Forums › General Discussion › Empty space under seat in the shower
Viewing 5 reply threads
    • #68364
      Hi all,
      Since moving on the boat and using the shower pretty much everyday has made fighting the water and scum build up in the seat area in the shower the bain of my existence. We don’t use the space for anything since it never dries out. I was wonderinf if anyone has just filled in the space and sealled it off? And if so, what did you fill it with? I was thinking of using that spray foam stuff and then creating a gasket of sealant around the top edge and screw down the seat cover.
      Dawn
      S/v Deep Playa
      On Jun 17, 2011, at 10:00 AM, wrote:
      Send maillist mailing list submissions to
      To subscribe or unsubscribe via the World Wide Web, visit
      or, via email, send a message with subject or body ‘help’ to
      You can reach the person managing the list at
      When replying, please edit your Subject line so it is more specific
      than “Re: Contents of maillist digest…”
      Today’s Topics:
      1. Re: Rendezvous Planning Update 2 ( Thatcher A. Stone)
      2. Re: Rendezvous Planning Update 2 (Robert Fine)
      3. Garhauer Vang Model (Patrick “Peaboy” Walters)
      4. Re: Garhauer Vang Model (Pete Dubler)
      Message: 1
      Date: Thu, 16 Jun 2011 19:49:14 -0400
    • #77367
      patn
      Really – it’s always wet? I use a cork to seal it .. and then put dirty
      shirts and other not so big things with detergent just before we take
      off… works great as a small washing machine for us. Does it work for
      us because we’re in fresh water?
      – pat
      SV Doris E, p424 #178
      Dawn Rodney wrote, On 6/18/11 1:39 PM:
      Hi all,
      Dawn
      S/v Deep Playa
    • #77368
      I keep 3 things in that space: shampoo, a scrubber sponge, and a small
      pail. The scrubber sponge is for the dirt ring around the shower pan,
      The pail is for catching the cold water that comes from the shower
      nozzle before the hot water reaches it, water that would otherwise be
      wasted. Then I add a little hot water to it and use it for bathing.
      The mini clothes washer is a great idea. I do the same thing with a
      bucket (with a tight lid), which I lash on the foredeck where the motion
      is most amplified. When conserving freshwater, you can wash & rinse
      clothes in seawater, and then give a final, frugal rinse in fresh to
      remove the salt. Works great!
    • #77369
      Like Tor, I keep three things in that space – shampoo, a scrubber sponge
      (for the same reason) and a fake chamois called ‘The Absorber’ (about $15 at
      West Marine, less at auto part stores) for wiping down the shower except for
      the ring.
      Twice a year I clean it super well and wax it with the Starbrite PTFE
      cleaner wax and it lasts for quite a while.
      In addition, I keep the seat top inboard of the head so the pit is always
      open and dries. Also, I have a clip with a hook that’s attached to the
      middle of the shower curtain. When I’m done, I hook it to the lip under the
      portlight so that the curtain dries and there isn’t an area of wet under
      plastic on the floor and wall of the pan.
      Sounds complicated, huh?
    • #77370
      Mine drains. Not all 424’s are the same however so if yours is holding water you might look at building up the bottom a little to pitch it so that it drains. At that, water will still get in there when you shower so cleaning would be needed. We use X14, a mildew cleaner that works very well.
      Hardware stores sell a type of rubber gasket material that is used on home windows as a weather sealant. The stuff comes in a small roll and has two beads of self-sticking gasket. The rubber is soft and makes a good seal. I used this stuff on my ice-box lid to seal it tight. While my lid has been replaced to remove the hinge, the same gasket would work on the hinged top and would probably work on the shower seat. You might keep the water out of the seat-tub, but now you’ll have a gasket to clean 🙁
      BlackSheep #47
    • #77371
      I really like the ideas! I will try the washing machine idea when we head
      out for our trip up to the San Juans in a couple weeks. Have you had any
      issues with the sump pump becoming gunked up from the residue from the
      detergent? And I am going to search for a bucket to fit in that space to
      capture the water.
      Thanks guys for the awesome ideas! I am going to keep that space and try it
      out.
      Dawn
      s/v Deep Playa
      Today’s Topics:
      1. Empty space under seat in the shower (Dawn Rodney)
      2. Re: Empty space under seat in the shower (pat noordsij)
      3. Re: Empty space under seat in the shower (Silverheels)
      4. Re: Empty space under seat in the shower (Robert Fine)
      Message: 1
      Date: Sat, 18 Jun 2011 13:39:22 -0700
