Forums General Discussion Goose Neck Question
Viewing 14 reply threads
    • #68751
      I am getting ready to put my rig back together and noted that the goose
      neck pin (bolt) (the one with the reefing hooks) has a lot of play
      relative to the bushing. The bolt is 1/2″ and the bushing it 3/4″. It
      this supposed to be this loose or am I missing an insert (nylon or
      otherwise) here? See picture below.
    • #79817
      patn
      hmm… picture??
      – p
      Pete Dubler wrote, On 7/13/13 9:44 PM:
      goose neck pin (bolt) (the one with the reefing hooks) has a lot of
      play relative to the bushing. The bolt is 1/2″ and the bushing it
      3/4″. It this supposed to be this loose or am I missing an insert
      (nylon or otherwise) here? See picture below.
    • #79820
      The picture is pasted above
      On 7/13/2013 8:55 PM, pat noordsij wrote:
      hmm… picture??
      – p
    • #79821
      Let’s try one more time. The picture is attached instead of pasted…
      hmm… picture??
      – p
    • #79822
      Pete,
      I can’t see the bushing on my gooseneck without taking it apart, but I
      definitely don’t have any play in the fitting. There must be a missing
      bushing.
      hmm… picture??
      – p
      neck pin (bolt) (the one with the reefing hooks) has a lot of play relative
      to the bushing. The bolt is 1/2″ and the bushing it 3/4″. It this supposed
      to be this loose or am I missing an insert (nylon or otherwise) here? See
      picture below.
      https://pearson424.org/mailman/**listinfo/maillist_pearson424.**org
    • #79823
      Thanks John.
      On 7/14/2013 10:46 AM, John Stevenson wrote:
      Pete,
      bushing.
      hmm… picture??
      – p
      picture below.
    • #79824
      Not ever really looking at the details of the gooseneck on the 424 but having fabricated from wood and had cast, then machined and installed custom bronze goosenecks on a 50′ schooner, I can tell you for sure from that picture “something is missing” !
      Is it possible the mating boom fitting fits in as what appears to be a missing bushing?
    • #79825
      Unrelated to the gooseneck(sorry pete)… I have a question for an administrator or anyone really……why can I not edit my comments, add pictures etc on this “mailing list” thread, but on the “chit chat” thread I have full use these abilities?
    • #79826
      RigRite has parts. They’re bastards to deal with though !
      Writing a New Chapter Page by Page in an Old Book.
    • #79827
      I can come up with a bushing of those dimensions pretty easily.  Thanks folks
      Sent from my Android smartphone with a spell checker that is programmed to entertain you.
    • #79831
      I have a bit of play in my gooseneck but not what I would call unusual. I took a close look at your photo and your fitting looks a bit different. I’ll send a photo of mine as shortly. Mine has a steel pin through the mast fitting as yours (3/8″?). The gooseneck fitting is a flat plate bent over a steel bushing whereas yours looks to be plastic. My steel bushing is welded to the plate. While examining mine, I noticed cracking near the pin. If you hadn’t sent your question, I would have never noticed until it failed. I’ll send it out to a welding shop this winter. I suggest that other owners inspect theirs.
      My guess is that Pearson had some failures in the first few model years and redesigned the gooseneck to include a plastic bushing. This probably absorbs some of the shock load on a gybe. The plastic bushing is much larger in diameter. It may have deformed after several years of service and give some play to the fitting. A good hardware store may have a replacement.
    • #79833
      Pin is 1/2″ – the whole thing is not shown. It has hooks on the top for
      reefing.
      Everything is metal. No plastic.
    • #79834
      Peter
      Your bushing is much thicker than mine. Yours looks bronze. Mine is stainless. On mine, side plate is just folded across the roll-pin which is welded to the plate. There are fine cracks on each side. There is also a tang on the center pin under the rod that mounts the reef hooks. It fits between the side-plates. Yours bulges out to support your thicker bushing. I have hull #47.
      Your bushing appears to have quite a lot of clearance for the center pin. It almost appears that your bushing is the wrong size. I wonder if your original fitting broke and was replaced with a close match. If someone replaced the fitting at some point, the tang would have needed to be cut off to accommodate the thicker bushing. A replacement bushing might solve your problem. Look for axle bushings at tractor-supply.
      Rig-right has several possible replacements.
      http://www.rigrite.com/Spars/SparParts/Gooseneck_toggles.html#Gooseneck%20Toggles%20for%20a%201/2%22%20Vertical%20Pin
    • #79837
      Photo attached
    • #79838
      Thanks Rich. They are definitely different.
      On 7/16/2013 5:35 AM, Rich Carter wrote:
      Photo attached
