Forums › General Discussion › Electrical Terminal Protection
- This topic has 18 replies, 7 voices, and was last updated 17 years, 4 months ago by
June 15, 2009 at 2:30 pm #67542
I’ve got a Lofrans electric windlass with a control box mounted high up in the chain locker. I’ve just
discovered that the terminals on this box – connecting the power in, ground, foot switches and power to the
windlass motor – are gunked up and, in fact, shorted out with the kind of green corrosion you find on
neglected battery terminals. Anybody know the best stuff to put on those terminals once they’re cleaned up, to
prevent a recurrence?Tor
June 15, 2009 at 2:39 pm #72854
john stevensonParticipantTor,
Other than moving the control box out of the locker (I assume not practical) you might try encasing the contacts in silicone.On Mon, Jun 15, 2009 at 10:29 AM, Silver Heels < ([email][/email])> wrote:
I've got a Lofrans electric windlass with a control box mounted high up in the chain locker. I've just
neglected battery terminals. Anybody know the best stuff to put on those terminals once they're cleaned up, to
June 15, 2009 at 2:48 pm #72855
RichCarterParticipantTor
There’s a spray coating made specifically for battery terminals. Its usually blue or red in color and is sticky. I think I last purchased it from Walmart. If they don’t have it, try an auto-parts place.Regards
June 15, 2009 at 3:33 pm #72857
If you mean silicone sealant, I tend to avoid using that stuff. Inevitably I find myself having to service the fitting on which I put it, and then there’s hell to pay. Very difficult to clear away once it’s set up.
June 15, 2009 at 3:33 pm #72858
I KNEW you’d know, Rich. Thanks.
FYI, I looked it up in “The 12-Volt Bible for Boats” while I was waiting to hear back from the group. In the section on Battery Maintenance and Tools the author suggested, “A little petroleum jelly or oil will help to prevent future corrosion.”
June 15, 2009 at 4:53 pm #72859
ModeratorTo amplify your comment, Tor, silicone is not adhesive – it is a compressive sealant (like a gasket but much more annoying). Slathering a terminal with the stuff will not only make servicing difficult but will also guarantee that corrosion will take place out of sight resulting in a failure at the most inappropriate time. Silicone really has no place on a boat except, perhaps, a dab on the end of cotter pins on the pins that hold the standing rigging turnbuckles to the chainplates. I know there's a name for those pins but am having a brain fart and cannot remember what they're called.
Rich's recommendation is spot on.
On Mon, Jun 15, 2009 at 11:07 AM, Silver Heels < ([email][/email])> wrote:
Quote:I KNEW you'd know, Rich. Thanks.FYI, I looked it up in “The 12-Volt Bible for Boats” while I was waiting to hear back from the group. In the section on Battery Maintenance and Tools the author suggested, “A little petroleum jelly or oil will help to prevent future corrosion.”
June 15, 2009 at 5:16 pm #72861
SpectatorI have been wondering about this myself and while petroleum jelly is recommended (some say grease others say no to grease, so go with no) the idea of something that can smear all over things isn’t appealing to me. There is a commercial product call NCP-2 which is widely available from a variety of stores. Defender sells it in a kit with a terminal cleaner. This link has the best picture of the product: http://www.sbsbattery.com/subpage_index.php?_subp_=114
I’ll probably stop in at my local auto parts store and see what they’re selling as well and just go with that.
June 15, 2009 at 6:11 pm #72863
That looks like the right kind of stuff, Pat. Rich’s suggestion also sounds like it would do the trick. Unfortunately, for this round I’m limited to what’s already on board. I’m anchored out, the dinghy’s in the davits and I’m too lazy – too busy fixing things, actually – to make the expedition to town to buy something. So I’m using Vaseline petroleum jelly on my windlass control box terminals, as per “The 12-Volt Bible for Boats.” Guess I’ll know in a few months how well it works. Next shopping trip I’ll pick up some of the more advanced stuff.
Speaking of miracle goops, I “discovered” Lanacote rust and corrosion protection a few months ago when I was putting stainless bolts into aluminum. They say you can remove the screw years later as easily as day one. Truly, THIS is the golden age of sail.
June 15, 2009 at 6:28 pm #72864
ParticipantTor:
I am pretty sure John was probably talking about using silicone grease, which is pretty good for protecting electrical connections, among other things:
http://www.satcure.co.uk/tech/silicone.htm
http://www.satcure.co.uk/tech/silicone.htmPaul
June 15, 2009 at 6:45 pm #72865
You can get a large tube of “dielectric grease at an auto parts store in
the electrical dept. Small tubes are expensive, large tubes are cheap…I also like to wrap connections with CoaxSeal, a self-adhering tape.
Good price on it from AllElectronics.comPete
Paul Lefebvre wrote:
Quote:Tor:I am pretty sure John was probably talking about using silicone
among other things:http://www.satcure.co.uk/tech/silicone.htm
June 15, 2009 at 6:48 pm #72866
john stevensonParticipantYes, I was not referring to silicone sealant as found in WM stores, but a dielectric compound. I can't remember the name of the stuff I've used in the past, I think I picked it up at an electrical supply house. It may not be the best choice for this application, but I'm also not sure that the spray on battery terminal stuff will be that effective in the wet, corrosive atmosphere of your anchor locker.
On Mon, Jun 15, 2009 at 2:28 PM, Paul Lefebvre < ([email][/email])> wrote:
Quote:Tor:I am pretty sure John was probably talking about using silicone grease, which is pretty good for protecting electrical connections, among other things:
June 15, 2009 at 7:33 pm #72867
Will wonders never cease? That looks like great stuff. Thanks, Paul.
June 16, 2009 at 1:58 am #72872
ParticipantI’ve used the terminal sealant sold by auto part stores and it is red and nasty. I’m addicted to spray lithium grease. Easy to reapply and clean up. The red stuff is sticky and runs, yuck.
June 16, 2009 at 11:47 am #72873
Darn! Wish I’d thought of lithium grease yesterday. I have some aboard and could’ve used it instead of Vaseline.
Oh, well, next time. Now at least I’ll get to find out for myself how well the old home remedy works.
June 16, 2009 at 12:24 pm #72874
ModeratorHi Tor,
Vaseline will do the job nicely – as well as lithium grease. Don’t
regret using it. It’s also easier to clean off if you need to.Bob
On 6/16/09, Silver Heels <> wrote:
Quote:Darn! Wish I’d thought of lithium grease yesterday. I have some aboard and
could’ve used it instead of Vaseline.Oh, well, next time. Now at least I’ll get to find out for myself how well
the old home remedy works.Tor
June 16, 2009 at 12:53 pm #72875
Thanks, Bob. I have few regrets in my life; using Vaseline has never been one of them.
June 16, 2009 at 1:16 pm #72876
ModeratorI, for one, cannot wait to meet you, Tor!
Original MessageQuote:<.. snip>Post generated from Pearson424 Forum using Mail2Forum
June 16, 2009 at 1:52 pm #72878
ParticipantOK now you boys are starting to scare me!
June 16, 2009 at 1:56 pm #72879
Welcome to the club. I’ve been scaring myself for decades.
