Forums › General Discussion › from Chain locker to the bilge
  • This topic is empty.
Viewing 3 reply threads
    • #226078
      John Livi
      Hello, recently during a sailing trip to Menorca I saw that the some salt water from the waves breaking on the bow was entering into the chain locker and flowing below the bow cabin floor, down near the mast, below the saloon table and down into the bilge. Is it the same configuration in all the Pearson 424 ?
      I think it’s a good idea to keep the weight of the chain lower, into the anchor well, down into the bow. But like this we always have the bolts of the mast basement below the water. And water in the bilge. I spoke with a FRP technician here and he told me he had never seen a sailing boat with this configuration. According to him That shouldn’t be the best solution if the bilge pumps stop functioning and the waves go on breaking on the bow. So he suggested closing that passage leading water into the bilge and create two small holes as drains into the hull.
      Considering the general low quality of general configuration in more modern “plastic fantastic” I’m not too worried about that, relying more in the know-how and wisdom of Bill Shaw. And considering how these boats were well designed and built.
      But is there a way to avoid having water flowing from the chain locker ? Is it accepted as normal and we just have to pump out from the cockpit manual pump from time to time ? Or someone has solved the problem somehow ? If it’s a problem.
    • #226081
      I never liked the fact that the salt water from the anchor locker flowed to the bilge and sat around the base of the mast. I know some owners have glassed the bottom of the anchor locker and put a drain overboard at the bottom of the locker. It is still on my list.
    • #226097
      I purchased some lamp wick that I drape from the area around the mast base and into the bilge. Didn’t think it would do any good but it did! Of course water still gets around the mast base but at least it wicks out. The mast base area is generally dry.
    • #226098
      I haven’t completely solved the problem of standing salt water around the mast base but did come up with a partial solution. I draped a length of lamp wicking material, about 1 or so inches wide, from the area in question into the bilge. Didn’t think it would do much but it did. Water will still accumaulate around the mast base but wicks surprisingly quickly into the bilge. At any given time I check the mast base area for moisture it is generally very dry…
