Forums › General Discussion › good mechanic
Viewing 5 reply threads
    • #68606
      Jack Clarke
      Can anyone in the group recommend a good reasonable mechanic that I can get
      to look at my Perkins engine? Right now I’m in Sandwich MA and going
      through the CC Canal today. I’ll be in the west MA, RI & CN area this
      week and on to the Long Island area after that.
      I’m having overheating issues and I think that the repair may be beyond my
      limited skills level. My plan is to carry on down to the Bahamas, so I
      have to get this addressed ASAP. Any help or information will much
      appreciated. Also, my Internet will be limited, so I might take longer
      than normal to get back to you.
      Jack Clarke
      Xanadu IV
    • #78719
      I can take a look at it if you’re in Stamford.
      Jack Clarke
      Xanadu IV
    • #78720
      Jack,
      An overheat issue should be something that we can coach you through. Is the engine pumping a full stream of water out the exhaust when running? Do you have white smoke in the exhaust when its running hot?
    • #78721
      Jack Clarke
      The problems that I’m having are;
      1/ white smoke like steam coming out the exhaust
      2/ the hoses coming from the transmission cooler to the raw water pump
      are collapsing
      3/ I’m loosing coolant from the heat exchanger
      I’ve had different people tell me an assortment of different things that
      could be the problem. I think that that transmission cooler is clogged.
      It’s much like the tube in the heat exchanger, only smaller. You can only
      access about 25% of the tubes. I’ve tried flushing it with Salt-away and
      it helped a bit. I think that it needs to be soaked in something
      stronger. Can the transmission cooler be bi-passed without any ill
      effects?
      Bob, I’m in Marion MA today and will be leaving tomorrow, weather
      permitting, and most likely head for Pt. Judith and then west again after
      that. This whole area is new to me, but I don’t like to get too far off of
      the main routes. I could probably be in Stamford by Thursday or Friday.
      Thanks everyone
      Jack Clarke
      Xanadu IV
      Please keep any suggestions coming
    • #78722
      Jack,
      What kind of engine?
      Most engines cool the transmission on the freshwater side but some use the seawater side for cooling. It sounds like you have seawater cooling your transmission and a blockage between the heat exchanger and intake through hull. Does a hose go between the heat exchanger and vdrive?
    • #78723
      Ok, Jack, let me know – I may be able to get you a slip for a night while
      we fix it.
      are collapsing
      effects?
      Thanks everyone
      Jack Clarke
      Xanadu IV
