Forums General Discussion Follow Up on Transmission Failure
Viewing 7 reply threads
    • #68256
      I think my last post on the subject of my transmission failure was that the
      re-built transmission and new damper plate were installed and the gear
      backlash noise in the V-draw is negligible,.
      Because of that, it is evident to me that the damper plate was DOA from Mack
      Boring, I went back to my installer to see if I could get some
      compensation for the early failure of the transmission.
      Not surprisingly, Mack Boring declined to provide any consideration even
      though the evidence (MO) was that the damper plate failed on delivery, well
      within the warranty period. However, my installer – Zahnisher’s Yachting
      Center in Solomons, MD – did provide a significant level of compensation
      even though they (IMO) were not at fault and they did not admit to any
      responsibility for the transmission failure.
      So my recommendation is that if you need service from a responsible yard in
      the Chesapeake Bay, consider Zahniser’s as one of your first choices.
      Conversely, if you are choosing a product supported by Mark Boring (Yanmar
      being the prominent one), my recommendation is to look elsewhere.
      That said, I am sympathetic to the warranty issues of providers of
      mechanical devices such as engines and transmissions. Once their products
      are delivered to a consumer they lose total control of how that product is
      operated. For a claim oiutside of the warranty period (such as they believe
      is mine) it is prohibitively expensive to establish whether product failure
      or owner abuse was the cause of a failure. Hence the very brief warranty
      periods for equipment that should provide many years of service. However,
      in my case, I think I should have received some consideration that there
      was ample evidence that the damper plate provided by Mack Boring was either
      DOA or failed when the engine was initially placed in gear (well within the
      Warranty period). The backlash noise was very loud from that point until
      the damper plate was replaced after the transmission was re-built. Although
      not a definitive proof, I believe it should have made Mack Boring at least
      consider that their product might be at fault. if they were not willing to
      admit that the transmission failure was due to the damper plate failure, at
      least admit that the product they delivered (i.e., the damper plate) failed
      during the warranty period. I would have accepted compensation for the
      replacement of the damper plate, but no such offer was forthcoming from
      Mack Boring.
      FWIW, I might have thought my installer should have recognized this problem
      during the installation and fixed it then. However, I had more than one
      boat yard (all Mack Boring/Yanmar dealers) investigate the gear backlash
      problem, and they all reached the same conclusion that it was just a
      normal, low RPM, gear backlash Walters V-drive characteristic. So even if
      this problem was reported to Mack Boring before the transmission failure, I
      believe they would have reached the same reasonable conclusion – this is
      what happens with a Walter V-Drive. So my issue with Mack Boring is not that
      their authorized dealers and service reps didn’t find the problem before the
      transmission failed, but that once the problem was finally identified they
      could care less (unless I reported the problem within the warranty period).
      Bottom Line: Zahniser’s Yachting Center are the good guys. Mack
      Boring/Yanmar maybe not such good guys.
      I guess I should also state that I have been a customer of Zahniser’s for
      over 35 years, so maybe that counts for something. Mack Boring still
      pisses me off.
    • #76766
      Well said! We could use more of that kind of human feedback.
    • #76767
      I’m not impressed with MacK Boring either. When I ordered my Yanmar, I ordered a spacer plate for the bell housing to mate up with the BW transmission. They quoted and sold a spacer that was too thin. I had no way to know how thick the spacer should be and trusted them to quote the right parts. I ended up buying another spacer, only $120, but it ticked me off because it was their error.
    • #76768
      What worries me now, is that the noise I am getting is  from the VDrive, but because of a bad NEW damper plate.
      Could be a B***** to replace now that I have engine back in….
      — On Fri, 2/18/11, wrote:
    • #76769
      If you’re getting some rattle at low speeds don’t worry. If whine at high
      speeds, go to gear oil instead of 30wt. Like 50wt or even 80 wt.
      Remember, these drives are usually hooked up to big noisy gasoline engines
      so you don’t hear them. Also, those engines idle faster than diesels.
    • #76770
      Alan,
      Pulling the transmission does not appear to be a lot of fun, but maybe not
      that big a deal. That said by the guy whose only experience with the task
      is watching a couple guys remove mine and then re-install it. It is a two
      person job though. It was about 1/2 hour each way, off and on. Just don’t
      drop that sucker in the bilge.
    • #76771
      With the W58 and the way it’s tucked in there. I would  probably just a block chain fall to lift up the back end of the engine enough to be able to slide the transmission off…… maybe a days work figuring I would not have to disconnect too much.
      There is not that much to the damper… a plate and a few springs. I wonder if the springs are just to heavy and not allowing it to ” damper”
      — On Fri, 2/18/11, John Stevenson wrote:
    • #76772
      I’m surprised that you will have to lift the engine to remove the
      transmission. It certainly was not required with my Yanmar. It is the same
      Velvet Drive as I believe are on most W58s. The replacement plate purchased
      from Mack Boring does not have springs. Here are a couple of pictures.
      http://www.svsarah.com/Sarah/Images/OldPlatevrsNewPlate2.JPG
      http://www.svsarah.com/Sarah/Images/NewPlatInstalled.JPG
      The first pictures is of the new plate (foreground) and the old plate
      (background). The second picture is the new damper plate installed on the
      engine. This looks like an R&D (PYI company) plate, and checking the Mack
      Boring website it appears they are now specing R&D dampers and couplers.
