Forums › General Discussion › etching new fiberglass
- This topic has 8 replies, 5 voices, and was last updated 17 years, 6 months ago by
madsailor.
April 24, 2009 at 8:08 pm #67483
ParticipantDoes anyone know the acid/solvent used for etching new fiberglass, to remove the surface wax?
April 24, 2009 at 8:14 pm #72547
RichCarterParticipantI use interlux 2333n
BlackSheep #47
April 24, 2009 at 8:17 pm #72548
patn
ModeratorAre you asking about removing all the mold release from the
fiberglass? If so Interlux 202 or MEK.– pat
the surface wax?Tor
For additional commands, e-mail:—
Sent from my mobile device
April 24, 2009 at 8:23 pm #72549
Usually a combination of solvents, though acetone is effective.
Try this link.http://www.westmarine.com/1/1/30955-95-fiberglass-dewaxer-solvent-quart-from-pettit.html
— On Fri, 4/24/09, Silver Heels <> wrote:
April 24, 2009 at 8:26 pm #72550
RichCarterParticipantOops, sorry, 202 is the right stuff, not 2333n. Got my jugs mixed up.
If its your bottom you’re cleaning, here’s a link to the interlux instructions.
http://www.yachtpaint.com/USA/hotlinks/fiberglass_paintguide.pdf
April 24, 2009 at 8:56 pm #72551
ParticipantThank you all for those suggestions. Was hoping for something generic and likely to be lying around already,
like MEK or acetone, since I only need to etch the few square feet of my new windvane rudder & trim tab below
the waterline. I’ve already sanded the surfaces thoroughly with 60-grit wet and would be surprised if any
surface wax remains, but I want to be sure.Thanks again.
April 24, 2009 at 10:36 pm #72552
yes, MEK or acetone will work…just don’t breathe any vapors…both are carcinogen suspects.
April 24, 2009 at 11:41 pm #72553
ParticipantThanks, Joseph. I’ll be careful with the vapors. Gave that stuff up in favor of beer years ago.
April 25, 2009 at 10:26 am #72554
ModeratorHi Tor,
I'll weigh in on the subject – acetone will do the job. You're just removing wax, grease, or release agent and it does the trick. And you're more likely to have it hanging about. MEK works, too, but I avoid using it because of it's ability to be absorbed through the skin.
Good luck with the job!
Bob2009/4/25 Silver Heels < ([email][/email])>
Quote:Thanks, Joseph. I'll be careful with the vapors. Gave that stuff up in favor of beer years ago.Tor
