Forums › General Discussion › Free-Wheeling Prop
Viewing 7 reply threads
    • #68693
      Bob,
      I gather some transmissions can handle a free-wheeling prop under sail while
      others are damaged by it, presumably because the transmission oil isn’t
      circulating adequately when the engine is off. Some transmissions lock when
      you put them in gear. I wish mine did! When my prop free-wheeled, as it did
      when I bought this boat, the noise spoiled the sailing ambience for me. So I
      installed a Shaft-Lok. I’ve had my share of problems with it, but when it’s
      working it’s great.
    • #79273
      Hi Tor,
      I use the spinning shaft for power – over about 5 knots, I get more than
      enough power run the autopilot, instruments, and refrigerator. So I like
      that – it only takes about half a knot off the speed and it keeps the
      batteries charged.
      There are, apparently, three different transmissions used on the 424s,
      mine, one that locks (I think a Hurth), and another that’s not supposed to
      freewheel. If yours was freewheeling when you got the boat I have to
      believe it’s ok – you have one like mine. Locking it is optional.
      I may very well be wrong here, but it seems to me a big three bladed prop
      dragging through the water locked creates more drag than one spinning with
      no load (I know there’s a load with the alternator – at full speed, it’s
      about 16hp). I’m sure there’s some kind of study on this.
      Anyway, there’ve been discussions about this before.
      On Tue, Mar 26, 2013 at 3:29 PM, Silverheels wrote:
      Bob,
      while
      I
      working it’s great.
    • #79274
      Actually, my Paragon transmission self-destructed soon after I bought the
      boat, requiring a complete rebuilt by a specialty shop here. So maybe
      freewheeling wasn’t OK for it. (Or maybe it was because the PO never changed
      the fluid. Or both.)
    • #79275
      I think that’s what I have and it’s gone 10000 miles that way. It may be
      lack of maintenance.
      changed
    • #79296
      Bead Game
      Those boats that a Warner velvet drive transmission had a prop lock installed. The Warner transmission should not free wheel as there is no lubrication when the engine is not runnning.
      The original Proplock was hydraulicly deactivated by transmission oil pressure. This has worked fine. However the company that made it is very long out business.
      I have been able to fabricate my own break pads as the old ones wore out. Recently the bronze casting began to fail. I installed a reconditioned feathering Max Prop to avoid free wheeling. It has worked.
    • #79298
      Lee,
      Your statement about the Velvet Drive tranny is inconsistent with what the
      Velvet Drive tech reps have told me. Until engine starts to turn the gears
      in the tranny are not engaged and do not turn. The only thing turning is
      the output spline, none of the internal parts are turning.
      Anyway that’s what I have been told on repeated inquiries to mechanics and
      tech reps familiar with the Velvet Drive.
      long out business.
      Lee Hirsch
      Out of da Bronx
    • #79299
      I must admit there has been a lot of inconsistent information on the
      subject of free-wheeling Velvet Drives. I wonder if that inconsistency is
      because the vast majority of installed VDs have a reduction gear. That
      reduction gear may be turned by the free-wheeling prop and could be
      damaged. As far as I know all 424s have a direct drive VD with the
      reduction gear in the V-Drive. That was the context of my discussion with
      the VD experts.
      On Sun, Mar 31, 2013 at 11:34 AM, John Stevenson
      wrote:
      Lee,
      long out business.
      Lee Hirsch
      Out of da Bronx
    • #79300
      I’ve been through the manuals for all three transmissions. Velvet drive
      can freewheel in neutral, should not be left in gear. Paragon needs to be
      locked either through a brake (that’s the transmission the 424 came with a
      brake for) or folding/feathering prop. Doesn’t self lubricate. And the
      Hurth which can rotate or be locked in reverse. The reverse lock is the
      preferred method.
      On Sun, Mar 31, 2013 at 11:47 AM, John Stevenson
      the VD experts.
      wrote:
      Lee,
      the
      gears
      and
      long out business.
      Lee Hirsch
      Out of da Bronx
