Forums › General Discussion › Fuel tank leak 2
Viewing 12 reply threads
    • #68936
      Ken, or anyone else
      I got the engine out. I have all the fittings off except the fuel pick up. it’s right in the middle of the tank. once I scrunch my self-down into any one of the lockers I can’t reach it. how did you get that one disconnected?
    • #81158
      Alan, I was able to reach in from the stb locker to remove all the
      fittings. The actual pick-up obviously can’t be removed with the tank still
      under the deck, as it’s too long into the tank. Just remove or cut the
      fitting that is attached to it. You’ll be able to repair or replace it easy
      enough while the tank is out.
      On Thu, Jun 26, 2014 at 1:38 PM, Alan via maillist
      wrote:
      Ken, or anyone else
    • #81159
      oops…..port locker the one without the batteries in my case.
      On Thu, Jun 26, 2014 at 1:38 PM, Alan via maillist <
      > wrote:
      Ken, or anyone else
      disconnected?
    • #81160
      Your batteries are in the port locker? By the way, I know how to get a new
      pickup tube in the tank without removing the tank. Also, how to remove the
      old pickup tube without removing the tank, just in case anyone’s interested.
      On Thu, Jun 26, 2014 at 2:14 PM, Ken Page via maillist <
      still
      easy
      > wrote:
      Ken, or anyone else
      into
      disconnected?
    • #81161
      I am all ears.
      My batteries are in stb locker like most.
      I thought you made a mistake. I’ll have to rent a small kid with long arms to get one last fitting.
      I also have wire coming thru the mizzen step. Radar, wind gen etc. So I hoping to don’t have remove mizzen to full tank fwd.
      a
      still
      easy
      > wrote:
      Ken, or anyone else
      into
      disconnected?
    • #81162
      Can you get to and remove the support slats under the forward part of the tank? If you can, the tank might move forward and down allowing access from behind the engine.
    • #81163
      Alan,
      I don’t mean to butt in where I know less than everyone
      else here (although that has never stopped me before),
      but if you have wires coming in from the mizzen mast
      that are in your way, would it not be easiest to cut
      them, install connectors, and move on, rather than
      un-stepping the mizzen mast? I realize this is not a
      simple undertaking with the radar cable – perhaps the
      manufacturer offers a quick-connector exactly for this
      purpose(?) – but it will make life easier now, and also
      the next time you (or some FO) un-steps the mizzen
      mast.
      Or maybe you could just pull the wires back from their
      instruments as far as the mizzen step, as you
      apparently would have to anyway if you were to un-step
      that mast, thus getting them out of the way so you can
      move the fuel tank forward without un-stepping the
      mizzen mast.
      Or maybe I’m not seeing the situation as it really is.
      I do that a lot, too.
    • #81164
      Simple Answer would be, the connectors would then be in the way.
      Up north here, the masts come every year. So taking the mizzen down would be no big problem. 30 minutes worth of work at most.
      On Jun 26, 2014, at 8:19 PM, Silverheels via maillist wrote:
      Alan,
      mast.
      mizzen mast.
    • #81165
      You can unscrew the fitting on the top of the tank. Then lift and bend
      until you’ve removed it.
      To put one in you must make a coil of about 4 inches in diameter. Spread
      until the length of original tube and screw it in.
      That took me days to figure out.
      phone.
      On Jun 26, 2014 8:47 PM, “Alan via maillist”
      On Jun 26, 2014, at 8:19 PM, Silverheels via maillist <
      > wrote:
      Alan,
      mast.
      mizzen mast.
    • #81166
      When I removed my tank recently I was able to get to all the fittings on top of the tank from the port cockpit locker, facing aft with my left arm doing all the work. Some of the tank straps were very difficult to reach from the stb locker but I found it a bit easier to reach them from the old fuel tank site glass in the sole of the cockpit.
      After removing the forward frame work holding in the tank in one piece, I just sawzalled the screws holding the bottom part under the tank so the tank dropped down enough inches to easily clear the mizzen support beam.
      I had trouble removing the 1 1/2″ fuel fill fitting, so I just sawzalled it off too. No sense wasting effort on things much more easily dealt with when the tank is out.
      I can’t imagine any wires coming down from the mizzen could be that much in the way after knocking out the bottom of the tank support as I did. It was all very easily replaced while the tank was out, and you could redesign it to be fastened “after” the tank was put back in. Actually, I did just that by re-glassing/epoxy a bottom support to the hull after the tank was back in, then I screwed it in place.
    • #81167
      Bob, you are so cool.
    • #81168
      Glad to hear it. Good luck with the project.
    • #81169
      Alan,
      Try removing the fuel tank gauge viewing deck fitting. There should be enough room to get your arm in there. As I recall, you must remove the fuel gauge and everything else that sticks up from the tank to clear the mizzen support beam. You may need to remove some of the bottom boards from the crate too. I had access from the starboard locker since I had removed the battery box years ago. I never liked the weight on one side of the boat. It gave the boat a permanent list.
