Forums › General Discussion › Generator hookup
- This topic has 9 replies, 4 voices, and was last updated 14 years, 8 months ago by
Hull152_Patrick.
February 17, 2012 at 7:16 pm #68518
SpectatorHey guys, quick question. I bought a Honda Eu20i here in Mexico. It’s
the same as the eu2000i (non-companion) so I need to connect a
standard three prong cord to boat’s shore power. I was going to make a
cord, but the twist locks from Marinco are crazy expensive.Could I wire in a standard 20amp out to the back of the shore power
inlet instead? Mg thought is to have this outlet live inside the
lazarette.Quick replies get extra points, I’m at home depot. 😉
Thanks!
-pSent from my iPhone
February 17, 2012 at 8:09 pm #78259
ModeratorYes, but why not an adapter and regular extension cord? Adapter like $40
and you should have one anyway.I’m not being terse. This is from my mobile.
On Feb 17, 2012 2:17 PM, “Peaboy Walters” wrote:Hey guys, quick question. I bought a Honda Eu20i here in Mexico. It’s
Thanks!
February 17, 2012 at 8:26 pm #78260
SpectatorThe adapters are unavailable here at the moment and expensive when they are.
I think I’m good to go now, I just wanted to check with y’all that I
wasn’t missing something.Muchas Gracias!
Thanks!
February 17, 2012 at 8:32 pm #78261
RichCarterParticipantMy boat has a 30A 115v make receptacle for shore power. If you add a second receptacle and feed power through it, the make plug will be hot. This is a bad idea and must violate some codes.
I made a 15A shore power adapter cord many years ago using a cheap extension cord and a plug purchased at the hardware store. It wasn’t expensive. You don’t really need a fancy marine plug for this.
I use an EU-2000 on my boat. It works pretty well.
February 17, 2012 at 8:58 pm #78262
SpectatorI did see a 15amp twist lock which could be wired to a cord. I didn’t
think the tong (?) or pin pattern was the same circumference as the
30amp. Maybe I was wrong though.-p
On Feb 17, 2012, at 12:33, “”
wrote:Quote:My boat has a 30A 115v make receptacle for shore power. If you add a second receptacle and feed power through it, the make plug will be hot. This is a bad idea and must violate some codes.I made a 15A shore power adapter cord many years ago using a cheap extension cord and a plug purchased at the hardware store. It wasn’t expensive. You don’t really need a fancy marine plug for this.
February 17, 2012 at 9:04 pm #78263
ModeratorI’ve made that mistake. It isn’t the same…
On Feb 17, 2012 3:58 PM, “Peaboy Walters” wrote:I did see a 15amp twist lock which could be wired to a cord. I didn’t
wrote:My boat has a 30A 115v make receptacle for shore power. If you add a
expensive. You don’t really need a fancy marine plug for this.Quote:I use an EU-2000 on my boat. It works pretty well.Rich
February 17, 2012 at 9:46 pm #78264
Rich’s point is valid, but you are in Mexico. Down there you don’t need no
stinking codes[?]. Just to be a little safer, maybe could you buy a 20A
male plug and seal the inside (silicone?). Insert that into 20A female
plug that you are going to wire to the backside of the shore receptacle
when you are not running the generator. That way there is no open hot plug
in the lazarette on those rare occasions when you are plugged into shore
power.I think a little caution with what you are planning will prevent any
problems until you can get a proper adapter for the shore power receptacle.Regards,
February 17, 2012 at 11:20 pm #78265
SpectatorI gotcha…. Like one of those plastic child proof plug thingies.
On Feb 17, 2012, at 13:46, John Stevenson wrote:
Patrick,
February 19, 2012 at 12:50 pm #78266
RichCarterParticipantThe issue is that the existing shore power plug on the boat will have live power on it. If someone gets their hand in there they could get injured.
February 19, 2012 at 2:10 pm #78267
SpectatorTrue, but it does have that handly screw down cover.
I ended up finding a shore cord for $23USD at a swap meet and put one
of the three prong plugs that came with the EU20i on the male end of
the cord. We’ll give it a shot this week.Thanks!
-p—
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.com | @DeepPlaya | W7PEAOn Sun, Feb 19, 2012 at 6:50 AM, wrote:
Quote:The issue is that the existing shore power plug on the boat will have live power on it. Â If someone gets their hand in there they could get injured.Rich
