Forums › General Discussion › Hatch refurbish
- This topic has 2 replies, 3 voices, and was last updated 16 years, 6 months ago by
sumocean.
April 9, 2010 at 6:01 pm #67965
ParticipantAnyone replace the lenses in the Bomar deck hatches? Canal plastics
has nothing uv resistant which translates to a useful life of two-
three years here or 17 minutes in the islands.Adam Silverstein, iPhone
April 9, 2010 at 9:12 pm #75135
RichCarterParticipantYes, I purchased smoked Margard polycarbonate from a local glass shop and used silpruf bedding compound to replace the plastic in my deck hatches a few years ago. As reported earlier, I had hinge failures in two hatches and ended up replacing the whole thing. I bought a pair of Bowmar deck hatches from the same place I purchased the portlights for about the same price ($200 ea.). They were extruded aluminum frame hatches rather than the cast aluminum. They were the same size, but the hole pattern was different.
http://www.infolink.com.au/c/Sabic-Innovative-Plastics/Lexan-Margard-Polycarbonate-Sheet-n762089
April 9, 2010 at 10:58 pm #75136
ParticipantAdam
I pulled mine several years ago had the frames powder coated and replaced the glass. I believe that it was Lexan. I contacted Bomar and they suggested the type of glass and I got it at a local glass shop. I can’t remember what the name of the glazing compound that they told me I had to use. I believe that it was GE Ultraglaze it was the stickiest stuff that I have ever seen I recomend taping off the glass inside and out. It is difficult to tool and sticks to everything that it comes near. The powder coat was not worth it to me. I have had to touch up with paint but all in all they are better than when I started. No leaks and I can see through them.
Sumocean
