Forums › General Discussion › Fwd: Anchor Platform / bow sprit
- This topic has 8 replies, 1 voice, and was last updated 12 years, 1 month ago by
September 3, 2014 at 5:02 pm #68981
Glad you got it, Just noticed I left a few things out, Title Box, dates,
name, not to mention a few dimensions and text. My drafting teacher way
back in 1971 would of failed me for sure!!!!
Have fun,
KenOn Wed, Sep 3, 2014 at 12:54 PM, Paul Audi via maillist <
> wrote:Thanks Ken,
You’re my hero. This is great. I’ll see about fabricating locally.I’ll let you all know how it works out.
Best,paul
On Wednesday, September 3, 2014 9:41 AM, vickykenr— via maillist <
> wrote:Re: Fwd: Anchor Platform / bow sprit
Author:
OK, this is the last drawing of the anchor platform, I hope it can be of
use.I have seen these with an added support from below. I think it needs it.
Reply Link: <
https://www.pearson424.org/tiki/tiki-view_forum_thread.php?forumId=1&comments_reply_threadId=1&comments_parentId=755&post_reply=1#form_______________________________________________
September 3, 2014 at 5:07 pm #81473
Pat, I only took pictures of the 2 drawings themselves. I’m done now.
Thanks for your patience. I wish I could have done a more professional
drawing, but I think this will do for any who have use for it.
KenOn Wed, Sep 3, 2014 at 1:01 PM, pat noordsij via maillist <
> wrote:Uploaded both images to the website gallery
https://www.pearson424.org/tiki/tiki-browse_gallery.php?galleryId=3are there any other pictures I should load to this gallery?
– pat
vickykenr— via maillist wrote, On 9/3/14, 11:41 AM:
Author:
September 3, 2014 at 7:51 pm #81475
Pete, how about a picture? It sounds like a very strong addition! I’m
curious as to how it’s ended at the bulwark and hopefully not look like an
after-thought. Not that there is anything wrong with that, I understand, we
need to do what we need to do and sometimes within our means or acceptable
values. A picture tells a story. My platform is already bent and distorted
over these years, but not to the point that I believe it shows badly. A new
support from the stem similar to what I drew should keep it going for many
a more year.
KenOn Wed, Sep 3, 2014 at 2:06 PM, Pete Dubler via maillist <
> wrote:That drawing matches the design of my sprit/platform. Much stronger if a
channel is welded onto the bottom edge of the long tubes and across the
bottom of the cross bar. Make the channel out of 4″ wide 3/16″ thick
plate (need to find someone with a large hydraulic press to bend that).Pete
– pat
Author:
September 3, 2014 at 8:03 pm #81476
I’m surprised to hear so much about “bending platforms”. I’m assuming everyone is using a snubber that they cleat to the deck, through the chocks (not over the sprit). In this case, there is seldom any long-term strain applied to the platform. You’re biggest worry is just when hauling anchor (and presumably motoring toward the hook, so only the last bit of chain/anchor weight is involved). But maybe I’m misunderstanding some of this.
a more year.
– pat
Author:
September 3, 2014 at 10:48 pm #81478
I found some pictures on my phone. See attached two pictures and two
more in next mail. (This is before I took off the 35lb claw, moved the
65 CQR over to be my secondary anchor, and got the 85lb Mantus in
place). I am one happy hooker now!Pete
like an after-thought. Not that there is anything wrong with that, I
understand, we need to do what we need to do and sometimes within our
means or acceptable values. A picture tells a story. My platform is
already bent and distorted over these years, but not to the point that
I believe it shows badly. A new support from the stem similar to what
I drew should keep it going for many a more year.
< > wrote:That drawing matches the design of my sprit/platform. Much
stronger if a channel is welded onto the bottom edge of the long
tubes and across the bottom of the cross bar. Make the channel
out of 4″ wide 3/16″ thick plate (need to find someone with a
– pat
Author:
hope it can be of use.I have seen these with an added support from below. I
think it needs it.Ken
September 3, 2014 at 10:48 pm #81479
additional pictures attached.
– pat
Author:
September 3, 2014 at 11:45 pm #81477
Pete,
I like your solution. It avoids the problem of a bob-stay, or similar
support from below, chafing a snubber line as the boat sails at anchor.
One more item for the project file.Regards,
Sarah’s BlogOn Wed, Sep 3, 2014 at 6:47 PM, Pete Dubler via maillist <
> wrote:additional pictures attached.
a more year.
– pat
Author:
September 4, 2014 at 1:00 pm #81480
a more year.
– pat
Author:
September 4, 2014 at 10:21 pm #81485
Wow Phil, that “tool” you have looks to me to be a welding jig for the
proper location and angles to weld the pads on the platform. That would be
something that Pearson, or whoever fabricated these platforms for Pearson,
would use as a template to make multiple, over and over again exact fitting
pieces. That is a treasure for the 424’s. How it came with your boat must
have something to do with the shop that fabricated these. And I love the
support that you have under your platform.Ken
On Thu, Sep 4, 2014 at 5:20 PM, Philippe Fontaine via maillist <
> wrote:Quote:Pat and all,
Attached are Pictures of Aurora’s anchor platform, as it presently exists,
and a tool that was given to me by the previous owner. The purpose of the
tool, I was told, is to permit a bent platform to be straightened without
distorting the location of the bolt flanges. In fact I used it to
straighten mine (which was bent down somewhat when I purchased the boat)
before I had a local welder fabricate the diagonal brace shown in photo.
I am not near my boat so I cannot confirm that my platform is exactly the
same as Ken shows in his drawings but from memory I am quite sure that it
is. It was original to the boat and the length of the tool at the center of
the flanges is about 29 inches – which correlates well with the 32 inch
dimension in the drawing. I would be pleased to loan it to Paul or anyone
else who might want to have a platform fabricated or straightened. I don’t
know what the shipping cost would be but for estimation purposes, the tool
weighs about 10 pounds.
Phil Fontaine
Aurora – Ketch # 94
