Forums › General Discussion › Fuel Pipes
    • #67048
      Bob,
      Thanks for the advise. I agree, compression fittings
      at the bleed points tend to get overworked. The
      previous owner used a heavy hand on just about every
      mechanical devise on board. Will be ordering a new
      set today.
      Yesterday’s sail was interesting. We moor on the
      Alameda estuary in the east bay. It was windless and
      hot when we motored out to the Bay Bridge. The breeze
      went from nothing to 25 in a quarter mile and stayed
      that way all afternoon. Recently had the blisters
      ground and faired. With the new bottom, we were
      surfing at 9.1 kts on a beam reach and a big flood on
      our stern. A nice ride indeed…
      Thanks again for all the help. You 424 owners are the
      best!
      Bill Emberley
      Running Tab, 424 #86
      — Robert Fine <> wrote:
      Hi Bill,
      I had a great sail on Long Island Sound yesterday
      morning, too – probably
      not as boisterous as SF Bay, but still nice. Then
      it got really hot and
      windless.
      I think I mentioned a parts dealer in one of my
      other posts for Westerbeke
      parts. I’m sure you can get new ones. Let me see if
      I can find it again.
      But the W58 is a Mazda industrial engine, so if we
      can figure out which one,
      we’d be good to go.
      On fuel pipe compression fittings:
      Two things happen to make them fail. They are used
      as bleed points (which
      is usually unnecessary) and they are tightened too
      much. They’re actually
      pretty delicate and require something in the range
      of inch-pounds of
      torque. It’s the sealing surface that makes the
      connection.
      Anyway, if you can’t find them new (and I’m sure
      Westerbeke sells them), a
      competent diesel mechanic can make new ones.
      On Sun, Jun 8, 2008 at 6:09 PM, Bill Emberley
      wrote:
      Hi Bob,
      Your email prompted me to do a thorough check for
      leaks then a system bleed. Discovery- #3 fuel
      pipe
      compression fitting at the injector gave up the
      ghost
      and is at least one of the air leaks. I had the
      #1
      fuel line go out a few years back and had a repair
      job
      done that has held to this day. In any case I
      think
      it is time to replace all.
      Any ideas on where I could get a new set? My
      local
      source said it would be difficult to find, and
      costly.
      I just want to eliminate any potential air leak
      problems.
      Had an great sail today on San Francisco Bay.
      Warm
      and sunny. Winds SW at 25-30. Just right for the
      424.
      -Bill
      Hi Bill,
      It sounds as if you have an air leak in the
      system
      that the normal flow at
      speed will cover. Not a big one. Find that
      first.
      If there’s an air leak in the fuel system, all
      installing a pump will do is
      make the system leak positively. Sure, the
      engine
      will idle, but you’ll
      also be putting fuel in the bilge.
      There is already a booster pump on the engine.
      You
      could use another one on
      the fuel tank where the cut-off solenoid is, if
      it’s
      still there. If not,
      there are already wires for a pump or whatever
      that
      is turned on with the
      ignition.
      On Sat, Jun 7, 2008 at 10:44 AM, Bill Emberley
      wrote:
      I have had random engine failures when idling
      for
      long
      period of time on my old Westerbeke. After a
      bleeding
      session the engine runs fine. I am considering
      installing an in-line 12v fuel pump to
      increase
      fuel
      flow.
      Questions
      1. Any recommendations on a Pump.
      2. Do you install it before or after the Racor
      filters?
      3. Is it wired to activate with the ignition
      switch?
      Thanks for any ideas you old salts may have.
      Bill Emberley
      Running Tab
      P424 #86
      Edit One Productions, Inc.
      2310 Clement Avenue
      Alameda, CA 94501
      Studio 510-814-9519
      Fax 510-814-6945
      Cell 415-279-1340
