Forums › General Discussion › Found the place
Viewing 8 reply threads
    • #68959
      where all the nuts and bolts and washers and some tools go when you drop them and never find them again.
      You’d be surprised the places you can go when you don’t have an engine or fuel tank in the boat. Forward side of starboard sail locker, all the way down in the corner.
      I actually thought I’d find a TV remote or two in there.
      Unabated
    • #81321
      Occasionally I happen upon an errant screw or nut that
      I’m sure was dropped by a Pearson workman in 1977.
    • #81322
      How about in those deep sharp edged boxes of the engine bed frame. A couple
      of those places were holding water, washers, nuts, screws, bolts, zip-tie
      cut-offs and accumulated caca in general. I found with the engine in, you
      can’t get an arm to bend into them. A past owner had drilled small holes
      but really didn’t get close enough to the lowest spot. I had to go in from
      “under” the actual frame and drill almost blind through some wood wedges to
      get a decent 5/16″ hole to the bottom of them.
      ken
      On Sat, Jul 19, 2014 at 11:58 AM, Alan via maillist <
      down in the corner.
      Unabated
    • #81323
      I believe I have almost a full set of sockets down there somewhere. Hoping they’ll eventually roll out for rescue.
      Keehi Lagoon, O’ahu
    • #81324
      Ferrous metal sockets are easy. Just poke around with
      one of those magnets on a stick. It’s the stainless
      stuff that’s challenging.
    • #81325
      I can’t imagine what it is like to have a boat with an aluminum hull where you cant leave any dropped stainless hardware because of electrolysis eventually rotting through the aluminum.
    • #81326
      I thought that too but there is a but driver somewhere in my bilge that must repel the magnet… Just had to get a new but driver…
    • #81327
      Must be a negative but driver.
    • #81328
      Ahhh darn spell checker… But driver
