discharging power somewhere and I can’t find it. My
      electrical skills are very basic.
      Does anyone know of a good electrical guy in the Deltaville / Norfolk area
      that is reasonable. Or anywhere south of there, we are flexible as we are
      en route to the Bahamas. We will be in Deltaville most likely today and
      Norfolk by Sunday possibly.
      The internet coverage is patchy to non-existent at times so please bare
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78816
      Jack- I am aboard here in Deltaville. Give me a call at 540-400-2434. I am
      not an electrician, but I have an idea or two of someone to help, if they
      are available on short notice.
      In a message dated 9/28/2012 6:51:06 A.M. Eastern Daylight Time,
      writes:
      Hi everybody,
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78817
      Hi Jack,
      Can you describe them? AC or DC? A particular item or a bunch of items?
      I’m sure there are people on the site that can give you some great ideas
      for tracking them down and dealing with them.
      Glad to see you’re making your way south! I wish I was there…
      On Fri, Sep 28, 2012 at 6:50 AM, Jack P Clarke wrote:
      Hi everybody,
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78818
      Jack Clarke
      Hello everyone,
      The problems that I’m having are on the DC side of things. When running
      the engine all day, the house bank only gets up toabout 13.3 V, Then when
      I sut it down it drops to 12.9 and lower quite fast, in an hour or two.
      This happens when there is basicaly nothing on. The same thing happens
      after being hooked up to shore-side power or a generator.
      The starter battery is no problem @ 14.5 V.
      I had both alternators rebuilt in May, the house bank is charged by a
      Balmar 100 amp. and the start battery is charged by a 40 amp boshe. I put
      a new voltage regulator in for the Balmar in August. The start battery was
      new in April, the windlas/bow thruster battery new in June and the house
      bank new in August.
      In May I had a guy do some work on the boat and one of the thinggs he put
      in was a BEP Marine DC/AC meter and it tells you the charging rate as well
      the discharging rate and it shows something is drawing a lot of amps, and
      this is with everything shut off.
      I don’t know where or how to look for the problem.
      Bill I will give you a call tomorrow morning. I’m in Jackson’s Creek right
      in front of the marina.
      Jack
      Xanadu IV
      On Fri, Sep 28, 2012 at 7:56 AM, Robert Fine wrote:
      Hi Jack,
      wrote:
      Hi everybody,
      while
      in
      area
      are
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78819
      More questions….
      How old are you batteries?
      Did you check the water level in the batteries?
      When were the batteries last equalized?
      If you do not now own these books, I highly recommend them.
      Nigel Calder: Boatowner’s Mechanical and Electrical Manual
      http://www.amazon.com/Boatowners-Mechanical-Electrical-Manual-Essential/dp/0071432388/ref=sr_1_1?ie=UTF8&qid=1348882113&sr=8-1&keywords=nigel+calder%27s+boat+owners+mechanical+and+electrical+manual
      Don Casey: Sailboat Electrics Simplified
      http://www.amazon.com/Sailboat-Electrics-Simplified-Don-Casey/dp/0070366497/ref=la_B001IGOSIK_1_3?ie=UTF8&qid=1348882191&sr=1-3
      @DeepPlaya |
      W7PEA
      On Fri, Sep 28, 2012 at 9:22 PM, Jack P Clarke wrote:
      Hello everyone,
      bank new in August.
      Jack
      Xanadu IV
      Hi Jack,
      wrote:
      Hi everybody,
      while
      back
      in
      area
      are
      and
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78820
      Jack,
      Sounds to me like you may have two problems.
      1. The Balmar is not outputing a full charge to your house bank. You
      don’t say what type of battery you have in the house bank, but no matter
      the type the charge voltage should be over 14V. I would suspect a fault
      or set-up problem in the regualator. The battery voltage should drop down
      to below 12.9 shortly after the charging stops. So this sounds normal.
      What is the voltage when on shore power?
      2. The battery monitor shows a significant discharge when everything is
      turned off. I assume this a just a couple of amps and all of the breakers
      on the panel are off. In that case I would look at the circuits that do
      not go through the panel breakers (SSB radio?). However, first I would
      insure the battery monitor is installed and working properly.
      Good luck.
      On Fri, Sep 28, 2012 at 9:31 PM, Peaboy Walters wrote:
      More questions….
      @DeepPlaya |
      W7PEA
      wrote:
      Hello everyone,
      when
      put
      was
      bank new in August.
      well
      right
      Jack
      Xanadu IV
      Hi Jack,
      items?
      ideas
      wrote:
      Hi everybody,
      while
      back
      in
      My
      area
      we
      are
      and
      bare
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78821
      Jack, I don’t have an electrician here today but may be able to get one to come in. I’m in the office above the marina.
    • #78822
      The first thing I would do would be to get your batteries load tested.
      A bad battery or one that is sulfated will show as a bad regulator. A bad battery in a group of four will show all of them being bad also.
      If you see Bill in Deltaville he can tell you of my experience last year it got to be very expensive buying batteries out of the country. Everyone thought it was the regulator but the regulator tested out fine and in fact it was badly sulfated batteries and equalizing them would not bring them back
      On Sep 29, 2012, at 6:04 AM, John Stevenson wrote:
      Jack,
      Good luck.
      More questions….
      @DeepPlaya |
      W7PEA
      wrote:
      Hello everyone,
      when
      put
      was
      bank new in August.
      well
      right
      Jack
      Xanadu IV
      Hi Jack,
      items?
      ideas
      wrote:
      Hi everybody,
      while
      back
      in
      My
      area
      we
      are
      and
      bare
      with me on replies.
      Jack Clarke
      Xanadu IV
    • #78823
      before you go too far, check the volt meter itself by using another
      meter at the battery directly.’
      On 9/29/2012 4:04 AM, John Stevenson wrote:
      Jack,
      Good luck.
      More questions….
      @DeepPlaya |
      W7PEA
      wrote:
      Hello everyone,
      when
      put
      was
      bank new in August.
      well
      right
      Jack
      Xanadu IV
      Hi Jack,
      items?
      ideas
      wrote:
      Hi everybody,
      while
      back
      in
      My
      area
      we
      are
      and
      bare
      with me on replies.
      Jack Clarke
      Xanadu IV
