Forums › General Discussion › FW: Where’s the lead?
    • #67986
      I have run copper strap from my automatic antenna tuner as a counterpoise for my SSB/HAM installation. I’ve already connected the strap to 3 bronze thru-hulls, as per Gordon West’s recommendation. Actually, he says 1 or 2 thru-hull connections are enough, and claims this is all that’s needed. However, since I had plenty of copper strap handy I continued the run forward through the upper bilge to the area of the mainmast step. Numerous radio-wise folks, including some in this 424 group and also my pretty sharp marine electrician neighbor, feel that connecting the strap to the lead keel ballast, even though it is internal rather than external, will significantly increase the power of the counterpoise. The connection is made via a lag bolt passed through the strap, into and through the fiberglass covering the ballast and into the lead.
      Personally, I pretend no knowledge of these esoteric mysteries. So when I get 7 out of 10 seemingly knowledgeable opinions in agreement on a point of procedure, I tend to follow that advice. I’m certain some of our 424 owners have lagged their counterpoise strap into the lead ballast. I’m hoping one of more of them will tell me where exactly they drilled and how far through the fiberglass they had to go to reach the lead.
