Forums › General Discussion › Follow Up on Transmission Failure
    • #69113
      Start of attached email. Subject: Re: Follow Up on Transmission Failure
      On Feb 18, 2011, at 10:04 AM, John Stevenson <> wrote:
      I’m surprised that you will have to lift the engine to remove the
      transmission. It certainly was not required with my Yanmar. It is the same
      Velvet Drive as I believe are on most W58s. The replacement plate purchased
      from Mack Boring does not have springs. Here are a couple of pictures.
      http://www.svsarah.com/Sarah/Images/OldPlatevrsNewPlate2.JPG
      http://www.svsarah.com/Sarah/Images/NewPlatInstalled.JPG
      The first pictures is of the new plate (foreground) and the old plate
      (background). The second picture is the new damper plate installed on the
      engine. This looks like an R&D (PYI company) plate, and checking the Mack
      Boring website it appears they are now specing R&D dampers and couplers.
      On Fri, Feb 18, 2011 at 9:36 AM, Alan <> wrote:
      With the W58 and the way it’s tucked in there. I would probably just a
      block chain fall to lift up the back end of the engine enough to be able to
      slide the transmission off…… maybe a days work figuring I would not have
      to disconnect too much.
      There is not that much to the damper… a plate and a few springs. I wonder
      if the springs are just to heavy and not allowing it to ” damper”
      — On Fri, 2/18/11, John Stevenson <> wrote:
