Forums › General Discussion › Fuel Consumption
Viewing 8 reply threads
    • #66985
      Actualy I am rather embarrassed to say “I am not
      sure”.
      The four or five trips I have made up to the 1000
      Islands (about 80 – 90 miles) with this boat, I
      figured I got about 1 to 1&1/4 Gallons/Hr – speed
      around 6.5 to 7 knots RPM’s 2200.
      Since Ive repitched the prob last summer, I have not
      taken any long trips – just the 3 mile hike to the
      outlet to sail.
      I havent kept track of the usage.
      At 2500 RPM’s the ass end of the boat really gets
      buried and it takes two hands to steer but the 7.5
      knots get’s me out the lake sooner. At 5$ a gallon
      I’ll be more careful in the future.
      I wished there was a better way to guess fuel
      consumption. Motoring a couple of miles and then
      heading back to the fuel dock on Sodus Bay is PITA.
      Oh, and our fuel gauges work so well!
      Maybe I’ll make a point to do a better job this summer
      since I won’t be able to sail for awhile – Getting my
      arm fixed.
      How did you come up with those numbers?
      — Robert Fine <> wrote:
      Really? I cruise at 1900-2000 rpm at 6 to 6.5
      knots. I can get the engine
      up to 2400 rpm, but by that point it’s trying to
      climb out of the water.
      At 1900 rpm it’s burning about 3/4 gallon per hour.
      At 2200, it’s burning
      nearly 2 gal/hr. Since the gain in speed of at most
      a knot isn’t worth it,
      I just cruise right along.
      What are your experiences with speed/rpm/fuel
      consumption?
      On Thu, May 8, 2008 at 3:17 AM, alan P
      <> wrote:
      I repitched mine from a 13 to a 12. Mainly because
      I
      thought I should have more engine RPM’s before the
      engine started to bellow black smoke. I have a W58
      and
      now can get it past 2800 rpms. Not that I ever run
      it
      that high, mostly cruise at 22 to 2400.
      — Syringa <> wrote:
      Patrick
      Hope you had a good trip back from Bellingham!
      I
      have been looking into the prop pull on Syringa
      as
      you know. (This is when the vessel is under
      steady
      steaming in forward at 1800 rpm or above)
      (not
      backing or docking) I don’t believe the shaft
      is
      off set (if it is it’s not much) and should not
      account for that much pull. The prop may be
      over
      pitched. I will let you know if or when I come
      up
      with the answer.
      I would like to hear from anyone who has changed
      propellers or reduced the pitch.
      Don
      Syringa
      know-it-all with Yahoo! Mobile. Try it now.
      http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
    • #69804
      Hi Alan,
      I came up with the numbers (which are very close to yours, by the way, at least before you re-pitched the prop) by filling the tank, running for 10 hours to get somewhere in no wind and then filling the tank again. Believe me, that's not what's going to happen this year as last year when I bought the boat my goal was to empty the three year old fuel as quickly as possible.
      That's not the case this year…
      sure”.
      around 6.5 to 7 knots RPM's 2200.
      outlet to sail.
      At 2500 RPM's the ass end of the boat really gets
      knots get's me out the lake sooner. At 5$ a gallon
      I'll be more careful in the future.
      Maybe I'll make a point to do a better job this summer
      since I won't be able to sail for awhile – Getting my
      arm fixed.
      up to 2400 rpm, but by that point it's trying to
      At 1900 rpm it's burning about 3/4 gallon per hour.
      At 2200, it's burning
      a knot isn't worth it,
      consumption?
      I
      thought I should have more engine RPM's before the
      and
      it
      — Syringa < ([email][/email])> wrote:
      Patrick
      I
      as
      steady
      (not
      backing or docking) I don't believe the shaft
      is
      off set (if it is it's not much) and should not
      over
      up
      with the answer.
      Don
      Syringa
    • #69806
      Thats the problem. Last year I topped off the tank
      before putting it on the hard for the winter. Who
      knows the speed and RPM’s done over the summer. Where
      we sail, if there’s wind on the bay, we motor out for
      5 minutes, sail for 6 hours and then motor back in for
      5 minutes. I think I used 15 gallons the entire
      summer.
      Beckie had neck surgery so we didn’t go anywhere.
      Not sure about this summer.
      Hi Alan,
      me, that’s not what’s going to happen this year as
      fuel as quickly as
      possible.
      That’s not the case this year…
      sure”.
      not
      outlet to sail.
      PITA.
      summer
      my
      arm fixed.
      to
      hour.
      most
      consumption?
      because
      I
      the
      W58
      and
      run
      it
      — Syringa <> wrote:
      Patrick
      Bellingham!
      I
      Syringa
      as
      steady
      (not
      shaft
      is
      not
      be
      over
      come
      up
      with the answer.
      changed
      Don
      Syringa
      m2f
      Read this topic online here:
      https://www.pearson424.org/bb2forum/viewtopic.php?p=831#831
      m2f
      === message truncated ===
    • #69808
      Has anyone got fuel consumption rates for a 424 with a Yanmar 4JHE?
    • #69809
      RE: 4JHE fuel consumption.
      Hopefully I get some metrics this summer on my 4JH4AE.
      I had fairly good metrics on my old W60 thanks to some extended engine usage in the last 3 years. On long motor trips I usually kept the RPMs around 1800, which in calm conditions gave me close to 6 knots through the water. At that RPM level fuel consumption was about 0.75 gal/hr.
    • #69812
      I have a 4JH3-TE. The only difference between our engines is the turbo. I’ve heard threads from the group discussing fuel consumption. I’ve never been able to measure mine. I suppose that I could fill up before heading out for a long cruise, then fill-up when I get to where I’m going. Then compute fuel economy based on engine hours and fuel added. This assumes that I fill the tank to precisely the same level on both fillings. I don’t know how I could ever do this. It also assumes that I run at the same power setting for several hours. This is unlikely.
      To answer your question, I would expect that any two contemporary engines would give very similar fuel consumption figures when driving a 424 in similar conditions. Variations include the effects of prop efficiency, condition of the bottom paint, wind and sea conditions. I’ve always estimated 1 gal/hr. I think this is pretty close, but I could burn more than 4gal/hr if I ran it wide-open. I would also guess that fuel consumption goes up rapidly at speeds greater than about 6.7kts. I’ve based this on how much power the engine seems to need in order to drive the boat. I usually cruise at about 7.0 kts. With the price of fuel going north of $5/gal, I might back off a little.
      This is definitely not a good time to own a power boat. Lets see 30 gal/hr at $5/gal = $150/hr. I don’t think so. Our dinghy even uses 3gal/hr. We put more fuel in the dinghy than the sailboat in a year.
    • #69815
      Thanks for your input, Rich. I expect we’ll find we’re burning about 1 gallon/hour at 6.5 knots in calm/moderate seas. Most boats/engines of this size/type come in around there. I was just curious whether anyone had hard numbers. No big deal. It is what it is.
      In any case, we’re all likely to be a little slower to fire up the “iron jenny” in light airs now, with fuel prices so high. Maybe that’s a good thing.
    • #69816
      Hello all:
      CHARISMA, while in the ICW last month, burned between 5/8 & 3/4 GPH @ 1600 to 1800 RPM. Her speed in flat H20 was about 7.8>8 MPH. She has her original W-6, and I think her wheel is 15″x15″.
      BILL
      Capt Bill Tice, aboard s/v CHARISMA, Deltaville, VA
      Wondering what’s for Dinner Tonight? Get new twists on family favorites at AOL Food.
    • #69817
      In a message dated 5/8/2008 12:43:00 PM Eastern Daylight Time, writes:
      sorry, wrong boat!
      BILL
