Forums › General Discussion › Harken Load Specs
    • #67613
      Have any of you, or your riggers, done any validation of the running rigging load calculations for the P424 on http://www.harkencompuspec.com/ ?
      The input measurements seem a little off but not enough that the output numbers should be wildly out of the ballpark.
      Curious what you think….
      SheetLoads: 100% Foretriangle @ 30 Knots: 1346.5 lbs 610.8 kg 100% Foretriangle @ 35 Knots: 1832.8 lbs 6.1f kg 100% Foretriangle @ 40 Knots: 2393.8 lbs 1085.8 kg 135% Foretriangle @ 20 Knots: 807.9 lbs 366.5 kg 135% Foretriangle @ 25 Knots: 1260.3 lbs 571.7 kg 135% Foretriangle @ 30 Knots: 1817.8 lbs 824.6 kg 150% Foretriangle @ 5 Knots: 56.1 lbs 25.4 kg 150% Foretriangle @ 10 Knots: 224.4 lbs 101.8 kg 150% Foretriangle @ 15 Knots: 504.9 lbs 229.0 kg 150% Foretriangle @ 20 Knots: 897.7 lbs 407.2 kg
      Lead Block Loads: #3 Genoa @ 30 Knots: 1763.9 lbs 800.1 kg #3 Genoa @ 35 Knots: 2400.8 lbs 1089.0 kg #3 Genoa @ 40 Knots: 3135.9 lbs 1422.4 kg #1 Genoa @ 6 Knots: 60.6 lbs 27.5 kg #1 Genoa @ 12 Knots: 242.4 lbs 109.9 kg #1 Genoa @ 18 Knots: 545.3 lbs 247.4 kg #1 Genoa @ 20 Knots: 673.2 lbs 305.4 kg #1 Genoa @ 25 Knots: 1052.0 lbs 477.2 kg
      Mainsail Area (Standard Roach): 294.8 sq ft 27.4 sq m
      Spinnaker Sail Area: 1249.7 sq ft 116.1 sq m End Boom Load: 1996.89 lbs 905.79 kg
      Maximum Genoa Turning Lead Block: 60 Degree Turn: 1832.8 lbs 831.3 kg 90 Degree Turn: 2584.2 lbs 1172.2 kg 135 Degree Turn: 3372.3 lbs 1529.7 kg 180 Degree Turn: 3665.5 lbs 1662.7 kg
